| Monza/Senator Monza and Senator A and Senator B Forum |
86 monza
Unanswered: monza 3l moter same as a 2.8 commodore moter???
any information would be great regarding this matter!i have just recently purchased an opel commodore,4 door,2.8 injected 4 speed manual.i was just wondering if these motors are the same or (how similar)they are to my 86 opel monza 3l.last question,are the 4 speed manuals any good? cheers michael Last edited by tekenaar; 10-03-2007 at 01:26 PM. Reason: manuel, woundering, moter, simular |
The straight-6 CIH Opel motors are all the same family, from the 2.6 to 3.0 Liter versions. They only have a different displacement, but I don't know whether its bore or stroke differences. They are mechanically interchangeable (motor mounts, clutch, gear box...).
This excludes the later 3.0 DOHC motors (Senator B/Omega A), they have a different block/head. The manual transmissions are ok if your motor is close to stock. I wrecked two automatic transmissions on straight-6 motors back in Germany, but never had any trouble with a 4-speed conversion in an Admiral. Of course, a 5-speed Getrag 265 is unbeatable in this league. Dieter
Opelitis since 1984
Real Name: Charles Goin
Going completely off memory.. So forgive me if I am wrong.
Main difference in 2.6 to 3.0L should be in the bore.. Dont know a lot about 2.6L but believe if its like a 1.7L then the head camber will be smaller and bore the same or it could be like a 1.9L head on a 1.5L Block and the head is the same the bore slighly smaller. But the 2.8L and 3.0L are about the same head.. different bore. The 2.8L was basically a carb motor. Although some 2.8L Commodore B GSE models used early L-Jet Bosch injection in the mid- 70s. Came with both single carb 2 barrel Zenith Carbs (Commodore B GS), Dual Solex Setups (Commodore A GSE and Manta TE2800) and possibly other combinations (Not familar with NON-Commodore applications) if memory serves. The 3.0L (12V) used Bosch early L-Jet injection to 1984 and the later (Non-resistance injectors) L-jet to about 1989. The 3.0L (24V) used Bosch K-Jet (Senator and Monza GSE Motor I believe) The 3.9L (Bitter motor) was a stroked 2.8L.. yes a stroked 2.8L not 3.0L, not sure why but thats what I was told. I think its because they bored the 2.8L Instead of the 3.0L because of smaller water passages allowed larger boring or something. It used the later L-Jet and had unique pistons, crank and rods. Thats what I remember from when I had my Bitter and rebuilt its motors.
CURRENT '06 Pontiac GTO '71 Opel Kadett 4 Door 36D (w/ Opel Parts & Service 2.0L) '74 Opel Manta (Bens Manta) '74 Opel Manta (w/ LK5 transplant) Past '73 Opel Manta (Blue Max) '75 Opel Manta (Yellow) '85 Bitter SC '73 Opel Commodore B GS '73 Opel GT (w/ Vinyl Roof) At least 16 or So Parts Opels Last edited by tekenaar; 10-03-2007 at 01:28 PM. |
G'Day Michael
Answer from someone in the same city as you!
The difference between the 2.8L and 3.0L six-cylinder motors is much the same as between 1.9L and 2.0L four-cylinder motors (1.9L x 1 1/2 = 2.8L and 2.0L X 1 1/2 = 3.0L). The bore size only is difference - 2.8L is 92mm bore and 3.0L is 95mm bore. The outer dimensions of the cylinder block are identical and everything bolts up - the only differences can be the intake ports position - like 1.9/2.0L motors and 2.2/2.4L - depending if one motor is 1983 or earlier and the other 1984 or later. You can probably bore a 2.8L out to 3.0L just by using 3.0L pistons - or Chevy pistons ... just like the 1.9L four-cylinder motor ... and fit Chevy valves into the head ... the same. 1.9L four-cylinder pistons can be used too - they are 93mm STD - so are a nice 'first oversize' for the 2.8L six ...
GTJim Opel Owner since last Century! Copyright © 2000-2009 J D Henry All Rights Reserved Last edited by GTJIM; 10-03-2007 at 10:34 PM. Reason: Added Info |
The largest engine in the Monza was the 3.0-12V with 180HP (depending on the market, the HP number might be slightly different). Dieter
Opel 4-cyl CIH: 1.5 (82.5mm x 69.8mm = 1492cc) ; 1.7 (88mm x 69.8mm = 1698cc) ; 1.9 (93mm x 69.8mm = 1897cc) ; 2.0 (95mm x 69.8mm = 1979cc) ; 2.2 (95mm x 77.5mm = 2197cc) ; 2.4 (95mm x 85mm = 2410cc) . . . all Opel CIH (4/6) engines have used common bores of 82.5mm (1.5), 88mm (1.7/2.6), 92mm (2.8), 93mm (1.9) and 95mm (2.0/2.2/2.4) respectively and all CIH (4/6) engines, except the 2.2 (77.5mm), 2.4 (85mm) and the Bitter/Mantzel 3.9 (90.5mm), used a stroke of 69.8mm.
