+ Reply to Thread
Results 1 to 14 of 14
Thread: Radio Antenna possibilities question
    Member manta73wi manta73wi's Avatar
    Sep 2003
    Mequon (Near Milwaukee) Wisconsin
    640
    My "new" '75 Manta did not come with a radio or antenna originally, which I believe would have been dealer installed back in the day. The previous owner recently installed a CD player, which is fine, but I would miss my morning radio show on the way to work.
    Since there is no antenna, I would like to install one (I do have antenna & cable from my '74 parts car). However, looking at the shiny fender, I'm not thrilled about cutting a hole there. It looks so nice and smooth without the chrome glob on top of the fender!
    Are there any modern advances in antennas that would allow for decent reception without having to cut into the body? Or, should I just give in and install the parts car antenna? Thanks!
    Jeff W
    '73 Manta
    '75 Manta
  2. #2
    Cunning Linguist tekenaar will become famous soon enough tekenaar's Avatar
    Plano, TX 75074
    4,459
    tekenaar has made a donation to the forum!
    Stock or no?
    Depends on how "stock" you want to leave car . . . Never thought "windshield" antennas were all that good, reception-wise. Even today, not too many other "non-drill" antenna options.
  3. #3
    antenna
    on my opels i am using the hirschmann antennas [ german made ].
    i have the power antenna for $65 and i can get the manual for
    around $ 22. it is replacement for bmw and mercedes.
    Pete
  4. #4
    Antenna
    You could mount a semi-automatic power antenna on the rear panel on the passenger's side. I had one on a 75 Manta that I had until recently. It looks good on the back. There are windshield antennas that have better reception these days. You can try to find one of the T-shaped inside antennes designed for the rear window.
    The rear mount semi-automatic antenna looks better if you go with the outside mount. Plus, you can lower the antenna when not using the radio.
    Don't drill without a good reason. Good luck on that decision.
  5. #5
    Southern Red Neck BQS4 will become famous soon enough BQS4 will become famous soon enough BQS4's Avatar
    Snellville, GA
    6,162
    You can go to a CB shop and get a trunk mount that uses the inside lip and you can close the trunk. You can mount an antenna on that and never touch any of the fenders
  6. #6
    opel free after 26 years baz is on a distinguished road baz's Avatar
    Jun 2002
    sunderland england
    5,072
    find a ford with the rear screen demister used as an antenna and wire that in (escorts use it )
    2 wires to the grid on the screen
    1 power in
    1 ground and a screw in antenna lead to the radio
    result radio with no holes
    B.O.O.B. founding member
  7. #7
    Opel GT? Who makes that? simplemind7 is on a distinguished road simplemind7's Avatar
    Oct 2004
    Ayr, Ontario, Canada
    631
    this might sound stupid as i've never heard of it done or talked about before (probably for some reason) but could the body itself be used as an antenna? as in hook one end of the antenna wires to the front of the roof and the other to the back. or would the body already being used as a ground create problems? problems like.... 12 volts running at way too many amps running through the deck on its way to the battery... I think I might have answered my own question there
    Brendan:
    72 Manta Rallye
    69 GT
    72 GT - parts car
  8. #8
    No Access nobody is on a distinguished road
    Nov 2003
    in transit
    3,870
    Like Baz pointed out some cars use a window type. You can buy them at any good stereo shop that does installations. It is a thin wire run across the top of the window with a thin non yellowing tape. They do work well.
    I think all Opels brought to the US had a radio. Some newer cars it's an option, like tires and doors that you get to pay extra for.
  9. #9
    Pleasant Valley, CT
    7,558
    Not sure about GT's, but I've had three other Opels (one Manta, one Ascona, one wagon) with the radio deleted. No hole in the fender top, no hole in the inner fender for an antennae cable, no speaker, and the dashboard inset was smooth with no cutout for a radio.
  10. #10
    Nov 2003
    in transit
    3,870
    Now that you mention it I have seen a block off cover that was a factory part. I'm not sure from what model it came but it was Opel.
  11. #11
    Block off plate.
    The plate was probably from a Kaddet. The GT and the Manta have the vinyl covered foam dash over the reinforcing sheet metal skeleton.
  12. #12
    Plano, TX 75074
    4,459
    Radio delete
    Quote Originally Posted by RallyBob
    Yeah, that's how my 1300 mile '75 Ascona (1900) is . . . no cutouts in dash, no speaker mount, no holes in fender or underneath. Gonna leave it that way for now.
  13. #13
    Jun 2002
    sunderland england
    5,072
    Quote Originally Posted by nobody
    what you had to buy the tyres doors extra must have been a harsh drive and a heck of a windy ride
  14. #14
    Saint Michael, MN
    1,724
    Blog Entries
    one more idea
    Some Ford cars in the early-mid 80's used an antenna that mounted inside the car, either in the a-pillar under the plastic trip or under the top of the dash. They worked a bit better than the wire-type ones, but not quite as well as the regular ones in the fenders. While I wouldn't know where to get one now, I bought 20 or so of them at one point to have around as spares when I was installing stereos professionally, and I still have a few. For someone who doesn't want to drill a hole in the firewall and another in the fender, they might work out slick. Let me know if anyone's interested.
+ Reply to Thread
