My fiberglass GT - Page 8
Page 8 of 11 FirstFirst ... 4567891011 LastLast
Results 141 to 160 of 203
Like Tree280Likes
Thread: My fiberglass GT
  1. #141
    Dec 2012
    new tecumseth ontario
    178
    Old Photo
    When I first started my build thread, I mentioned that I was going to try and find some old pictures of my car. I still haven't figured out where I put the ones of my previous fiberglass build, but I found an old photo of my car in it's original form from 1976. Yeah, I wish it was still just the way it was in the photo. It was a 71, and the original owner had flat top pistons put in it. It went pretty good too. The only drawback was, the solex carb started acting up, and never let it perform like when I first got it.
  3. #142
    Dec 2012
    178
    Well, things are progressing nicely on my car. I have both windows installed for a trial run and both are working nicely. I am now in the process of fitting the front and rear side marker lights, and making sure the clearances are going to be enough for primer and paint. I am trying to get them to sit as flush to the body as possible.
    I showed molds of most of the parts I have made, but one mold that I forgot about was the mold I made for my cold air intake snorkel. It is a four piece mold. To make it, I had to make a plug. I laminated a few pieces of wood together to make a block in the rough shape of what was required, then proceeded to carve and shape it to the desired form. Once this was achieved, I coated it in a layer of fine fiberglass cloth and resin. I used some filler on it here and there to help get it nice and smooth. Then a couple more coats of resin, and when it was all dry, sanded it all nice and smooth, and finished it off with 600 grit. Now I waxed the heck out of it, (about ten coats to be exact) and applied some pva mold release. I also had to make a separator, to put around the place to divide the upper half from the lower half with a flange.
    Now it was time to start making the mold over it. I didn't have any colored gel coat at the time so I used some clear gelcoat I had from another project. First, you apply the gelcoat, let it cure, then apply one more coat. After that I used one layer of very fine surface veil, let it cure, then proceed with 3 layups of 1 1/2 ounce mat. After it was all cured, I parted both halves with a fine slitting saw, and had my molds. I put both halves back on the plug and using a thin separator between each one, applied all the small flanges around the edges to screw them together for making the parts.
    I wish I had play by play pictures of the whole procedure, but here are some of the mold, and the plug.
  4. #143
    Nov 2007
    Cöllingswööd, NJ
    9,689
    Gördö
    6
    You are one sick puppy, with your quest to make your entire car out of fiberglass!
    Holy Cow, what's next? A fiberglass exhaust system? Fiberglass engine block? Fiberglass windshield? Fiberglass tires?
    When will the madness stop?
    John B likes this.
  6. #144
    Dec 2012
    178
    Yeah, I used to do some electrical maintenance at a nearby wrecking yard and the guy's there called me fiberglass Johnny. But the thing I like about it the most is that when everything is all done, you can say, I made that with a paint brush and a small plastic roller.
  7. #145
    Dec 2012
    178
    I mentioned about installing the windows in the doors, and the fitting of the side marker lights. I finished the fitting of the side marker lights so here are some more pictures.
  8. #146
    Dec 2012
    178
    Dorr Jamb Switches
    Well, a few days ago, I started a thread where I was inquiring about the Gt door jamb switches. I mentioned that I couldn't find my originals, and that I was going to make some custom ones. I started them yesterday morning, and after about an hour or so the hydro went down. I could tell by the way it went off it was something major. Turns out someone took out a few poles about ten miles away from here, and knocked out a substation. We have a generator for the house, but the shop is three phase, so I was dead in the water. So it was off, from 10 in the morning, till just after 11 in the evening.
    So first thing this morning I was back at it. I made the mounting plates out of 1/8 stainless, and two of the barrels out of 3/8 stainless round stock. I looked high and low for another piece of stainless to make the third barrel, but couldn't find anymore. So I looked in my tool box, and I found a piece of titanium round stock that someone gave me years ago, so I made the third barrel out of that. I'll be the only guy to have titanium in a door jamb switch I guess. The plungers are also made from stainless steel. Surprisingly enough the titanium was easier to machine than the stainless steel. Stainless steel tends to work harden. So when you start drilling, don't stop or the surface hardens and you have to break through it to start cutting again. Quite hard on drill bits, and cutting oil seems to make things worse. I made aluminum end caps that screw into the ends of the barrels to hold the works inside.
    They are pretty well all done, except for the connectors, that I will make from .020 brass shim stock. I'll post more pictures of them when they are completed, but here are some pictures of them so far.
  9. #147
    Dec 2012
    178
    Sorry, I tried to edit a spelling mistake in my last post and somehow it's posted twice. There's more pictures.
  10. #148
    Apr 2003
    Portland, Oregon
    6,540
    How do you keep them from grounding when pushed in?
    John B likes this.
  11. #149
    Calgary, Alberta, Canada
    4,976
    5
    ...and since the OEM switch grounds to the body, will there be a separate wire for completing the circuit? I assume that this issue comes up with virtually every electrical thing that you wire on your fiberglass GT
    John B likes this.
