Alberta Opeler
Unanswered: Combo Switch Needed
Perhaps this should go in the Parts Wanted section but I need some views. I need the FOG LAMP/BRAKE/FLASHER switch for my 70 Kadett Rallye. The back of the switch has 11 contacts and the critical one that has to be on the back is 54F in the upper left corner. The other contacts are: S49a R 30 L +49 15 31 S N 15 The Flasher Switch must be free and easy to move. Thanks, Ray Morley |
Fog light switch wiring . . .
Alberta Opeler
Hi Otto:
Since I have the Rallye the Fog Lamps are already on the vehicle and wired in. This part of the switch is not causing me the grief. What happened is the FLASHER switch was selected ON and then jammed in the ON position. When I carefully tried to select it OFF it did go to the OFF position but the lights remained flashing. The switch does not have the on/off function anymore. I had no problem isolating the wire to prevent the flashers from flashing but that inhibited the turn signal funtion. Ray |
Alberta Opeler
Here are some pics of the unit. Actually this is exactly what the front and rear of the unit looks like except for the back.
If you look at the upper left corner you can see where I have applied a small piece of masking tape. This is the location of 54F which this switch I am using for the pics does not have. The switch I need must have this connector spade. |
UngerDog
The unit I have from a GT is different. I'll try to post them here for reference. Sorry, Jerry
Attachment 10510 OpelGTby JU 002.jpg Last edited by ungermm; 10-19-2006 at 07:57 PM. |
Yes, it does work, in fact it goes in either position with a loud click. Yes, it can be bought.
Alberta Opeler
Here is my email: rayemorley@yahoo.com
Please send me an email with your address and the price (plus postage) you would like and I will send you a Bank Money Order in US Funds. Are you looking for anything? |
