HC's 72 Project (I need help!) - Page 2
Page 2 of 5 FirstFirst 12345 LastLast
Results 21 to 40 of 82
Like Tree33Likes
Thread: HC's 72 Project (I need help!)
  1. #21
    Jan 2003
    Chapel Hill, TN
    7,753
    Harold Collins
    Quote Originally Posted by mschinelli3 View Post
    My car runs between 3-4 in most situations... idle and driving... I'm trying to figure out why its different for different cars... Hope this is a dumb question.. just trying to learn
    Bearing clearances, condition of the oil pump, pump pressure relief valve, oil viscosity, oil filter, idle speed, engine temperature, etc. affect oil pressure. To further confuse things, variations between sending units and gauges may give the appearance of different oil pressures as well.
    GoinManta and mschinelli3 like this.
  3. #22
    Aug 2002
    SW Missouri
    2,241
    speaking of oil pressure, I turn both oil pump gears around and use the unused gear surfaces to maximize oil pressure.
    TMK
  4. #23
    Jan 2003
    Chapel Hill, TN
    7,753
    Harold Collins
    Quote Originally Posted by tomking View Post
    Neat idea, but I have to wonder how much effect it actually has on pressure.
  6. #24
    6,647
    Charles Goin
    5
    New rebuilt motor with freshly polished crank and all new bearings..
    Thats why yours is so good.. :P
    CURRENT
    '74 Opel Manta - "Barbara"
    '05 Pontiac GTO
    In the past owned:
    '06 Pontiac GTO
    2 Bitters (#491/#439)
    '73 Commodore GS
    '73 Blue Max Manta Luxus
    & at least 20 other Opels
  7. #25
    6,647
    Charles Goin
    5
    I often look for a good used set of gears ( nice smooth teeth..), I have in the collection when rebuilding. That way there are fresh surfaces for the gears.
    That said you're in Middle TN, so finding any teeth is good, much less smooth ones.
    Ooooner and The Scifi Guy like this.
    CURRENT
    '05 Pontiac GTO
    In the past owned:
    '06 Pontiac GTO
    '73 Commodore GS
  8. #26
    Jan 2003
    Chapel Hill, TN
    7,753
    Harold Collins
    Too funny Charles. Being neighbors with W. Virginia, I'm surprised you even know the plural version of tooth.
  9. #27
    Jul 2005
    Milner, GA.
    11,175
    Dan
    12
    I can lend you my toothers...but I'll need them back!
  10. #28
    Jul 2005
    Milner, GA.
    11,175
    Dan
    12
    In a pinch you can flip the short gear around..just sayin.
  11. #29
    Living in the past opelnut10's Avatar
    Jan 2004
    Chesapeake, Virginia
    2,188
    Lloyd
    WEST VIRGINIA Riddle
    What is 10 feet long and has 8 teeth (answer) front row at family re-union photo session
    hrcollinsjr likes this.
  12. #30
    Jan 2003
    Chapel Hill, TN
    7,753
    Harold Collins
    Update on Blue
    Last week I decided Blue needed a tiny bit of lowering in the front. I had a lowering spring that had been removed from another car so no cost to me other than labor. I started early figuring I'd be done before lunch. Things progressed normally until I got ready to re-install the lowering spring which is usually easier than re-installing the original spring. After I fought installing the spring eyes bolts for a few hours it finally dawned on me that the spring might be hitting the lower ball joints. After removing the spring and doing a little grinding the spring went back in and the bolt holes lined up with little effort.
    The end result appears to be a 1/2" lower front end. I would have liked a little more but can/will live with the end result.
  13. #31
    Jan 2003
    Chapel Hill, TN
    7,753
    Harold Collins
    Fuel Gauge
    The fuel level sender in the tank had been rebuilt by OGTS when the car was restored back in 2004. Now that doesn't sound too bad but...... I removed the sender shortly after I got the car and cleaned the contacts up restoring a weak signal to the gauge. It would never read full and finally it quit working again. With two drivers using the car and two different driving styles there wasn't much way to keep up with fuel usage and I didn't want to get a call from the wife that she was out of gas somewhere so I decided to give the sender another go. Long story short, I "fixed" it, so I called OGTS the next day, Tuesday. I had a new VDO sender on the front porch when I got home Thursday night and shortly after that I had a working gas that I can trust.
