HC's 72 Project (I need help!) - Page 3
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 82
Like Tree33Likes
Thread: HC's 72 Project (I need help!)
  1. #41
    Aug 2006
    Goderich, Ontario Canada
    2,708
    P.J.
    I had the similar issue with my 15x10 rims. Rather than welding or modifying stops, I added split collar on each end of the steering rack. Installation was easy, it just required temporary removal of the clamp on the wide end of the rubber boot, so I could roll back the boot and get good access to the steering rack.
    GT is small car with already tight turning radius, so the reduction of steering angle is hardly noticeable.
    John B likes this.
  3. #42
    Jan 2003
    Chapel Hill, TN
    7,795
    Harold Collins
    Neat idea, I'd have never thought about that. Waiting on the shop to warm up now. I'll probably fill the notches worn in the stops with weld. Hopefully restoring them to near original specs gaining clearance or at least reducing the need for thicker spacers.
  4. #43
    Calgary, Alberta, Canada
    4,985
    5
    Would you happen to have a photo of that PJ?
    Working on the bare-metal, nut & bolt rotisserie restoration of my '71 Opel GT, and may have another GT to build next...
  6. #44
    Jan 2003
    Chapel Hill, TN
    7,795
    Harold Collins
    Steering stop deviation?
    Assuming, which can get oneself in trouble, the steering stops can be 'altered' from there original configuration creating the ability to turn shorter in one direction than the other. Also creating a variation in tire clearance from one side to the other. Thus a non-OE part being rubbed on one side but not the other. I welded the offending stop this morning with some success. The tire appears to have clearance now when turned full lock to the right.
  7. #45
    Jan 2003
    Chapel Hill, TN
    7,795
    Harold Collins
    Heater and thermostat relationship
    I've received two texts from my wife wanting me to ask PJ what modifications he has done to his heater. I noticed the engine temp has been really low in the cooler weather this fall. Hopefully replacing the 160° thermostat with a 195° thermostat will do the trick. I will flush the heater core at a later date.
    guyopel likes this.
  8. #46
    Nov 2009
    Pacific NW
    1,098
    You could use a trucker method and cover part of the radiator with some cardboard. Might work and a heck of a lot easier than changing the stat twice a year.
  9. #47
    Aug 2006
    2,708
    P.J.
    I didn't take any photo Keith, sorry. No sense to do it now as the collars are inside the rubber boots. They are clamped on the ends of the steering rack bar. I bought them from McMster Carr. Note, they would not ship to Canada, you must give them the address in the States (I worked in PA at that time).
  10. #48
    Aug 2006
    2,708
    P.J.
    Harold, I did not modify the heater, I just changed the fan in order to make space for DSD carburetors.
  11. #49
    Nov 2007
    Cöllingswööd, NJ
    9,831
    Gördö
    6
    He is probably using the same split in half locking collars that he showed Mike in his brake pedal travel thread. Instead of letting the front suspension hardware hit a bump stop or have the tires bump into the sway bar, he put locking collars on the ends of the rack bar to limit it's travel and prevent the tires from hitting stuff.
  12. #50
    Nov 2007
    Cöllingswööd, NJ
    9,831
    Gördö
    6
    Quote Originally Posted by kwschumm View Post
    I used to do that when my GT was my daily driver! It worked great, it felt like I doubled the heat in the car. Ya gotta watch out when the weather gets warmer, though. You'll forget that you partially obstructed your radiator and you'll overheat when it's only 60* outside.
    I remember reading in a recent ad that some guy "plumbed new heating" into his GT. Has anyone bypassed the oem heater or supplemented it with an extra heater core or tranny cooler with a fan? One of the worst things about the GT heating system is that it can't recirculate the interior air through the heater. It can only draw in ice cold or wet outside air and push it through those tiny, lame, ancient, heater cores. Also, you really can't stop outside air from entering the car, can you? You can close the side vents in the footwells, but you can't actually shut off the vents at the ends of the dash.
    I designed out this problem when I did my dash. The flow through ventilation system is entirely seperate from my aftermarket heater and I can totally shut off the flow with closable vents at the dash and footwells. The heater only draws in and recirculates the air that's already in the car. It works like the dickens, too. I forgot which way to shift the inline heater control valve and I drove around for a few months of the Summer with the water flowing through the heater's core. I didn't have the fan on, but the extra heat inside the center console area was causing my stereo unit to overheat after about 1/2 hour of driving and the sound would start getting muddy coming out of the speakers. I finally discovered the screw up and turned off the heat and no more stereo problems.
  13. #51
    Jul 2005
    Milner, GA.
