Saving my 2.2 (engine documentation thread)
Page 1 of 7 12345 ... LastLast
Results 1 to 20 of 132
Like Tree29Likes
Thread: Saving my 2.2 (engine documentation thread)
    Apr 2003
    Portland, Oregon
    6,395
    I just found out that my 2.2 needs a rebuild.
    It will be done using existing parts, new parts and remanufactured parts.
    Feel free to comment on the rebuild.
    Apr 2003
    Portland, Oregon
    6,395
    First off, I would like to know what the stock rod journal diameter is. I found two journals at 51.50mm, one at 51.48, and one that's 51.46.
    Is the stock diameter 51.5 or 52mm?
    The engine shows signs that it was rebuilt at least once.
    Aug 2006
    Goderich, Ontario Canada
    2,607
    P.J.
    I have attached page from Opel Service manual showing crankshaft journal sizes.
    Attached Files Attached Files
    Jul 2005
    Milner, GA.
    11,165
    Dan
    12
    The rod B/E bore 2.1653-2.1658
    Crank rod 2.0460-2.0467
  7. #5
    Apr 2003
    Portland, Oregon
    6,395
    That's what I was afraid of.
    It looks like this crank has been ground down .020 (.50mm) already.
    It definitely needs another grind.
  8. #6
    Swansea, MA
    8,911
    Gary
    4
    Are there any identifying numbers on the rod bearings that might show the undersize?
    www.alt-opel.us
    @opelgary
  9. #7
    Apr 2003
    Portland, Oregon
    6,395
    Just looked
    On one end,
    Clevite
    157
    The other end,
    CB1173AL
    0.50 K
    And that confirms my suspicion that the crank has been ground .020" (0.50mm)
    Gary likes this.
  10. #8
    Apr 2003
    Portland, Oregon
    6,395
    OK, does anyone know the full dimensions of the 2.2 conrod?
    I found a few H-beam rods but the dimensions don't seem to jibe with what I have in my hand.
    These are the dimensions of the ones I found that are closest
    Center to center length:
    141.5mm
    Big end diameter:
    55mm
    Small end diameter:
    22mm
    Big end width:
    24.8mm
    Small end width:
    24.8mm
  11. #9
    Spofford, NH
    12,377
    Bob Legere
    141.5mm
    Big end diameter:
    55mm
    Small end diameter:
    22mm
    Big end width:
    24.8mm
    Small end width:
    24.8mm
    2.2 rods are identical dimensionally to 1.9 rods. In fact they are the same as late model cast steel 1.9 rods.
    They are 128 mm long center-to-center, pin ends are 23 mm.
  12. #10
    Apr 2003
    Portland, Oregon
    6,395
    THis shows what a 2.2 noob I am.
    I saw the height of the piston/rod combo was different and assumed they just used 2.0 95mm pistons on shorter rods.
    I put the combo side by side with my 1.9 piston/rod specimen and see the pistons are the different component.
    This helps, and hurts less. I have a few extra 1.9 rods so that's no problem. Especially since the pistons are in great shape.
    So, the dimensions of a stock 1.9/2.0/2.2 rod are
    Big end - 55mm
    Small end - 23mm
    center to center - 128mm
    width - 24.95mm (garnered from measuring a rod from two different engines)
    Is this correct??
  13. #11
    Jul 2005
    Milner, GA.
    11,165
    Dan
    12
    A simple formula to keep in mind..
    Block height = 1/2 stroke + rod length + compression height
  14. #12
    Apr 2003
    Portland, Oregon
    6,395
    Does not compute.
    Does not factor the distance from the center of the wrist pin to the top of the piston.
    Unless that's an industry standard somewhere.
  15. #13
    Jul 2005
    Milner, GA.
    11,165
    Dan
    12
    Yepper
  16. #14
    Apr 2003
    Portland, Oregon
    6,395
    Yepper
    AH. I see now
  17. #15
    Spofford, NH
    12,377
    Bob Legere
    IIRC, a 1.9 and 2.0 have a compression height of about 1.771", while a 2.2 has a compression height of about 1.619".
  18. #16
    Jul 2005
    Milner, GA.
    11,165
    Dan
    12
    1.1 pin vs stock 1.9L
  19. #17
    Apr 2003
    Portland, Oregon
    6,395
    I will accept those numbers as they correspond, VERY closely, with my measurements. I'm not using the most sophisticated measuring devices so I have to have the +/- that fits within your stated measurements.
    OK, so I'm good on the pistons and rods, still.
    I just need to cross my fingers that I can have the crank machined in one pass.
    The main journals, so far, seem fine.
    P.S. I started rebuilding the head a week ago. Although it was never run with this engine, it was in about the same state of having been rebuilt before.
    I found really nice intake valves, good exhaust valves and a set of lifters that looked relatively new. One lifter was collapsed though, having been stored in a compressed position for a while. And, soft rubber on the valve seals.
    The one slightly worn lifter convinced me to pull it all apart, clean and inspect the guides, examine the seats, and lap the valves.
    I'll put in a new set of lifters and a combo cam because I have them on hand.
    I inspected the timing and found newer chain guides. The timing chain was one tooth off. This isn't a huge issue but will be resolved when I reassemble everything.
    I'm also going to check the gap on the rings. As long as I'm putting all this time into this thing I might as well check all my bases.
    Viny Charb likes this.
  20. #18
    Apr 2003
    Portland, Oregon
    6,395
    1.9 vs 2.2 pistons
  21. #19
    Jul 2005
    Milner, GA.
    11,165
    Dan
    12
    With used hyd. lifters we all ways collapsed them during a simple rebuild.
    Sometimes even took them apart and did some internal cleaning.....just sayin
    With a fresh valve job... well the lifters will need to readjust things a bit.
    Cool pic
    How much does that non-tapper pin weigh?
  22. #20
    Apr 2003
    Portland, Oregon
    6,395
    Cool pic
    Have no idea what things weigh at this point.
    The 1.9 is a low comp that's going to be tossed.
    The 2.2 is from the engine I'm doing in this thread.
    When I assemble things I will weigh them and do my best to match weight within 1 gram. I might even go a little tighter than that.
    1. A Call for SR20 documentation
      By bigben in forum Engine Swap Forum
      Last Post: 11-24-2016, 12:58 AM
    2. Saving A 1972 Opel Wagon
      By Ooooner in forum Member Projects
      Last Post: 10-11-2016, 01:13 PM
    3. My engine build thread.
      By First opel 1981 in forum 6F - Engine Rebuilding
      Last Post: 01-30-2016, 05:09 PM
    4. Should I bother saving my Opel Steelies?
      By First opel 1981 in forum General Discussions
      Last Post: 05-04-2014, 02:03 AM
    5. Saving Private Driveshaft
      By lowkey in forum 4B - Propeller Shaft and Central Joint
      Last Post: 01-29-2013, 11:40 PM
