Vivian Revival - Page 4
Page 4 of 7 FirstFirst 1234567 LastLast
Results 61 to 80 of 123
Like Tree81Likes
Thread: Vivian Revival
  1. #61
    Opeler Acofficer's Avatar
    Feb 2014
    conifer, CO
    71
    Jamie
    sanded
    I checked the fit of the front screen today and made some minor adjustments. Thanks for the tip Anonymous. I worked for a few hours and finished prep sanding for the primer today. The DTM arrived yesterday so next step is to mask and lay the epoxy.
    1971 GT 1.9
    1972 Jeep Commando
    1975 International Scout II
    1976 Jeep Cherokee Chief
    1990 Jeep Wrangler
  3. #62
    Aug 2004
    Planet Earth
    1,490
    Recheck the structure around the front of the driver's side headlight to make sure it's round and allows the bucket assembly to rotate freely.
  4. #63
    Feb 2014
    conifer, CO
    71
    Jamie
    bucket
    The filler by the headlight was actually not done by me. I discovered it when sanding for primer. The buckets work perfectly. The filler there has a crack in it, so I will repair it after primer. It looks like it had quite a bit of body work done before the last repaint. I found repair panels in front of both rear wheel wells and behind both front ones.
    I hope to make it look factory fresh by block sanding the whole thing after the primer is layed.
    1971 GT 1.9
    1972 Jeep Commando
    1990 Jeep Wrangler
  6. #64
    Kid at heart
    Mar 2012
    Purgatory
    5,140
    Beelzebub
    wow, did you work at a body shop to pay for police academy?
    Fine work. fine name to. i go by Jamie with my friends.
  7. #65
    Feb 2014
    conifer, CO
    71
    Jamie
    body work
    Actually I am an Animal Control Officer. This is only the second car I have done body work on. My motto for working on cars is learn as you go. I read read read then give it a shot. This is the fourth vehicle I have done a restoration or build on. I know old Jeeps inside and out but this is a totally new adventure for me, and I am LOVING it.
    Here is a thread from my last body work job:
    Body Work Thread for the Siberian Express - International Full Size Jeep Association
    The paint on the jeep I did a single stage Acrylic Urethane. I am going to try a base/clear on the Opel. I am also going to dive into the world of powder coating so we will see how that goes as well.
    I try not to bore everyone on here with simple little steps but then again, thats how I learned, reading other people's step by step builds. I think showing the mistakes helps everyone as well.
    1971 GT 1.9
    1972 Jeep Commando
    1990 Jeep Wrangler
  8. #66
    Feb 2014
    conifer, CO
    71
    Jamie
    Progress
    Ok, some progress finally, other than sanding. She is officially in primer. I sprayed the entire thing with DTM epoxy primer from Eastwood.com. It went on really well. I had a couple of runs that I will sand down. Biggest lesson learned for the color, thin coats, don't worry about undercoat showing through on the first coat.
    sawdust and poor gt (R.I.P) like this.
    1971 GT 1.9
    1972 Jeep Commando
    1990 Jeep Wrangler
  9. #67
    Jul 2005
    Milner, GA.
    11,300
    Dan
    12
    Nice
    Next comes a light coat(skim) of black.
    And the fun really begins.
  10. #68
    Feb 2014
    conifer, CO
    71
    Jamie
    Rage Gold
    I have spent the last couple weeks laying down thin coats of Rage Gold. First time I have used this stuff. It is amazing. SOOOO much better than the cheap bondo stuff. After laying it, I sanded and shaped it with 80 grit. After the shape was perfect I used 400 grit. Then I filled the few pinholes with glaze.
    In the picture below you can see the almost finished product. The door and major damage are done and perfect. I redid on small spot on the flare that you can see is still green and not sanded yet.