    Working on the bare-metal, nut & bolt rotisserie restoration of my '71 Opel GT, and may have another GT to build next...
  12. #150
    Dec 2012
    178
    Where I attach my terminals under that 4-40 screw in the bottom of the plunger, I am going to insulate them with some bushings made out of delrin. That way they will only ground out when the plunger is extended and they contact the barrel. Similar to the way the insulators are on a set of ignition points.
  13. #151
    Dec 2012
    178
    Yes Keith, I'll have to attach a ground wire to them also. I think that it will work out good for the buzzer switch though, because it looks like that switches contacts are isolated from ground. But I will have to attach one wire to the barrel of the switch and the other to the end terminal.
    John
  14. #152
    Dec 2009
    Germany/Bremen
    2,718
    Norbert
    Wow
    Great work for such small part
    We here can take it easy and use also the Opel Corsa B ones.
    The Corsa B have both style of switch on same car!The Driver side have two terminals and the passenger side one!
    But we are all next door to a junk yard
    John B likes this.
  15. #153
    Nov 2007
    Cöllingswööd, NJ
    9,689
    Gördö
    6
    Quote Originally Posted by John B View Post
    Holy Shiatzu!
    Interesting about the titanium vs. stainless hardness. I tried to drill and re-tap a stripped titanium bicycle crank axle years ago. It was darn near impossible to work with the stuff. I ended up snapping off a tap in it. We needed to drill 100's of 1/2" holes in some pretty thick stainless sheet metal here at work a few years back. We opted to buy a pretty expensive punch apparatus to do the job.
    John B likes this.
  16. #154
    Dec 2012
    178
    Holy Shiatzu!
    There are different grades of titanium, just like aluminum. This piece I have is probably not as hard as the grade you were working with. I got it from this guy who owned a hobby shop down in the city. I made a deal with him, to build a scale model of a Florida everglades style air boat in a trade for that yellow helicopter of mine. It was 5 feet long and 2 feet wide, all riveted, together with solid rivets. He gave me a spare helicopter rotor head and a gas powered engine to set up on it, thinking he could have variable pitch blades. So he gave me that piece of titanium to make the rotor shaft out of. But I finally convinced him that, helicopter rotor blades for the purpose of propelling something like that would be totally inefficient. We went with a proper pusher prop and the thing went perfect. I think he thought I was bullshooting him about me building him this thing though, because 2 weeks after starting it, I walked into his store with it and he was surprised as anything. He had video of it running. I have some pictures of it on my old 35 mm camera but never got them developed. I wonder if after all these years they can still be developed.
  17. #155
    Dec 2012
    178
    My switches are all done, tested and ready to go. I figured that instead of trying to mount a ground wire to the body of the switch, I'll just ground the mounting plate.
    rrossjr and P.J. Romano like this.
  18. #156
    Oct 2002
    Mahopac, NY
    4,036
    awesome work and you are the RallyBob of fiberglass for sure!
    John B likes this.
    www.markandson.net
    www.gpny.com
    '64 VW Ghia '09 S35 BMW Z4
  19. #157
    Nov 2007
    Cöllingswööd, NJ
    9,689
    Gördö
    6
    So, where are you overall with this awesome project?
    Have you started on an interior yet or are you still working out body details, lighting, etc.?
    I'm just trying to get a sense of your to-do list.
  20. #158
    Dec 2012
    178
    No, Interior stuff being done upholstery wise, but I figured for a change of pace, I will install my remote starter kit. Have to take out the instrument panel to mount it behind there. Overall, the body is pretty well all sanded, but it seems every now and then I notice a little spot here and there that needs taking care of. Hopefully I'll be priming it as soon as the weather gets warm enough. I still have to bleed my master cylinders, and the brakes and check for leaks. I was going to make a list last week as a matter of fact, but forgot. Thanks for reminding me.
    The Scifi Guy likes this.
  21. #159
    Opeler Yellow73GT's Avatar
    Apr 2003
    N.Dak.
    950
    Chuck
    5
    Yes..
    John B likes this.
    "Be Water, My Friend" Bruce Lee, December 9, 1971
  22. #160
    Nov 2007
    Cöllingswööd, NJ
    9,689
    Gördö
    6
    Do you think your car will be heavier, lighter, or about the same weight as an oem GT?
    1. gt fiberglass parts
      By mniskeep in forum General Discussions
      Last Post: 10-18-2014, 01:07 PM
    2. Manta Fiberglass?
      By IT Manta in forum Manta
      Last Post: 09-14-2009, 06:08 PM
    3. fiberglass frontend
      By scott floyd in forum 2D - Body Repairs and Modifications
      Last Post: 02-04-2009, 09:25 PM
    4. Best Fiberglass???
      By roosterrusek in forum 2D - Body Repairs and Modifications
      Last Post: 08-27-2008, 07:35 PM
    5. Fiberglass Hood
      By crankyhick in forum 2D - Body Repairs and Modifications
      Last Post: 11-08-2006, 11:18 PM
