Vivian Revival - Page 2
Page 2 of 7 FirstFirst 123456 ... LastLast
Results 21 to 40 of 123
Like Tree81Likes
Thread: Vivian Revival
  1. #21
    Opeler Acofficer's Avatar
    Feb 2014
    conifer, CO
    71
    Jamie
    Bingo!
    Pertronix ignitor and 3 Ohm Flamethrower installed and boom, she fired right up and sounds great again. Old coil had water in it and was all rusty.
    The vac lines on my carb are going to distributor advance, charcoal canister, and egr.
    Sorry if I have a ton of questions but thats how I learn. So on to my next one. I ran a non resistor lead from fuse #3 to the positive side of the coil then hooked up the leads to the ignitor. I have no tach now. Before I do it and fry something, I assume the black covered wire goes to the Positive of the coil and the green wire from the loom goes to the negative post of the coil. Is this correct?
    1971 GT 1.9
    1972 Jeep Commando
    1975 International Scout II
    1976 Jeep Cherokee Chief
    1990 Jeep Wrangler
  3. #22
    Jul 2005
    Milner, GA.
    11,300
    Dan
    12
    Yawn
    let me know when the primary is .01 ohms
  4. #23
    Kid at heart
    Mar 2012
    Purgatory
    5,140
    Beelzebub
    Green wire is your tach and yes it goes to -. There is no EGR??? guess im wrong.. Did you eliminate clear resistor wire? Is this black one. Peel off to reveal clear?
    It is best to supply ignitor with its own 12v. Off the coil will fluctuate. Approx 9v
    Your vacuum lines of Carb still need work. Weber and solex are very different. Please look at link I provided above with vacuum line diagram. Where your y-tee off Carb should be one line going to advance. Line for Carbon canister goes to port on top of Carb near fuel inlet. Some are tapped with fitting, some not. If not either you can drill out port to float bowl and install a nipple for fuel line to carbon canister. You can also just leave it. Its function is for evap off of tank gets saved in carbon and sucked into Carb to be burned at start up and not to atmosphere.
    Long story short, at least get that Carb port doing what its supposed to. Eliminate splitter and carbon canister line for now. Essentially you have a vacuum leak through your CC right now. Looks like yours is threaded with a brass plug fitting in it now. Its right above your opposite side fuel inlet, that is also capped.
  6. #24
    Feb 2014
    conifer, CO
    71
    Jamie
    Thanks
    Frozen, Thank you sooo much for that reply. That is the type of info that really helps me learn.
    I will fix the vacuum lines tonight.
    As for the ignition. I wired the ignitor directly to the flamethrower coil as the instructions directed.
    My old coil had the black wire and clear wire on the positive (the wiring diagram shows the black comes from the starter, not sure what it does.) The negative had a green wire that y'ed, one green going into the loom and one going to the points.
    My new coil has a new full 12v to the positive, black to the positive and red ignitor. The negative has the green wire and the black to the ignitor.
    1971 GT 1.9
    1972 Jeep Commando
    1990 Jeep Wrangler
  7. #25
    Apr 2003
    Portland, Oregon
    6,688
    Quote Originally Posted by Acofficer View Post
    The clear wire is a "resistor" wire. It reduces the voltage going to the coil from the ignition.
    The black wire, connected to the starter, supplies a full 12v to the coil when your starter is cranking, adding a stronger spark in the starting process.
    If you eliminate the resistor wire and supply a constant 12v to the coil from the ignition then you will fry the stock coil.
    Your new coil should be set up to eliminate the resistor wire and the wire from the starter can be eliminates but it's not really necessary to do so. Those should be on the + side of the coil.
    On the - side of the coil should be the green wire from your points and the wire that returns into the loom, as before. The wire that returns into the loom is your tach wire.
  8. #26
    Feb 2014
    conifer, CO
    71
    Jamie
    Vacuum lines What is this??
    Ok, I ran the Charcoal cannister to the bowl vent. I hooked up the distributor advance to the correct port on the carb. My third hose comes from this thing. What is it? It is below and just in front of the carb.
    1971 GT 1.9
    1972 Jeep Commando
    1990 Jeep Wrangler
  9. #27
    Aug 2004
    Planet Earth
    1,490
    EGR valve.
  10. #28
    Jul 2005
    Milner, GA.