    11,300
    Dan
    12
    ... Hopefully replacing the 160° thermostat with a 195° thermostat will do the trick. I will flush the heater core at a later date.
    You could read this thread
    hrcollinsjr likes this.
  14. #52
    Jan 2003
    Chapel Hill, TN
    7,795
    Harold Collins
    I know that but she thinks you have improved every aspect of your car.
    P.J. Romano likes this.
  15. #53
    Jan 2003
    Chapel Hill, TN
    7,795
    Harold Collins
    The car should have heat at 40° without doing anything special. I do remember back in the 80's having to block off part of the grill to get the car to operating temperature. We were also in single digits something we don't see that often.
  16. #54
    Jan 2003
    Chapel Hill, TN
    7,795
    Harold Collins
    Ignition Timing
    I removed the distributor this morning and tried modifying it slightly, thinking I could improve it a tad. I got close to what I wanted but there is still some room for improvement.
    I partially disassembled the distributor that was in it. Removed the old sticky lube, replaced one of the springs (didn't take any pictures but will when I go back in), welded the centrifugal stops to limit total advance, lubed and reassembled it.
    8° initial at idle 850-900rpm
    33° total mechanical
    44° with vacuum advance
    I placed a small spot weld where the arrow is and ground it back down with a Dremel. I will go back and grind a little more. I thought I needed to re-install the distributor a tooth retarded to have my distributor line up like I wanted. I thought wrong.
    Will probably tweak a few things tomorrow and try to leave it along for awhile. I need to get back to The Old Hag as she is still sitting on the parking pad with a broken clutch cable looking neglected.
  17. #55
    Jan 2003
    Chapel Hill, TN
    7,795
    Harold Collins
    Carburetor Forum
    Replaced A/T throttle linkage with M/T throttle linkage with a little adjustment to be able to achieve WOT. Since not everyone reads "Member Projects" I thought it might be more beneficial to start a new thread in the "Aftermarket Downdraft Forum".
  18. #56
    Jan 2003
    Chapel Hill, TN
    7,795
    Harold Collins
    Ignition Timing Pt. 2
    I removed the distributor one more time to see if I could get a little more advance out of it. I've included a few pictures of what I did. Not pretty but it works.
    I swapped a lighter spring with constant tension for the standard heavy spring with an elongated loop on one end allowing quicker initial advance.
    Idle 850-900 rpm
    8° initial advance
    36° total mechanical advance
    I did no modification to the vacuum advance so I should have 47° advance cruising with no load on the engine. Too much? I'm thinking about checking some other vacuum advance canisters to see if I can find one with roughly half as much advance.
  19. #57
    Jul 2005
    Milner, GA.
    11,300
    Dan
    12
    Under a no load condition you can run the spark way up into the hundreds.
    Only after you start the engine__ will the loading apply.
    Now if you can give percentage of load then that's different.
    Last edited by wrench459; 12-13-2016 at 08:12 PM. Reason: Trying to be helpful...but it's not working
  20. #58
    Jan 2003
    Chapel Hill, TN
    7,795
    Harold Collins
    So leave it alone? I did find out last night that I need to get my alignment checked as the car was a handful at speed on a rough road.
  21. #59
    Jul 2005
    Milner, GA.
    11,300
    Dan
    12
    So leave it alone?
    I've seen many spark maps go into the 50 range.
    Closed throttle-deceleration.
  22. #60
    Jan 2003
    Chapel Hill, TN
    7,795
    Harold Collins
    Wheel spacers removed.
    I finally slowed down enough to remove the 16mm wheel spacers on the rear wheels. I bought shorter open end ET lug nuts with OE size 19mm heads. In a previous post I included pictures of the two different styles of lug nuts that were on the car. They also would have required two different tire tools/sockets to remove as the hex sizes were different. The open end ET nuts won't work with stock wheels but work great with the aftermarkets wheels on this GT.
    The tires can be rotated now without having to swap the spacers from wheel to wheel.
    P.S. "Rear" wheel is now the front.
    1. GT-R Project
      By rcthiemann in forum Member Projects
      Last Post: 10-14-2016, 08:17 AM
    2. My new GT project
      By wklopf in forum General Discussions
      Last Post: 08-02-2009, 11:51 PM
    3. My first project
      By Luckas in forum Introductions
      Last Post: 09-22-2006, 11:13 PM
    4. 2.0 Project
      By BetaCarotene in forum Opel Engine Performance Modifications
      Last Post: 02-13-2006, 07:58 PM
    5. New Project
      By Healy61 in forum Introductions
      Last Post: 02-14-2005, 05:29 PM
