Go Back   The Classic Opel Forums > Opel Forums > Classic Opels > GT
Old 10-05-2006   #1 (permalink)
akitamojo is on a distinguished road
Unanswered: Need Help Identifying these parts
akitamojo is offline
Old 10-05-2006   #2 (permalink)
tomking's Avatar
First and fourth items are for the spare tire shelf.
Second item I dont know.
Third item is rear resonator mount bracket
fifth item is engine brackets to reinforce engine to tranny mount.
TMK
tomking is offline
Old 10-05-2006   #3 (permalink)
opelnut10's Avatar
Item Identification
#1 Motor mount bracket, #3 GT rear muffler bracket # 5 bell housing to engine block bracket, sorry the other two I have never danced with
opelnut10 is online now
Old 10-05-2006   #4 (permalink)
Thanks so far, will you take a picture of the part attached to the car? It will help us know what bolt out of our coffee cans to use. It will also help clear up #1, lol. Thanks
Old 10-05-2006   #5 (permalink)
Top to bottom:
Spare tire well part for GT
Battery hold-down, bend to straighten
GT rear resonator mounting bracket
Another GT spare tire area part
Block-to-bellhousing stabilizer brackets for manual transmission
Old 10-06-2006   #6 (permalink)
To add . . .
Originally Posted by RallyBob View Post
Top to bottom:
. . . to clarify "bend to straighten":
Old 10-06-2006   #7 (permalink)
2 Fast 4 U's Avatar
Top to bottom:
got them on the auto trans as wel [Ascona]
Opel Ascona;
Only built from 1970 - 1975
2 Fast 4 U is offline
Old 10-06-2006   #8 (permalink)
Yes, very true. But the auto trans versions have wider spacing on the bolt pattern on the transmission. The ones in the picture are from a manual transmission (4-speed).
Old 10-06-2006   #9 (permalink)
The information is great however the transmission brace is concerning me because we definitely have an automatic transmission. Can someone tell me what the bolt spacing should be for an automatic transmission brace? Or I can take a close up picture of the braces with a ruler next to them if that will help.
I am sure I can figure out the transmission braces, if they will actually work with this transmission and I am sure I can figure out the battery brace and rear resonator brace but, I would like to see a picture of the tire rack braces if it is not too much trouble.
Thank You,
Joshua
Old 10-06-2006   #10 (permalink)
bq97
Number 1 is in the very front center underneath the tire shelf between the shelf and the floor pan. In the first picture the bracket is on the far left under the shelf, center line just above the driveshaft tunnel.
Number 4 is in the very rear of the tire shelf and goes between the shelf and the body, it’s one of the pivot points for the spare tire hold down.
bq97 is offline
Old 10-07-2006   #11 (permalink)
2 Fast 4 U's Avatar
Yes, very true. But the auto trans versions have wider spacing on the bolt pattern on the transmission. The ones in the picture are from a manual transmission (4-speed).Bob
????? what do you mean by that?? I thought that I could change an auto trans and a manual trans without any problems or adjustments?? [and they do!!]
and now you say:
"But the auto trans versions have wider spacing on the bolt pattern on the transmission.
Opel Ascona;
Old 10-08-2006   #12 (permalink)
opelwasp's Avatar
The GT manual tranny bell housing brackets and the manta brackets are not the same. If you have a GT and want to put in a Getrag you must get the brackets from a manta 4speed because they fit the Getrag. The manta bolt pattern is closer together than the GT. As far as the auto tranny i have no idea. The ones in the picture though are from a GT 4speed.
opelwasp is offline
Old 08-02-2008   #13 (permalink)
Mid-West Opeler
sawdust's Avatar
Logbook Entries: 2
Real Name: Hans
New Part to identify
I was working on the Weber again (72 GT 1.9 engine) when I spotted this laying on the motor mount under the carb.
Picture1 is the bracket or heat shield.
Picture2 is the motor mount and the remainder of the part.
My other car does not have one. Any ideas as to what it is??
Projekt 2009 - Der OPEL GT
Other Cars:
2006 Solstice (Aggressive)
2010 Fusion Hybrid (White)
LINK to my picture Albums
sawdust is offline
Old 08-02-2008   #14 (permalink)
I'm not sure about your question. The heat shield is an attempt to protect the engine mount near the exhaust head pipe. They are frequently like yours or just left off for various reasons but seem to me to be a good idea.
hrcollinsjr is online now
Tags
what is it