    11,300
    Dan
    12
    Oh now I see the rusty,crusty thing.
    Who else has run into this and what did you do?
  11. #29
    Kid at heart
    Mar 2012
    Purgatory
    5,140
    Beelzebub
    is there spcific years or models they are on?
  12. #30
    Feb 2014
    conifer, CO
    71
    Jamie
    egr
    I thought that was an EGR valve but after looking at the diagram you put up it said the EGR was only on 73-74. I don't see anything in my service manual about an EGR. Is it possible that mine is a 73 titled as a 71??
    1971 GT 1.9
    1972 Jeep Commando
    1990 Jeep Wrangler
  13. #31
    2000 Post Club My location poor gt (R.I.P)'s Avatar
    Mar 2011
    cincinnati ohio
    2,502
    Brad
    Most likely in the past someone switched the intake & exhaust manifold, or the whole engine
  14. #32
    Jul 2005
    Milner, GA.
    11,300
    Dan
    12
    Nope my '68 GT also had the valve.
  15. #33
    Feb 2014
    conifer, CO
    71
    Jamie
    Drove her for the first time
    I took her out and drove her around the neighborhood for the first time. She drives GREAT! I had a three phase plane for restoring her: 1) Mechanical 2)Body and Paint 3)Interior.
    I don't seem to have a lot of mechanicals to fix so I am moving on to the body work. I will take pics of damage on the passenger side and then chronical my trials and tribulations of fixing it. I may dabble in the interior as I go just to take a break from sanding.
    Any feedback on whether I should strip the entire body down to bare metal or not?? It has the origninal paint and what looks like a MAACO job over it.
    opelnut_1 likes this.
    1971 GT 1.9
    1972 Jeep Commando
    1990 Jeep Wrangler
  16. #34
    Feb 2014
    conifer, CO
    71
    Jamie
    Body damage
    Here is the major damage I have to fix.
    1971 GT 1.9
    1972 Jeep Commando
    1990 Jeep Wrangler
  17. #35
    Mar 2011
    cincinnati ohio
    2,502
    Brad
    outch, that will be fun
  18. #36
    Opeler My location SpringGT's Avatar
    Mar 2006
    Houston, TX
    1,050
    10
    Maybe someone on here with a parts car can get you a new door and quarter panel.
  19. #37
    Feb 2014
    conifer, CO
    71
    Jamie
    co parts car
    I did ask a couple of the Colorado guys but they didn't have one. I have definitely thought about cutting out the damage and welding in a new panel but till I find one I am going to try and pull it all out and use a hammer and dolly as well.
    1971 GT 1.9
    1972 Jeep Commando
    1990 Jeep Wrangler
  20. #38
    Opelnut opelnut_1's Avatar
    Apr 2003
    Colorado
    785
    Metal massage
    Seen worse worked to perfection try to work it out
    My Collection:
    69 Opel GT (Mystery Car)
    70 Opel Gt (First car)
    72 Opel Gt (Mostly Stock)
    87 Volvo 240 (Daily Driver)
    07 Volvo S60 (Daily Driver soon)
    07 CBR 1000rr (SPEED FIX Machine)
    65 F250 (for parts haulin)
    65 Fastback Stang (Sleeping Till Gt is back on the Road)
  21. #39
    Apr 2003
    Portland, Oregon
    6,688
    You should give Opels unlimited a call for a panel.
    As much as I feel that you would be dealing with the devil, sometimes you just have to buckle under and make the deal.
    If you are going to replace an entire panel, get a spot weld cutter. It will make the process much easier and cleaner.
  22. #40
    Mid-West Opeler My location sawdust's Avatar
    Oct 2006
    West Chicago, IL
    2,368
    Hans
    mine was a bit worse I think
    It was all pulled out, not by me, the Insurance paid for it.
    Message - Opel Photo Gallery
    Projekt 2017 - Der OPEL GT
    1971 Opel GT (Green) 10/28/06 VIN: 77 232 5469 Body U1032187 Build date: 10/70
    1972 Opel GT ..(Red) .05/11/07 VIN: 77 237 3202 Body U1049159 Build date: 11/71
    I am past the Age of knowing when I should know better
    Other Cars:
    2010 Fusion Hybrid (White)
    LINK to my picture Albums
