Register Logbook FAQ Calendar Mark Forums Read Chat Room
Old 09-26-2007   #1 (permalink)
Heinrich is on a distinguished road
Unanswered: Opel 2l Ohc
Im from South Africa and take part in stockcar oval track racing.I would like
to built a relaible engine with good performance.
The engine need to rev 8500rpm and dont exceed 2.1 alot have tried to built
motors with mercedes rods but it does not last what rods can we use to make the bottom end bulletproof and piston to accomidated the right ratio what would be safe.What would be the right cam to use for the type of racing
Someone also mentioned something about the sump and oil pump gears.Can somebody please help as cheap as possible.
Heinrich is offline
Old 09-26-2007   #2 (permalink)
Ohc ??
Most of us on this site run the old Cam-In-Head Opel motor built from 1965-85 ish.
Are you talking about this motor (2.0Litre 95mm bore X 69.7mm stoke) or the later Over-Head-Cam motor (2.0Litre 86mm X 86mm) like the one used in Opel Vectras fron 1987 - 2000 ??
Old 09-26-2007   #3 (permalink)
Look at a thread called "Connecting Rod FAQ" for a good start. You can PM me for a description of my rods and crank and bearings, it is not public information though...
Pistons are available to work with these rods.
Oilpans can easily be built from scratch, mine is deep and has right side kickout and vertical scraper and a screen and external pickup and an access plate under the pickup. It's pretty trick, but really simple.
Unfortunately you used the word "cheap" and that just isn't going to work. Sorry. But we'll do the best we can to help you within the budget!
jeff denton is offline
Old 09-26-2007   #4 (permalink)
Hiro's Avatar
Hiro
the 2.0 OHC (86x86mm) has a relatively low rod ratio of 1.663
but piston cd is already 30.5mm so there is not a lot of room to accomodate much longer rods.
maybe you can make custom forged pistons with cd 26.5mm
then you need 147mm long rods but I don't have cheap suggestion for that length,
and rod ratio would only be slightly better (1.71)
HTH,
Hiro
Hiro is offline
Powered by vBulletin® Version 3.8.2
DTO Garage vBulletin Plugins by Drive Thru Online, Inc.
