#26 (permalink) |
Kick a little asphalt
I had a nice set of Cibie 175 fogs that would have worked great for you. Unfortunately, I sold them on ebay about 5 months ago. I have often thought about getting the clear bubble protectors for the headlamps. I'll check into Opposite Lock. Thanks for the tip! Duane
"The bitterness of poor quality remains long after the sweetness of low price is forgotten" |
#27 (permalink) |
Otto,
Your Kadett has a multiple piece finishing panel? My wagon has one big piece that goes all the way accross the car under the dash. It is black plastic with sound deadening material attached to the backside of it. Most people threw them out as they made it a PITA having to R&R it to work on anything under or behind the dash. Duane
#28 (permalink) |
Duane;
I take it the Kadett we saved doesn't have this panel? It is tucked away in a barn right now awaiting its next owner. Remember, this car is free!(shameless plug and off topic )Does the generator bog down when you turn these on ??
#29 (permalink) |
Opel Adventure # 77 NC
Real Name: Kevin
My Kadett is a 69 wagon 1.1SR w/AT. It was all original w/16k on it when I picked it up in San Diego 10/04.
I am in the process of installing an Irmscher SSD intake w/ DCOE40 .Should make it a Silver Bullet. Duane, the 70 sport sedan that I sold to Gerry Newburg has the under dash pannel still. |
#30 (permalink) |
Real Name: Gerry
more Kadett wagons
I have 3 Kadett wagons.69,69parts and 72. Two still have the panels. They are not very easy to remove without damage. Very awkward because of it's size and shape. And yes, Kevins car has it still.
Gerry |
#31 (permalink) |
Real Name: Allan Wheeler
Kadett wagon
I myself have a 1970 kadett wagon with 14k original miles(garaged since 1976) on it...interior is flawless besides the headline (usual tiny splits with age) I just put a new motor in it with weber. needs MC and a vaccum modulator to make the trans shift. Other than that it is a perfect example of an genuine opel kadett wagon.It is white with red interior. ABSOULTLY NO RUST ANYWHERE! Even has the vintage smell. Clock works perfectly along with am radio. With that being said...I dont really need the wagon as I may be getting out of opels for a while. Being honest I could use the money too. Anyone intrested?
73 Gt (RIP), 4 speed, 2.0L, 290H cam, weber, S-10 clutch w/ matched flywheel, sprint to a 2" pipe, Aluminum finned oil pan. SOLD! 70 Kadett Wagon 14k, 1.9L, Auto, weber |
#32 (permalink) |
Jeff,
No, the coupe was missing it when I got it. Kevin & Gerry, I guess there are more of those panels still in cars than I thought. Beta Carotene, Pics, price and details please. Thank you. Duane
#33 (permalink) | |
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 04-11-2006 at 01:12 PM. Reason: corrected panel number |
#34 (permalink) | |
. . . I mean before it goes to junk yard!
#35 (permalink) | |
Thinking about fabricating a cold air intake for it? A few horses added to the 67HP already there have much more impact than on a higher HP engine. Just do it . . . almost free! Modifying the original linkage to work with the SSD or starting linkage fabrication from scratch? Just curious as I'm going through a bit of linkage fabrication on my Kadett myself . . . twin downdraft DFOs with an original Rekord Sprint air cleaner . . . if I can get it. Of course, then there's still the vintage ARA A/C evap and interior ductwork to install and the vintage Blaupunkt 4-band mono radio to install . . . all 'period correct'.
#37 (permalink) |
Otto,
I also have the grey piece above the pedal box but, mine is a grain textured cardboard type of material. My black plastic piece is all one unit. One thing I have been seeking for a long time is the rubber bullet shaped end plugs that cap the rear of the roof rack tubes. Would anyone have one of these? Duane
#38 (permalink) |
Kadette
1100 Kadette can be made into a really fun vehicle to drive. You just have to remember it is an antiquated design and with 3 main bearing and pushrods you can't spin them but so fast. I have seen an SR (67HP) show 82HP with just a little modifacation, that like making 150HP in a 1900. Re-curve the distributor, re-grind the cam and open up the exhaust. Tweeking the carbs and a little head work will work wonders for that motor. I had a 65 Kadette with a 1200 (european) parking lot racer that made many a MG midget and Spitfire wondering what got into that thing.
#39 (permalink) | |
2.2 enough?
#40 (permalink) | |
Allan
#41 (permalink) | |
1970-GT
I remember those when I was a kid, my neighbor had one, always liked them. My Dad had a Buick Estate wagon with a 455 and it weighed over 5,000 pounds, until the gas crisis hit! Then he bought a 74 Opel Manta Luxus. I was looking for something that I could do small deliveries with, gets good gas mileage and an Opel would be a plus! The 1900 would also be a thought. Lyle Last edited by tekenaar; 03-22-2006 at 11:43 PM. Reason: it's Luxus - DeLuxe |
#42 (permalink) | |
Bob |
#43 (permalink) |
MantAscona, as long as you are asking, I think it would look great with a row of them big lights across the top on the front of the luggage rack! Sort of like on a LandRover.
Steve "ever notice you are never done tinkering with the GT?" Never mind, I am WAAAY beyond tinkering now...[/SIGPIC] |
#44 (permalink) |
Real Name: Gerry
I know that this is somewhat off the main subject of Kadett wagons, but does anyone know of a source for the bulbs for the Kadett factory fog lights for the Rallye. I was told that they are hard to find. Or, can one use other bulbs in the housing without changing the wiring or relays dramatically?
Thanks, Gerry |
#46 (permalink) | |
Special
I am searching for some original bulbs too - found a second set of lights and brackets on EBay - plus a set of 2 Cibie 'Oscars' and two Cibie 'Super Oscars' mounted upon a light bar fell into my lap recently. Guess I will need a 105 amp alternator to run them all - and a bigger motor.
#47 (permalink) |
Bob,
That would be great if it's doable. Don't kill yourself on it though. I know you have a lot of projects on your hands already. Thanks! Duane
#48 (permalink) |
Steve,
I think I would need an auxiliary generator to run them all if I did that. I could just put two up there and it would look like Mickey Mouse coming down the road. Duane
#49 (permalink) | |
#50 (permalink) | |
