24v Ascona Wagon Upgrade - Page 16
Page 16 of 16 FirstFirst ... 61213141516
Results 301 to 304 of 304
Like Tree254Likes
Thread: 24v Ascona Wagon Upgrade
  1. #301
    Swansea, MA
    8,988
    Gary
    4
    Had the wagon aligned the other day. I never set the toe after I rebuilt the rack and added new tie rods. All the other 'Before' settings were done with a plumb bob and tape measure.
    I reversed the right front upper ball joint to bring the Camber into spec.
    Next up, adding Cruise Control!
    www.alt-opel.us
    @opelgary
  3. #302
    Aug 2006
    Goderich, Ontario Canada
    2,684
    P.J.
    It always pays to align the wheels. The car handles better and the tires last longer.
    Especially with flimsy GT suspension, I like to do it every 2-3 years. I don't care about alignment by string and similar shade tree mechanic methods. For $110 what they charge for front and rear alignment, I save 100s of dollars worth of my difficult to find tires. Well done Gary.
  4. #303
    Swansea, MA
    8,988
    Gary
    4
    Cost me $65. I was a little hesitant about bringing it to that shop as my good friend who did the alignments there had retired. The "kid" who did it was pretty sharp and he said that it was "So nice to work on a custom instead of doing a run of the mill alignment".
    www.alt-opel.us
    @opelgary
  6. #304
    Swansea, MA
    8,988
    Gary
    4
    Cruise Control is in!
    Had a minor issue with the charging circuit on the 3-wire mid '90's GM alternator. The "idiot" light was staying on but the voltmeter showed ~14 volts when running.
    The way that light works is one lead is connected to a switched source and the other to the "L" wire on the alternator plug. When the key is turned on, 12v flows through the lamp to the alternator and grounds there. When the alternator is spinning, 12v comes out of the "L" wire and the lamp goes out as there is no longer a ground. No output from the alternator = lamp on.
    I only had 3.4 volts coming out of the "L" wire and there was some discoloration on the plugs terminal which could be from high resistance due to a bad connection. Digging a little deeper on the 'net showed that alternator works best with 35-350 ohms resistance in that circuit. I replaced the stock bulb with a neon lamp and the resistance was only ~14 ohms.
    I installed a new plug and ordered a 50 ohm, 5 watt resistor from eBay. ($9.00 for 10, boy, do I miss my local Radio Shack)
    Stay tuned...
    guyopel likes this.
    www.alt-opel.us
    @opelgary
    1. Ascona Brake upgrade
      By Gary in forum Performance Suspension and Braking Upgrades
      Last Post: 09-22-2016, 01:34 PM
    2. Wood grain on Ascona wagon......
      By Aardvaark (R.I.P.) in forum Ascona (1900)
      Last Post: 02-16-2009, 08:53 PM
    3. Phase I of wagon interior upgrade
      By michaedo in forum 2B - Seats, Windows and Interior trim
      Last Post: 11-14-2008, 10:03 AM
    4. Ascona Suspension upgrade
      By hrcollinsjr in forum Ascona (1900)
      Last Post: 05-29-2006, 04:02 PM
    5. weights of Kadett, Kadett wagon vs the Ascona, Ascona wagon?
      By Betta Carotene in forum Kadett A/B
      Last Post: 08-25-2005, 11:19 AM