    1971 GT 1.9
    1972 Jeep Commando
    1990 Jeep Wrangler
  11. #69
    2000 Post Club My location poor gt (R.I.P)'s Avatar
    Mar 2011
    cincinnati ohio
    2,502
    Brad
    Your getting there, I'm like you, I do thin layers at a time, speed has noting to do with it. Just a matter of , how much sanding do you want to do LOOKING GOOD
  12. #70
    Feb 2014
    conifer, CO
    71
    Jamie
    2nd coat of primer
    More progress this weekend. I finished all of the body work and sanding. I scuffed the entire car again and did a second coat of primer. Now I just have to wait for a good paycheck to buy my paint.
    1971 GT 1.9
    1972 Jeep Commando
    1990 Jeep Wrangler
  13. #71
    Feb 2014
    conifer, CO
    71
    Jamie
    small steps
    Finally I have made some small steps. I got my powdercoating operation up and running in the garage. Bought a nice oven for $40 on craigslist and wire it up to the same line my 220 welder is on.
    I powdercoated the exterior screens, the front bumperettes, and front amber light housings, Gloss black. I also purchased 4 bmw 320i rims and with brand new tires, Falken Sinceras, for $200. I sanded primed and painted one using VHT wheel coatings. I like the look but I am trying to decide what highlights I am going to put on it. I am thinking of painting the center ring of the wheel chrome or Fireglow orange (where the black is on the original). Here is a pic of the wheels.
    1971 GT 1.9
    1972 Jeep Commando
    1990 Jeep Wrangler
  14. #72
    Aug 2004
    Planet Earth
    1,490
    Will an Opel emblem be applied to the wheel centers?
  15. #73
    Feb 2014
    conifer, CO
    71
    Jamie
    opel symbol
    Yes. I am trying to find an opel center cap sticker that will fit. The center circle is only 2" or 50mm so I am having a problem finding one. I may have to custom order them.
    1971 GT 1.9
    1972 Jeep Commando
    1990 Jeep Wrangler
  16. #74
    Feb 2014
    conifer, CO
    71
    Jamie
    OGTS order
    I have literally looked at hundreds of gt photos and my plans have changed. I found that every picture I was drawn to had side skirts and front spoiler. After working a bunch of side jobs I saved up and ordered GT05 and LT05. Gil told me he thinks the body looks unbalanced with out the LT12 rear skirts so he threw them in for Free. Great guy, lots of knowledge. Just awaiting shipment then I will document the install of all three pieces in this thread.
    Still planning on painting it after in a Clear/base Fireglow Orange. Only thing I am still trying to decide on is if I wanna run a single black 14" racing stripe down the middle
    1971 GT 1.9
    1972 Jeep Commando
    1990 Jeep Wrangler
  17. #75
    Kid at heart
    Mar 2012
    Purgatory
    5,140
    Beelzebub
    yes skirts are cool, wish i would have done them too.
    racing stripes are dumb though. with the bump in the hood it just doesnt look right.
  18. #76
    Mar 2011
    cincinnati ohio
    2,502
    Brad
    Quote Originally Posted by Acofficer View Post
    I have had the double stripe & solid wide stripe down the middle also, but my favorite was an off set stripe on the drivers side to miss the bump.
  19. #77
    Feb 2014
    conifer, CO
    71
    Jamie
    stripe
    If I stripe it I am going down the middle but narrow enough to avoid the bump.
    1971 GT 1.9
    1972 Jeep Commando
    1990 Jeep Wrangler
  20. #78
    Opeler jayhawkjesse33's Avatar
    Jul 2006
    Avon, Indiana
    540
    Eric
    Dumb for you maybe...
    ...but I like it on mine man.
    But that's what this hobby is all about...personal expression and making the car your own.
    Eric
    poor gt (R.I.P) likes this.
  21. #79
    Kid at heart
    Mar 2012
    Purgatory
    5,140
    Beelzebub
    see now, yours looks cool, but put a divider line down the middle making it stripes versus stripe and i think it isnt nearly as cool.
    or is your stripes blue and the white is the middle divider. haha
  22. #80
    Jul 2006
    Avon, Indiana
    540
    Eric
    Good save my man! I wondered what your comeback was going to be. You know I'm down to clown with you on here anytime dude.
    Eric
