The Old Hag - Page 3
Page 3 of 16 FirstFirst 123456713 ... LastLast
Results 41 to 60 of 304
Like Tree157Likes
Thread: The Old Hag
  1. #41
    Jan 2003
    Chapel Hill, TN
    7,753
    Harold Collins
    Quote Originally Posted by Ooooner View Post
    I don't know.
    Your horn was a dead short. Hey come to think of it, send it back I need it now.
  3. #42
    2000 Post Club GeorgeOpel's Avatar
    Feb 2013
    Kentucky
    2,254
    The brake system was upgraded with larger wheel cylinders and '75 brake calipers. Shortly after acquiring the car the brakes basically failed. I thought a line had possibly blown but it was a much easier and cheaper fix. The hose at the M/C reservoir was rotten and needed to be replaced!
    Why do people "upgrade", Opel GT brakes? My brakes need replacement but still work great stock
  4. #43
    Member My location guyopel's Avatar
    Feb 2003
    Duluth,Ga.
    1,229
    John
    Your car does not idle you do not need to upgrade brakes.
    Guyopel
    ---Thomas Edison
  6. #44
    Jan 2003
    Chapel Hill, TN
    7,753
    Harold Collins
    Quote Originally Posted by GeorgeOpel View Post
    Better brakes than stock, is usually a good thing. Second, Opel must have thought they needed improvement, otherwise they wouldn't have put larger front discs and pads on them in 1975.
    Why do your brakes need replacement IF they still work great??? I'm sure others would like to know as well.
  7. #45
    Jan 2003
    Chapel Hill, TN
    7,753
    Harold Collins
    Torque Tube Donut/Pinion seal replacement
    Another poly donut has failed and the pinion seal was leaking. I installed a new rubber donut and stiffened it up a bit sliding a fan belt in between the housing and the donut as others have suggested doing.
    The pinion seal was leaking so I replaced it as well.
    Can't catch a break. I finally got time tonight to install the torque tube only to have the bolt directly above the exhaust pipe strip. Looks like I'll have to drop the exhaust pipe to see what's going on. Hopefully a longer bolt will work otherwise I'm not sure exactly how I'm going to fix this newest problem.
  8. #46
    2000 Post Club My location poor gt (R.I.P)'s Avatar
    Mar 2011
    cincinnati ohio
    2,502
    Brad
    Harold, As for another, why ? first time I ever heard of this being done to the donut, Why not use the HD donut ?? Pic. please.......Brad
  9. #47
    Jan 2003
    Chapel Hill, TN
    7,753
    Harold Collins
    Quote Originally Posted by poor gt View Post
    I've installed three polyurethane donuts in the past few years. The first car sat in my garage for quite awhile. The donut cracked and looked horrible with zero miles on it over a period of time. The second I installed in a friends GT. I did it's first oil change a few years later and noticed the donut had gone bad with ~3000 miles on it. I installed one in a Manta cross member for SteveGT and haven't heard back from him on that one. Steve had previously installed one in Veronica and you saw the pictures of it in an earlier post.
    I have to thank Charles G. for letting me talk him out of the rubber torque tube donut that he acquired at Carlisle. As to the. "why did I insert a pieced of fan belt between the donut and it's housing?" It has been mentioned by a few members in other threads and I thought it sounded like a good idea. It should limit the amount of movement, limiting stress (I hope) on the component while still allowing it to do what it was intended to do - dampen drivetrain vibrations.
    Pictures? They won't be much as it is already installed but I'll see what I can do.
    Ooooner and poor gt (R.I.P) like this.
  10. #48
    Opeler jmbinjax's Avatar
    Mar 2005
    Canton, GA
    683
    John
    hmmm....I've had a poly donut in mine for 5+ years. Maybe I need to inspect mine. Of course I do drive mine and pretty aggressively. Maybe the secret is to actually drive the car.
  11. #49
    Senior Member My location SteveGT's Avatar
    Oct 2008
    Blairsville, Georgia, United States
    901
    Steven
    The one you did for my Manta looks just fine....as it's still sitting on a shelf in my parts room...on the list though...
    SteveGT
    poor gt (R.I.P) likes this.
    "71 Manta Rallye aka....BLKNBLU
  12. #50
    ggl
    ggl is offline
    2000 Post Club ggl's Avatar
    Dec 2008
    Norway
    2,589
    Goy Larsen
    We used to that all the time on rally cars here when the Ascona was still limited to using the stock rear axle housing. If there were 30 Asconas entered at least 29 of them had done this
    "I hate RallyBob"
  13. #51
    3000 Post Club blancojp's Avatar
    Oct 2005
    Acworth, GA
    3,088
    juan P. Blanco PH.D.
    Just weld the sucker and be done with it!
  14. #52
    Jan 2003
    Chapel Hill, TN
    7,753
    Harold Collins
    Quote Originally Posted by blancojp View Post
    I got a chance this evening to check out the weld nut that I stripped when I cross-threaded the bolt. An inconvenience but nothing that can't be overcome.
  15. #53
    Jul 2005
    Milner, GA.
    11,175
    Dan
    12
    Quote Originally Posted by SteveGT View Post
    So the next time that you busting my _all's over not installing the frontend grates..it's OK?
    chuckle
    hrcollinsjr likes this.
  16. #54
    Aug 2006
    Goderich, Ontario Canada
    2,610
    P.J.
    Matching holes on the torque tube bracket with the welded nuts on the bottom of the car can sometimes be a problem. It is even worse with the transmission bracket which often requires prying in order to insert the bolts properly.
    I replaced bolts with 10mm studs. Used red threadlock to keep them in place. That makes installation easy as the bracket slides right over the studs.
  17. #55
    Jan 2003
    Chapel Hill, TN
    7,753
    Harold Collins
    I had thought about doing this and you've convinced me that this is probably the easiest thing I can do especially if there is a next time.
    Thanks for the suggestion.
  18. #56
    Nov 2007
    Cöllingswööd, NJ
    9,474
    Gördö
    6
    Oh maaaannnn........you guys have all the cool mods!
    Dad gummit! Now I gots ta buy friggin' bolts what ain't gots no heads on 'em, so's I can keep up with you cool guys! Dad gummit!
  19. #57
    Mar 2011
    cincinnati ohio
    2,502
    Brad
    Gordon, I'm sure they will let play with the cool kids, but you have to ask you club president........Marty
    The Scifi Guy and MikeNotigan like this.
  20. #58
    Apr 2003
    Portland, Oregon
    6,422
    You know, since you always go that extra step on the mods, get a stud with an allen head so you can get the height just perfect.
    Just buy these and trim them down to size
    8039 Lot 5 10mm Thread Set Screws 5mm Allen Head 5 1 4" LGTH Free SHIP Cont USA | eBay
    The Scifi Guy likes this.
  21. #59
    Jan 2003
    Chapel Hill, TN
    7,753
    Harold Collins
    Almost 70 hrs./week between two jobs doesn't leave much time to work on anything, that and a +90° shop. Hope to get back to the Old Hag next week and get the torque tube mount done to suit me.
  22. #60
    Nov 2007
    Cöllingswööd, NJ
    9,474
    Gördö
    6
    Hey, pal, this website is about workin' on and fixin' up your Opel. We ain't readin' this here thread to hear you tell us how much you ain't working on yer Opel.
    I suggest gittin' yo saggy ole man azz out from under dat harvester and git it under da Opel.
