i would say so, mine was brought to me from GA...
just unhook the driveshaft before u tow...
Is it okay to transport a GT on a tow dolly for, say 150 miles?
Adam
I understand you should do this with an automatic, but is it required for a manual transmission?Originally Posted by spdkilz02
1973 GT, Parted out, R.I.P.
Nope. You can leave it alone if it's a manual.Originally Posted by jlthunder
well they did that just because it was such a long trip and they didnt want to take the chance of the tranny slipping into gear on the way up...
Adam
Bob, what's different about the Opel manual trans. that allows you to tow it w/o disconnecting the driveshaft?Originally Posted by RallyBob
I've never had an Opel box apart, but I've seen a number of other rear wheel drive manual transmissions that have burnt up from being towed. The mainshaft just spins inside the speed gear bearings, and since they aren't getting splash lube from the countergear spinning around in the oil as they do in normal operation they simply overheat. Results can be ugly - locked rear wheels, etc. I definitely would not recommend towing any RWD manual with the driveshaft connected.
I also watched John Gresley unload his GT from a dolly at Carlisle a couple years ago and drive away with no problem after towing it 750+ miles from WI so I know the GT seems not to have this problem.
I can't imagine it has an oil pump. Is the lube level high enough to oil the bearings?
Don
Opel says in the FSM's that you only have to disconnect the driveshaft if it's an automatic. Definitely not an oil pump in there!Originally Posted by dcm013
Knowing that the oil pan is nearly flat and the gear oil fill plug is a decent distance from the bottom of the pan, there's probably a lot of oil slinging going on there. I have never confirmed this firsthand, but I can check tomorrow as I have a 4-speed torn down I can measure.
I do know of one former Opel rally driver who towed his Opel on a car dolly to every event he ran over 8 years. Closest rally to him was 60 miles away, but one year he towed from Virginia to Maine nonstop with no issues, I'd guess 700 miles each way.
Speaking of towing, I'll be towing my GT from CT to NJ on Saturday! With the exception of about 8 weeks in 2004, this will be the first time I've had my GT out of storage and in the same state as me since 1999! I'm pretty excited, so honk if you see a blue GT on a trailer somewhere in the Northeast!
That being said, if anyone is in the Philly/Atlantic City area (I live right in the middle) who likes working on Opel brakes, let me know...![]()
Support the Coast Guard, get lost!
I checked an open transmission, and the countershaft is nearly completely submerged in gear oil. The gears on the main shaft dip into the oil as well, so my thoughts are that there is a whole lot of oil 'slinging' going on inside the transmission, and it would appear Opel deemed this splash lubrication sufficient for towing.Originally Posted by RallyBob
Just my thoughts,
What do you need to know? It is a very basic system.Originally Posted by yiger
Just got back from towing my GT to my new home in NJ. I don't recommend using a UHaul 4 wheel trailer- the supports are far to far apart for the GT's narrow wheel base. Trust me, it's not worth the stress-
-as far as what I need to know about brakes, I'm sure I can find it all here with the Search function on the site, but don't be surprised to see me throw out some questions now and then.
J
What problems did you have?Originally Posted by yiger
Almost embarassed to say, but in the dark of night, and in the pounding rain, the front driver-side tire slipped off the trailer and landed on one of the trailer axles (which was VERY fortunate for me- it kept the body from contacting the trailer at all). I was a great way to meet my new neighbors- knocking on doors late at night asking if they'd help pick up a car... It took 5 guys, and a really big lever to lift the thing back onto the trailer. What a mess... The plus side is that the car rolled away from the whole thing without even so much as a scratch, and I ended up meeting some of the world's nicest neighbors.
Hope you took out the extra insurance..lol We hauled a big dust collection unit for the gov't in a uhaul a couple of weeks ago and the dang thing shifted and we ripped the whole side out of the truck, but we had the insurance and the truck was covered![]()
Toby
Work is for people who don't know how to fish
I towed 2 opel gt's from Ok. to Tx. 400 miles at least. I used the u-haul tow dolly with the rear end on the dolly. I made sure the steering was locked. I also made sure to get the straps tight and the tires on the dolly correctly. I had no problems both trips.
I did the same thing, NC to PA, no problems back in '86Originally Posted by tomcat
Why backwards? To avoid differential issues I assume, but why bother if we've decided it won't hurt it? I've got one nibbling my bait, if it pan out, and it's a pretty long shot, I just don't want to hurt it. Just treading water whilst hunting GT's. It is still open season on them, isn't it?
You hit the nail on the head. My rear axle locked up. We unlocked it enough to get it on a tow dolly.
Your axle locked up because you dollied it?
Sorry for the misunderstanding.
My rear axle locked up due to a bad pinion seal. I then unlocked it and put it on a tow dolly with the rear wheels on the dolly so I could get it back home in PA.
The dolly had nothing to do with the axle locking up.
