73 split taillights
I have a 73 GT with the taillights that are on the manta. OGTS only has the all red and all amber replacements. Does anyone know where to get new orange and red taillights? Still waiting on internals to show up, so I need something to do.
4246 Post Club
New ones may be a bit hard to find but real nice ones do turn up on eBay from time to time. The other options are to try Germany or the UK as I think they used the same lights after 1973 on Mantas.
Susselbeek in Holland may be worth a try too at www.opelgtparts.com |
1969 GT Turbo
If you get stuck, I've probably got a few sets in the shed somewhere.
Its funny that a US GT owner wants the Manta style lights, when I converted my Manta to run GT ones. Like I said, if you get stuck, I can see how many I have. You want all 4 or just the brake/signal ones ? |
1969 GT Turbo
1971 Manta V6 Kompressor Lake District, UK |
I had 2 1973 GT's. One had the split lights and the other had the solid lights. Both were stock, I believe the early 73's had solids and the late had splits. I always liked the split lights and wanted to find another pair. Now I prefer the solid lights, simple and clean look. In the GT I use for my Mid Engine conversion, I would like to use a combination of the 2 types. I would use the Orange solid on the outside and the Red with the white reverse lights in the center. I will be in need of the Red/Reverse lights and lenses.
69 GT Blue/blk 1.1 4-spd
70 GT Yellow/blk 1.9 4-spd 70 GT Blue/blk 1.9 4-spd 70 GT Yellow/blk 289 auto 71 GT Black/blk 1.9 4-spd 71 GT Yellow/blk 1.9 4-spd 73 GT Blue/wht 1.9 Auto AC 73 GT Gray/blk 1.9 4-spd the above are PREVIOUSLY OWNED Currently, 72 GT primer/blk 1.9 4-spd |
1969 GT Turbo
But I've a few spare sets here in the Uk of anyone needs any. |
1969 GT Turbo
Yeah azzi thats cool. The reason I like the splits is when anyone that really knows Opels sees the car they can pick its year. And they look really cool! I wasn't sure if they could be cleaned up,they are real cloudy and the bottom screw holes are broke on both. But any help would be greatly appreciated.
#8 (permalink) | |
PrOpeller
#9 (permalink) | |
1969 GT Turbo
Anyone thinking of changing their rear lights need to remember to get the backs too. The rears are NOT interchangable as the diameter of the lense and the rim are slightly different. I.E. a GT lense will not fit on a Manta rear. (I know the later GT's had the splits also, but to avoid confusion I'll just quote Manta and GT) Basicly there are 4 different rears and lense types. Opel GT Yellow = Single filament bulb holder in center Opel GT Red = Double Filament Bulb Holder in Center Manta Split = Single filament bulb holder top & Double Filament Bulb Holder bottom Manta Reverse = Single filament bulb holder in center The Manta Split has a metal shield horizontaly through the middle to seperate the light beams. The Reflector area on the Manta reverselight area is not opaque, so you couldn't get a bulb to shine through anyways. As the Manta and the GT backs to not interchange, you may end up just making you own backs up if you need to customise them. Last edited by azzi; 01-10-2005 at 10:50 PM.. |
1969 GT Turbo
Now I'm unsure on what will fit. My GT's Taillights are amber on the top, red on the bottom, with a one filament bulb on top (turn signal) and a double filament on the bottom (driving and brake). The inner reflector and reverse light, I think has a light in the clear center. I think theyre factory but I've only had it 1/30th of its life. If not looks well done.
#11 (permalink) | |
1969 GT Turbo
chaging the subject slightly, did anyone get any of Destec's LED rear lights? How did they fit and what rears did you have to use (if any) |
1969 GT Turbo
Opelitis since 1984
I just got a NOS set from Europe for my Blue Max. I think I got some of the last ones available. The Red/Amber lense set was NOS, one of the Red/White wer NOS, the other extremely nice used (hard to tell it wasnt NOS). I got it from my supplier who specializes in Mantas.. so if he is going of stock on them.. that should tell you something.
Charles |
'71 Opel Kadett 4 Door 36D
Blown motor = EV Conversion? |
L.E.D. Tailights
Azzi
I got one of the first sets of L.E.D. tailights from Destec for my 72 GT. They work great, very bright and were very easy to install. To get the full brightness, it is better if the engine is on so they get the full 14 volts. It really cuts down on amperage draw. You will have to modify the turnsignal flasher since that works on amperage. On a Manta, it may act like you have a burnt out bulb and flash a the quick rate. On the GT you get the double green on the dash, but the instructions give you a few options on how to eliminate it. Destec is very knowledgeable(sp) and should be able to help you out. Jeff |
2001 Saab 9-5 SE 3.0 Turbo V6 Weeeeeeeeeee!!! 1973 GT, Parted out, R.I.P. 1968 Kadette, Owner since 2006, Sold, 28 June 2008 |
i used the manta's reverse lenses as blinkers... i just put an orange bulb inside, and the tailight/brake lens is like a GT red lense with one double bulb in the middle... allways hated those split red/orange lights.
maybe the indicator is a little too bright... but compared to some new cars, its just right. |
