#26 (permalink) | |
Are WE having FUN YET!!
Rick in Atlanta |
#27 (permalink) | |
Thanks |
#28 (permalink) |
You are talking about the idler pulley for the GM compressor? If so I just got one and will take a picture later today and post for you. I dont know if it is the same, but if you need a pic of the York idler pulley it is on a Manta and the pic angle would be, not so good, but I could do that too.
TMK
#29 (permalink) | |
idler pully for ARA with piston type compressor
Thanks Dennis Last edited by tekenaar; 11-09-2007 at 05:27 PM.. Reason: clarify title |
#30 (permalink) | |
#31 (permalink) |
The ARA idler pulley mounts on an adapter plate at the front cam cover . . . see attached pics.
#32 (permalink) |
5,000 Post Club
I guess I should have been more descriptive Otto. As you know there are two knobs on the GM AC control panel. One is the fan switch with multi-colored wires attached to it. The other is the temp selector. That is where the "Bourdon" type tube coil is connected to and is wound in to a circular shape about 4" in diameter with about 1/2" space between the coils. It is mounted right at the outlet opening of the AC enclosure. I can take a pic later if you need to see it.
#33 (permalink) |
. . . thinking outloud here for a moment, do you have the ARA compressor bracket and cast alu radiator hose adapter already? What about the ARA crank pulley . . . those are all pieces specifically required if using the ARA compressor mounted in its original location!
#34 (permalink) | ||
#35 (permalink) | |
I will have to hunt through my boxes of forgottens to see if I have that idler or not. It appears not to hard to fabricate if not, thanks you so much for taking time to get a picture of it for me. My whole unit is mounted, the ARA [early] model console wired and rear unit and hoses in place just needs a belt and maybe a leaky condenser to deal with never has been charged up yet and it may have other sorted problems as well, it has never been hooked up before. I need to start uploading pictures of equipment so everyone has a better idea of what I'm refering to. Last edited by tekenaar; 11-10-2007 at 04:59 PM.. |
#36 (permalink) |
Firstly, definitely upload some pics if for no other reason than to archive an ARA installation.
Just curious, but are you planning a 'period-correct' ARA install or just making do with whatever you have, i.e. all ARA pieces or mix-and-match pieces? Are you restoring your GT or just fixing it where necessary to make it driveable? |
#37 (permalink) | |
This piece must bolt on over the cam plate already on the head or the cam button would not have the proper clearance and the seal would be lost with the standoffs built on that piece you have pictured ? I have so much opel stuff it's hard to keep track of anymore just stored in boxes I parted out about 5 of these cars plus the cars I have, 5 intact cars no major damage or rust was on any of them, all but two are rebuilt 1 is almost there just needs assemble and paint drive train is rebuilt and in place. I see some pistons on ebay that I was considering for a spare motor I have one rebuilt with .05 in it but they are dished and the ones on ebay are flat top so may just buy if I can and put in stash for later. Right now I'm realigning parts to make them as accurate as possible with details associated with each year. After that garage sell. When I started my opel disease I just put together whatever I had to make the cars workable in example my 71 has the turn signal off the pre 69 model with dimmer button on it and the gauges /panel off that year as well that I need to get back on the car's they belong to. And to clarify this ARA unit is complete it has the double pulley the radiator hose casted adapter for clearance and the early model console as well as the rear deck and the extra 6 inch base plate for the rear tray that has the vents for suction on it. I have the later too model, but it is not as clean an assemble as the earlier model it wraps up and over the shifter where as the early model is kinda flatter and equally divided for the vents at a lower height. I promise to get some pictures just need to figure how to upload in the messages as others do and get it done. My car is very drivable already it peels rubber in first two gears it was totally mechanical rebuilt 10 years ago and painted as needed to stop rust living in Texas is not always an advantage. I painted it a light burnt yellow (dark banana yellow) but original color was silver so I need to go back and do it correctly. Now that I am in headed in retirement years and have the money I plan and making them all respectable cars for the years they are. |
#38 (permalink) | ||
I still have the ARA unit on my GT as installed in '73, except that I replaced the York compressor with a Sanyo. The York compressor is a good unit, cools the car well and mine didn't fail; the Sanyo just frees up a lot of engine compartment room and it kicks on and off much more smoothly than the York unit. The york is so large that its hose fittings often rub the underside of the hood when the engine torques over and it is near-impossible to see the flywheel timing mark with the York installed. A final suggestion for installing the ARA in a GT is to put a 6-8" loop in the condensor hoses in front of the radiator. This way, when it is time for a new battery, you just have to remove 4 sheet metal screws from the condenser and rotate it up and out of the way without having to break any hose fittings or add any new freon. You don't live that far from me; if you would like to come look at a near-original set up PM me. HTH Bob |
#39 (permalink) |
Thanks for that reminder, SpringGT, had forgotten about that spacer . . . still have that too. Now I remember where it's used, just have to find it again. My ARA was in my original '73 GT too, purchased in '76 and converted to '75 FI in '78.
Contact me by PM, Dennis Texas . . . I'll make you a good deal on those two items, if you want . . . that's why I asked my questions a few posts earlier.
#40 (permalink) | |
#41 (permalink) | |
5,000 Post Club
