Pink to Green, how one members car transformed.
Results 1 to 13 of 13
Like Tree19Likes
  • 16 Post By opelspyder
  • 2 Post By 69whitegt
  • 1 Post By opelspyder
Thread: Pink to Green, how one members car transformed.
    Tennessee
    4,088
    Keith Lundholm
    Pictures can be seen of the before of this car on our website under "Texas Tornado" but Robert out of Texas owns this car, and I have been working on it for quite some time. It came in running and driving, had A/C in the back and the battery was just loose in the car, the front suspension was jacked up on one side, and it was Pink, maybe even a candy pink, magenta. So it started with Steinmetz flare kit, Watts Link rear, limited slip differential, adjustable trailing arms, Roger Wilson stroker motor with roller rockers, Dual Dell'Orto carbs, Getrag 5 speed, stainless exhaust with Magnaflow muffler, Honda Radiator, Air Conditioning, power RX7 mirrors, all the wheel wells were filled in with metal so the fiberglass flares were not open on the inside. Heater removed and put in the rear with the a/c unit, Setrab oil cooler and oil filter relocated.
    Custom Phantom white face gauges with GPS speedometer, 3D printed gauge pod made to house three extra gauges, Miata seats with speakers in the headrest, battery relocated to the rear, electric power steering.
    I have looked at this project a long time, and a lot of modifications were made. The color is a Camaro Synergy Green. It is the meanest sounding Opel I have had in the shop, it screams! Just thought I would show a bit of it off on here.
    www.newvintageauto.com
    Senior Member My location anastosmotors's Avatar
    Apr 2003
    Kenosha, WI
    762
    Pete Anastopoulos
    Nice job Keith. I like the choice of the color too. Pete
    Pete Anastopoulos
    www.anastosmotors.com
    anastosmotors@wi.rr.com* * * * * * * * * * * * * *
    Opeler 69whitegt's Avatar
    Jan 2006
    Cincinnati, Ohio
    656
    David
    Amazing job Keith, elaborate on the engine if you could.
    ____________________________
    . 1972 GT " Ms. Cali "
    . 1.9 High Comp.
    . Sprint Manifold
    . 32/36 Weber
    . Isky OR-66 camshaft
    Opel Addicts My location saxybiker's Avatar
    May 2002
    Tallmadge, Ohio
    2,363
    Vickie and Allen Gage
    UMMM... and exactly what is wrong with Pink???
    On the other hand..... superb job, as usual, Keith!
    1969 GT Omi The Grandmother
    1970 GT Octavia V8 Opel
    1971 GT Opie DESTEC car
    1971 Kadett Wagon Otis Survivor
    1973 GT Olivette Awaiting Restoration
    1975 Ascona Sedan (1900) yellowOrlandoyellow
    1975 Ascona Sedan (1900) Oliver - "Olli"
    2008 SolsticeyellowOliviayellow
  7. #5
    Nov 2007
    Cöllingswööd, NJ
    9,576
    Gördö
    6
    Lookin' good. Cool mods. Great color!
  8. #6
    Jan 2006
    Cincinnati, Ohio
    656
    David
    Quote Originally Posted by saxybiker View Post
    Pink GT's have a tendency to enjoy garage time more then others
    RallyBob and saxybiker like this.
    . 1.9 High Comp.
    . Sprint Manifold
    . 32/36 Weber
  9. #7
    Aug 2006
    Goderich, Ontario Canada
    2,647
    P.J.
    It appears that you separated AC condenser from the radiator. Interesting solution. Did you install second fan in front of the condenser?
  10. #8
    Tennessee
    4,088
    Keith Lundholm
    PJ, not sure what you mean by separated the condenser from the radiator, if you mean a gap between, yes, about an inch. But if not they are always two separate units.
    So on the engine is a Roger Wilson build (last commercial engine he built). 1.9 stroked to equivalent of a 2.4 Ford rods, roller rockers, welded spacer on the valve cover, aluminum flywheel, S10 clutch, Getrag 5 Speed. Reinforced torque tube shaft, fully adjustable rear end (trailing arms, watt linkage, adjustable height, relocated shocks more vertical, Steinmetz flares, custom metal inner fenders, passenger heater and fender cut out for carbon fiber air box, vacuum supply canister, vacuum plenum built, Honda radiator, I did add a fan in the front for extra measure. Air conditioning, GM 105 alternator, electric steering, custom gauges, GPS speedometer, Compufire ignition. Chevy Camaro Synergy Green, Mazda Miata seats with custom brackets made to use Opel tracks. Retro sound radio with Bluetooth. Optima battery mounted in rear deck with custom bracket.
    kwschumm likes this.
  11. #9
    Aug 2006
    2,647
    P.J.
    I guess it must be an oil cooler in the nose. It looked to me like a condenser.
    Very nice job Keith.
  12. #10
    Tennessee
    4,088
    Keith Lundholm
    Yes, that is the Setrab Oil cooler, has a thermostat block and relocated oil filter.
  13. #11
    Opelitis afflicted My location charlie1966's Avatar
    Apr 2007
    Ireland
    420
    It's a credit to your workmanship Keith. I'm sure there will be one happy driver there.
    I was considering that color for one of my GT restorations and seeing it now makes me want it even more.
    "You can't fix stupid, but stupid eventually fixes itself." -Issac T.
  14. #12
    Opelnut opelnut_1's Avatar
    Apr 2003
    Colorado
    761
    Valve Train
    Any Photos of the roller rocker setup and the modded valve cover?
    My Collection:
    69 Opel GT (Mystery Car)
    70 Opel Gt (First car)
    72 Opel Gt (Mostly Stock)
    87 Volvo 240 (Daily Driver)
    07 Volvo S60 (Daily Driver soon)
    07 CBR 1000rr (SPEED FIX Machine)
    65 F250 (for parts haulin)
    65 Fastback Stang (Sleeping Till Gt is back on the Road)
  15. #13
    Tennessee
    4,088
    Keith Lundholm
    Quote Originally Posted by opelnut_1 View Post
    Just purple roller rockers. Valve cover had a water jetted lower piece welded on, about a 1/4 thick.
    1. Pink Engines
      By Blue Manta in forum General Discussions
      Last Post: 01-28-2017, 11:03 AM
    2. New Car For One of Our Members
      By P.J. Romano in forum General Discussions
      Last Post: 04-17-2014, 07:29 AM
    3. Pink rules...
      By G.v.Mainberg in forum Member Projects
      Last Post: 02-17-2014, 08:18 AM
    4. Pink Gt
      By Ray Morley in forum GT
      Last Post: 11-04-2006, 07:53 PM
    5. Green, Pink, Yellow
      By tekenaar in forum Humor
      Last Post: 03-15-2006, 01:16 PM