    After seeing the corrosion on the sender contacts and the surface rust on the inside of the tank I may become a believer in some of the ethanol fuel treatments. And yes, I do have plans to remove the tank at some point to clean it up, hopefully before the next problem arises.
    The Scifi Guy likes this.
  14. #32
    Nov 2007
    Cöllingswööd, NJ
    9,474
    Gördö
    6
    I don't like to refer to those springs, as "lowering" springs, as though that was their primary attribute. Their greatest attribute is the increase in handling and performance, the lowering is just a side attribute, IMHO. I think the names Intermediate or Sport describe them better.
    Which would you prefer to be, Harold, a lowered dude or a sporty dude?
    Last edited by hrcollinsjr; 12-06-2016 at 09:48 PM. Reason: Updated dimension on quote
  15. #33
    Jan 2003
    Chapel Hill, TN
    7,753
    Harold Collins
    Well, I'm a "Sporty Dude" because I have a sports car with a manual transmission. At least I think I am.
    Ooooner likes this.
  16. #34
    Nov 2007
    Cöllingswööd, NJ
    9,474
    Gördö
    6
    Notice that I left out "Intermediate Dude".
    I guess that would mean that you're half a dude and half a............?
  17. #35
    Spofford, NH
    12,381
    Bob Legere
    Best part is the reduced arc of the new spring no doubt. Less arc means less side loading of the suspension bushings, which means the suspension binds less. All good....
    Last edited by hrcollinsjr; 12-06-2016 at 09:48 PM. Reason: Updated dimension on quote.
    guyopel likes this.
  18. #36
    Jan 2003
    Chapel Hill, TN
    7,753
    Harold Collins
    Tire clearance issues
    In trying to sort out the suspension I'm having a clearance issue with the right front tire rubbing the sway bar when turning hard right. My wheels are 7.5x15 with ET25 offset. 25mm spacers on the rear, I think this was mainly done for appearance. I want to use the same thickness spacers front and rear. No more than 15mm. I stacked approximately 10mm worth of washers behind the right front wheel, only slightly reducing the rubbing. Since I'm only rubbing on one side I'm wondering if the stops on the lower control are uniform or if one is bent. I'm considering filling in the worn places with weld. Any downside to this? Yes, I realize it may reduce my turning radius on one side. But then again it may equal them out. Either way I don't think it will be noticeable.
    The stop in the picture is on the lower right control arm. The left control arm stop seemed to be more worn maybe even bent.
  19. #37
    Jul 2005
    Milner, GA.
    11,175
    Dan
    12
    .. Since I'm only rubbing on one side I'm wondering if the stops on the lower control are uniform or if one is bent. I'm considering filling in the worn places with weld.
    I would only use JB quick set.
  20. #38
    Jan 2003
    Chapel Hill, TN
    7,753
    Harold Collins
    But I have a welder that I've barely used.
    P.S. JB Weld is some awesome stuff, but I'll pass on it this time.
  21. #39
    Nov 2007
    Cöllingswööd, NJ
    9,474
    Gördö
    6
    Are these the big OGTS sway bars?
  22. #40
    Jan 2003
    Chapel Hill, TN
    7,753
    Harold Collins
    I believe so.
    1. GT-R Project
      By rcthiemann in forum Member Projects
      Last Post: 10-14-2016, 08:17 AM
    2. My new GT project
      By wklopf in forum General Discussions
      Last Post: 08-02-2009, 11:51 PM
    3. My first project
      By Luckas in forum Introductions
      Last Post: 09-22-2006, 11:13 PM
    4. 2.0 Project
      By BetaCarotene in forum Opel Engine Performance Modifications
      Last Post: 02-13-2006, 07:58 PM
    5. New Project
      By Healy61 in forum Introductions
      Last Post: 02-14-2005, 05:29 PM
