The Old Hag - Page 16
Page 16 of 16 FirstFirst ... 61213141516
Results 301 to 304 of 304
Like Tree157Likes
Thread: The Old Hag
  1. #301
    Spofford, NH
    12,377
    Bob Legere
    Bob, I was just saying discard all of the dimension info for adjusting the clutch and do it based on the mechanical requirements of the system no matter what clutch or tranny that he has. This removes any unknowns in the system that may be thrown in due to different parts being installed. JMO
    Gotcha. The 4.75" number came about after testing. I kept adjusting until the release was correct, then measured that number, not the other way around.
    Really, the only factors that are variables are the flywheel thickness, pressure plate design, and the length of the throw-out bearing.
  3. #302
    Dec 2009
    Germany/Bremen
    2,629
    Norbert
    First of most failure is :The clutch pedal is no foot rest!
    Here is a picture from the result! And be sure, to push this arm you must have a foot
    like a mammoth. This arm was a real cable eater before I help a friend!
  4. #303
    Jan 2003
    Chapel Hill, TN
    7,753
    Harold Collins
    Clutch Problem - ROOKIE MISTAKE!
    After doing all that I knew to do, I revisited the adjustment. I've always adjusted the clutch by measuring the stud and never had any problem. With that being said I tried the 4.25" with no better results. You know, if you remove the clutch lever spring and lightly push the lever forward for the 4.25" measurement you wind up with a fairly light clutch pedal.
    guyopel likes this.
  6. #304
    Jan 2003
    Chapel Hill, TN
    7,753
    Harold Collins
    Bouncing Speedometer Needle Mystery
    I've had problems with the speedometer needle bouncing for some time and it whined loudly during the cold weather this winter. I finally got around to cleaning up and lubricating another speedometer which appears to have fixed the problem.
    I'm not sure what was causing the speedometer to whine but I believe I've figured out why the needle wasn't steady. Check out the broken speedometer drive shaft in the picture. Probably happened when I topped it out.
