#26 (permalink) | |
crazy opeler
HMMMM.... I never noticed that. I have done a few motors and must have been lucky. Or it didn't matter. Either way it seems you could swap them and get slightly more clearance for say a pair of webers, because it would move the motor towards the driver side. I don't think it would rotate the motor that drasticly either. The only interferience I can think of is if you are using the stock fan shroud. EDIT: after thinking about it, the motor would move to the drivers side and up ever so slightly, but there would be no rotation. Last edited by opelgt73; 07-27-2005 at 10:38 PM.. |
Chris
Indianapolis, Indiana |
#27 (permalink) |
I'm running dual 40DCOE's and I'm trying to get a 5 degree angle for my webers. With the engine tilting so much the Webers are tilting downward. I've attached a photo from a Weber Carburetor book showing what I'm talking about. I've had to add a spacer under the passenger side motor mount to achieve this.
Trent |
#30 (permalink) | |
#31 (permalink) | |
#32 (permalink) | |
crazy opeler
Chris
#33 (permalink) | |
#35 (permalink) |
4246 Post Club
Good Question ..... !
I have one GT motor and I took the brackets off to paint them ....... really would like to know which one goes on what side myself.
Think the brackets must be a bit "off-square" to allow for the engine tilt so guess that by checking the brackets with a square it should be obvious - I 'll try that next. RATS!
#37 (permalink) | |
#38 (permalink) |
opel free after 25 years
if the engine is not mounted in the correct plane the drive shaft output will not be on the same angle both in vertical and horizontal planes , this will result in wear on the hardy splicers (the 2 universal joints ) in the prop and result in a failure of said joints ,they are made to work in a straight line and when they need to off set they can only do this i 1 plane not 2 as it twists the bearings inside and stresses the yokes
it normally takes me a week when fitting a different engine to be happy that i have both output face and axle face exactly right if the nearest i can get the output face to vertical is say 5° from vertical then the input to the diff or torque tube has to be 5° to match ,only this way will the prop last and take heavy use without brakeage |
#39 (permalink) | |
Engine mounting axes (planes)
#42 (permalink) |
OPEL-LESS!!!
if memory is serving me well today, i seem to remember that the driver side engine mount bracket has a part of it machined flat for the battery cable holder (lack of better terms on so little sleep). i should go in the garage and look but too lazy. but i think theres a flat machined part on the drivers side braket where the hole is drilled for the engine mount stud, and is only present on drivers side, not pax side.
currently own 92 25th anniversary Z28. Ttop, 350, T56 swap, many upgrades, basically a complete restore. 67 chevy sportvan deluxe....next in line. |
#43 (permalink) |
4246 Post Club
Left Side
Here is a picture of a LHSide (Drivers side!) GT engine mount bracket. The hole is closest to the block on this one and further away on the passengers (RH) side. The brackets are "square" so any angle must be taken up by the rubber damper. So the GT engine is moved to the left - but leant over to the right side. I think this was mainly done for carburettor clearance, so standing the engine back up square and moving it as far left as possible should give more room for twin side draft Webers .... food for thought!