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 10-04-2007 at 12:04 PM. Reason: Erick's input |
2.2 litre straight six 82.5 x 69.8 = 2239 cc
2.5 litre straight six 87.0 x 69.8 = 2490 cc 2.6 litre straight six 88.8 x 69.8 = 2594 cc [sorry Otto] 1.6 litre straight four 85.0 x 69.8 = 1584 cc
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by 2 Fast 4 U; 10-03-2007 at 06:19 PM. |
Idiot with a GT
This may be off-topic, and I may incur the wrath of the mods, but I would like to complement you guys on your knowledge of Opels.
I continue to marvel at the wealth of knowledge contained in your heads and others who have posted here. I rarely need to ask questions. I find out all I need to know by reading your posts. Thank you for sharing and helping. Thanks to Gary, too, for doing this site.
The difference between your butt and your soul is that God only has to save your soul once. - David Zielinski |
#11 (permalink) | |
this 28E CIH is quite of a weird bird among the CIH family: bore is only 92mm this makes a PITA to find parts like rings, injection is the old type D Jetronic (nothing to do with the later L/LE), the head is very special with injectors directly mounted on the head, so inlet ports are a few mm lower than a casual 1.9/2.0 head, manifold gasket is therefore specific. I just love this car (I have 5 of these), but consider to collect lots of parts to be on the safe side, or convert it to a complete 30E setup (very easy). HTH, Hiro Last edited by Hiro; 10-03-2007 at 06:20 PM. |
#12 (permalink) | |
head, camshaft, exhaust valves, pistons are specific. IMO the weirdest part of the 28E is the distributor: it contains a second set of twin points that triggers the injectors, better not have any problem with this distributor, because it's very rare even on Ebay.de! HTH, Hiro more infos on the D Jet here (french, sorry!): DJectronic Last edited by Hiro; 10-03-2007 at 06:22 PM. |
#13 (permalink) | |
3.6 litre straight six 95.0 x 85.0 = 3590 cc
#14 (permalink) | |
Opelitis since 1984
Also FYI.. Chuck Jordan who designed the Commodore B Is looking for one to import as well.. I had one, but Todd at Opels Unlimited has it now and its in really bad shape. Irony is that I brought it to California to save it because I couldnt find parts at the time and didnt want it to rust.
#16 (permalink) | ||
Hmmmmm . . .
I know this is used for both displacement taxing purposes and displacement limits in racing classes . . .
Hmmmm . . . part 2
. . . that made me curious about my 83mm bore listing for the '68 only, 1.5 4-cyl engine . . . oops, it's actually 82.5mm like your 2.3 (sorry) straight six above.
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 10-04-2007 at 05:47 PM. |
there are a few older euro engines with a listing lower than there cc's would suggest Otto
bmw had a 3210cc "3.2L" at one time the cut off is normally the 50cc mark the 1256 opel / vauxhall engine being a "1300" here
#19 (permalink) | |
I would say you could find 5 nice Manta/Ascona/Kadett for 1 comparable Commo, also much less cheap replacement parts available for restoring/welding the shell. so finally by the time you start working on a CommoB you will be finished with 3-4 Manta/Ascona/Kadett, it's the reason why I'm a CommoB fan racing a KadettC! Hiro |
#20 (permalink) | ||
OHV, OHC, CIH, DOHC and the diesel engines
#21 (permalink) | |
I also have 2239cc for the 6 cyl 2.2 CIH Hiro |
#22 (permalink) | |
Hmmmm . . . part 3
I know for a fact, that all engine displacement taxing was based on the '00-99cc' basis for taxing category - i.e. "up to 1.8 liter", "up to 2.0 liter", etc. - and that all the manufacturers made sure not to exceed those limits to avoid paying the next higher tax rate for "1cc over"! Perhaps those taxes have gone by the wayside over the years and are no longer of much concern in the EEC and GB, but the "up to X litre (00-99cc)" specification is still the determining factor in racing. That said, even Opel's last 2.4 CIH engines (95mm x 85mm) have an actual displacement of 2410cc . . . just don't try racing them in any 2.4 engine class!
#23 (permalink) |
General consensus is to round it up to 2.3 litres if you have, say, 2251 cc's. But if it's 2249 cc's you'd round it down to 2.2 litres.
My own homebuilt '2.4 stroker' designation is in fact 2372.98 cc's (95.6564 mm x 82.55 mm). But I rounded it up to 2.4 litres. Opel's factory 2.4 is 2409.99 cc's, but they still call it a 2.4, not a 2.5! |
#24 (permalink) |
OK, I've begun formulating an HTML matrix for all Opel CIH engines produced over the years to use as a reference tool. As Bob suggested, it would be nice to know all the variations for each engine type produced, S/E/H/etc. and all ancilliary details used in each type (yrs. manufactured, power, torque, CR, carb(s)/FI (type), unique specs, valve sizes, etc.), so that the matrix can be used as a "one look" overview for each displacement and type . . .
#25 (permalink) | ||
