24v Ascona Wagon Upgrade - Page 3
Page 3 of 15 FirstFirst 123456713 ... LastLast
Results 41 to 60 of 296
Like Tree237Likes
Thread: 24v Ascona Wagon Upgrade
  1. #41
    Swansea, MA
    8,923
    Gary
    4
    First cut is the deepest!
    RallyBob and Team Unter Puff like this.
    www.alt-opel.us
    @opelgary
  3. #42
    Swansea, MA
    8,923
    Gary
    4
    Shifter location could get interesting!!!
    www.alt-opel.us
    @opelgary
  4. #43
    Your Noble Friend ;-) My location G.v.Mainberg's Avatar
    Nov 2004
    Atlanta, GA - USA
    3,287
    Gary,
    are you sure you had it underneath the car the right way when you mocked up the cuts? I don't want your Wagon to go backwards once it's done!
    Dieter
  6. #44
    Swansea, MA
    8,923
    Gary
    4
    Quote Originally Posted by heimue View Post
    Gary,
    Dieter
    You mean it is not front wheel drive?
    www.alt-opel.us
    @opelgary
  7. #45
    Swansea, MA
    8,923
    Gary
    4
    Progress!
    Steps: Measure, measure cut... Measure cut... Screw it, just cut!
    www.alt-opel.us
    @opelgary
  8. #46
    Swansea, MA
    8,923
    Gary
    4
    More Progress
    The front suspension is in and the motor is resting on the front mounts. So I was able to get some accurate dimensions for the driveshaft, shifter, engine height, etc.
    It is ~23 inches from the Guibo joint to the torque tube. The '90 Senator driveshaft is a 2 piece unit with a center support. There is a spline at the center support that will take care of any lateral movement so the front shaft will need to be shortened and the piece from the rear u-joint will be mated to a cutdown Ascona d-shaft.
    The shifter mounting holes are right at the e-brake handle so it is going to be tight. Everything clears the e-brake, but I might have to shorten the e-brake handle. The R-25 is similar to a Getrag shifter
    The motor is sitting higher than I would like. I built up the motor mount brackets to clear the steering shaft and now the motor ends up just below the hood's bottom. So it will be rev.3 for the motor mounts to lower and clear the steering shaft. There is plenty of oil pan to crossmember clearance. The sway bar was eliminated so there was no interference at the rear of the motor. I was using Chevy poly tranny mounts for motor mounts.
    Clutch/brake pedal assembly will fit with minor mods to the battery box area. (The battery will be moved to the rear) The clutch master cylinder is attached to the pedal arm so it stays inside the drivers compartment.
    The Scifi Guy likes this.
    www.alt-opel.us
    @opelgary
  9. #47
    Swansea, MA
    8,923
    Gary
    4
    Motor Mounts
    Revision 3 of the motor mounts consists of a 8" x 5", 1/4" plate bolted to the block at the stock bracket location and holes drilled in the front part of the plate match the mount bracket holes. This puts three quarters of the Chevy trans mount I am using as a motor mount over the mount bracket on the crossmember with one inch fan blade clearance.
    Most of the weight will now be on the crossmember and the block will be around 1 inch lower from the rev. 2 brackets.
    Pics to follow.
    RallyBob and The Scifi Guy like this.
    www.alt-opel.us
    @opelgary
  10. #48
    Swansea, MA
    8,923
    Gary
    4
    Yeah! The flat head socket cap screws I ordered from McMaster-Carr will be here tomorrow! Mount bracket work will continue over the holiday.
    www.alt-opel.us
    @opelgary
  11. #49
    Swansea, MA
    8,923
    Gary
    4
    Here are some pics of the engine bracket plate, crossmember to mount adapter plate, assembled motor mount, and the rear tranny mount. The last pic shows how much the sway bar would have interfered with the oil pan.
    Just need to make two engine bracket plates and that will complete the 'easy' stuff!
    www.alt-opel.us
    @opelgary
  12. #50
    Swansea, MA
    8,923
    Gary
    4
    Two detailed updates made to the Project Blog: 24V Ascona A Conversion
    Comments welcomed here and on the blog.
    www.alt-opel.us
    @opelgary
  13. #51
    Swansea, MA
    8,923
    Gary
    4
    Finished the mount bracket plates today and the motor and trans are in place.
    Next up is the clutch/brake pedal placement, then shorten the gear shifter. Sheet metal work will follow.
