Unanswered: heater valve substitute
I am usin a heater control valve on my manta that came out of a mid 80's honda accord. It is cable operated, opens and closes the same and even has a control cable clip on it( the valve will work fine without cable secured in the clip). It has the same 90 degree bends as the original. The hose fittings are slightly smaller than orig. Very cheap and works great!
DAN |
I searched thru parts books till I found a valve that looked and worked the same as the opel. Then I went to wrecking yard and found the valve, not sure of year. I was going to order a new one if it worked ok but the used one has worked great and no leaks.
I dont know what the GT valve looks like, the manta is 90 degrees and the cable pushes to open the valve. DAN |
