Unanswered: 1969 Kadett Rallye restoration 95% done!
Great looking car. Enjoy it.
Pete
* * * * * * * * * * * * * * Pete Anastopoulos www.anastosmotors.com info@anastosmotors.com * * * * * * * * * * * * * * |
#3 (permalink) | |
One small safety related comment on the fuel line feeds to your carb - two blocked off, one actually supplied from the pump. As shown in your third pic and even though low pressure, not sure if those two blocked off inlets are properly "secured" at their bowl inlets . . . don't think you should rely on those two "push on" caps to stay on without some sort of clamp! You'd certainly never be allowed to "compete" at any level of sanctioned racing with the way it is now, but it's not safe in ANY use of the car!! I'd hate to see this wonderful car destroyed by an engine fire!!!
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 07-29-2009 at 12:32 PM. |
VERY observant!! The fuel line is not hooked up yet, I need to adjust the valves, put the fuel pump on and run the lines to the carb and it's ready to start.
I am going to put a Y in the line and connect both inlets. I bought the carb on Ebay and didn't notice it had both inlets. Believe me, after all this work caution is putting it mildly when I work on it. Terry |
Opelitis since 1984
Real Name: Charles Goin
That is absolutely sick.. I wish I had the time and patience to make mine look that good.. !
Fantastic car and garage!!
69 Rallye
Ever with all the work done, you should be proud to display that one anywhere. It looks better than new, and the upgrades you have made I'm sure makes it run better than new. That is one of my favorite models and is one tough unit. Kadetts are nice drivers, very simple to work on and while it does not handle as well as a Manta or Ascona it can hold it's own with anything it's age.
Just plain beautiful. Did you have the Rallye stripes painted on or go with the stick on vinyl? If painted, did they paint them on after the red was all painted?
PS- I don't think that is his garage...he parks that nice of a car in his KITCHEN!! |
WOW, that is SWEEEETTT. Enjoy the ride
#14 (permalink) | ||
So, NO unscrewing inlets here, I'm afraid!
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 07-30-2009 at 12:57 PM. |
. . . but that's what sets it apart from the ordinary.
Ever since I bought my low-mileage Kadett in Seattle, I've never really liked the haphazard factory heater-hose routing . . . it's almost like an afterthought on Opel's part! Looking at your engine compartment pic, I'd like to suggest a more "organized" heater-hose routing that uses your existing hoses but eliminates that haphazard heater-hose clutter in the engine compartment. The re-routing is primarily this: 1. A straight section of hose between the T-stat nipple and the passenger-side heater core inlet . . . 2. A straight section of hose along the same path of #1 to one heater valve inlet directly above the #1 heater core hose connection . . . 3. A short 90° hose section from the remaining heater valve nipple, behind the engine valve cover, to the driver-side heater core inlet . . . You could then support these parallel hoses at the side of the valve cover, one above the other, with two different length original Opel hose support brackets . . . perhaps even chromed! First pic is my Kadett heater-hose routing, like yours, as purchased originally . . . Second pic is my annotated, revised Kadett heater-hose routing . . . just a suggestion!
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 07-30-2009 at 12:53 PM. |
#16 (permalink) | |
#18 (permalink) | |
Terry |
#20 (permalink) | |
#23 (permalink) |
I doubt it will Roy, I'm picking it up on Labor Day weekend, it might, but it will be close
Keith
#24 (permalink) |
Real Name: Roy Bell
Yea... He told me you were going to be "finishing" it up and it would be close. But if not there this time, definitely in the Spring!!!