    Single digit temps tonight and over a foot of snow predicted by Friday night. Below zero (f) tomorrow night. Glad that I have a heater in the garage!
    www.alt-opel.us
    @opelgary
  14. #52
    Opeler samdog's Avatar
    Oct 2003
    boston
    345
    Very nice project Gary...very nice!
  15. #53
    Swansea, MA
    8,923
    Gary
    4
    Motor Mounts
    Here are the mount bracket plates installed. The drivers side was trimmed for knock sensor access.
    Team Unter Puff likes this.
    www.alt-opel.us
    @opelgary
  16. #54
    Swansea, MA
    8,923
    Gary
    4
    Ordered a 7 inch booster/master cylinder combo. The stock booster would not fit and one from a 1990 Senator was too large. While waiting for that I started on the 5-speed shifter.
    The shifter location caused a little concern as the stock location put it back near the base of the emergency brake handle. The linkage is very similar to the Getrag 240 setup. I made 2 "C" shaped brackets for the trans to shift lever connection and cut down the shifter base as much as possible. It moved it forward enough (~6 inches) so it is now close to the tip of the e-brake handle.
    The shifter was in and out at least 10 times before the alignment was set and the brackets welded together. Final assembly will be as soon as the paint dries.
    If it is too far back once the seat is in place, I'll have to make into a short throw or get creative with the shift handle.
    I'll post pics later.
    www.alt-opel.us
    @opelgary
  17. #55
    6,647
    Charles Goin
    5
    Man that thing is tight.. in all the ways you can use that term..
    Did you take some lessons from the Manta Dennis did years ago..?
    Looks really good though.. How much heavier is it than the stock setup..?
    CURRENT
    '74 Opel Manta - "Barbara"
    '05 Pontiac GTO
    In the past owned:
    '06 Pontiac GTO
    2 Bitters (#491/#439)
    '73 Commodore GS
    '73 Blue Max Manta Luxus
    & at least 20 other Opels
  18. #56
    Spofford, NH
    12,381
    Bob Legere
    Gary, if you need ideas on the e-brake hsndle, I shortened the one on my rallycar, but retained the push-button release. A little bit of work but not too bad.
  19. #57
    Swansea, MA
    8,923
    Gary
    4
    Dave Miller's Manta was part of my research, but ended up using very little from the work that Dennis did. (More room in a Manta's nose so the motor was not set back.)
    Not sure what the weight difference is. 2 extra cylinders, R-28 tranny is heavier, aluminum head, etc... Most of the weight is behind the front crossmember.
    Gary, if you need ideas on the e-brake handle, I shortened the one on my rallycar, but retained the push-button release. A little bit of work but not too bad.
    I was going to ask you for details on that Bob.
    www.alt-opel.us
    @opelgary
  20. #58
    Opeler My location SpringGT's Avatar
    Mar 2006
    Houston, TX
    1,038
    10
    Gary is it possible for you to relocate the e-brake handle location to the left side of the drivers seat like the Porsche 944? See picture.
  21. #59
    Swansea, MA
    8,923
    Gary
    4
    Quote Originally Posted by SpringGT View Post
    Anything is possible with this build.
    I think I can get away with shortening the handle. The e-brake housing clears the trans guibo. Here's a pic of the modified bracket and second gear location.
    That bend in the original was there for a reason. I had to shim the tower out to get 5th gear & reverse.
    UPS just dropped off my brake booster brackets!
    www.alt-opel.us
    @opelgary
  22. #60
    Spofford, NH
    12,381
    Bob Legere
    These might help.
    Gary and G.v.Mainberg like this.
    1. Ascona Brake upgrade
      By Gary in forum Performance Suspension and Braking Upgrades
      Last Post: 09-22-2016, 01:34 PM
    2. Wood grain on Ascona wagon......
      By Aardvaark (R.I.P.) in forum Ascona (1900)
      Last Post: 02-16-2009, 08:53 PM
    3. Phase I of wagon interior upgrade
      By michaedo in forum 2B - Seats, Windows and Interior trim
      Last Post: 11-14-2008, 10:03 AM
    4. Ascona Suspension upgrade
      By hrcollinsjr in forum Ascona (1900)
      Last Post: 05-29-2006, 04:02 PM
    5. weights of Kadett, Kadett wagon vs the Ascona, Ascona wagon?
      By Betta Carotene in forum Kadett A/B
      Last Post: 08-25-2005, 11:19 AM
