Unanswered: Kadett luggage rack
I would appreciate it if anyone can tell me how to remove the front or rear bars. The metal polisher will not do the rack unless I break it into smaller pieces. Thanks in advance for your help |
#3 (permalink) | |
yes Gary
LOVE to do restorations it is so rewarding when it is finished. I am going to the shop now to use PB Blaster and a propane tourch on the small set screws that hold the "collars" on the side rails (they do not want to turn, broke one small screwdriver tip off so far) , and to drill out (grind off) the pins on the rear that should release the backside rail. Once that is removed and the collars are loosened they should slide off. Having never done this before I hope I am guessing correctly
Last edited by tekenaar; 01-26-2008 at 04:08 PM. Reason: wnat . . . any relation to a gnat ;-); quessing |
![]() ![]() Provided Answers: 11
got it apart
Mine is different off a 1970 Kadett wagon. Getting it off the roof was not the problem that was easy It is actually at least 4 pieces and not easy to disassemble I did manage to get the 4 rails apart without damaging them too much The part that is hard to remove from the rails is the bracket that holds it to the roof. The set screws are not coming out not with PB Blaster not with heat just frozen in there too much. Broke 3-4 bits and gave up. I got one off before I quit trying. In any event the polishing company will have 4 pieces to work and they should come out with a mirror finish. |
