#27 (permalink) |
I'm more interested in the intake.
Tuned exhaust is only worth a few ponys...but if you match the intake with the exhaust flow in the correct proportions.. then you talking. Nice work Bob. Are you using the 80 percent flow rate to intake? Last edited by wrench459; 05-12-2008 at 11:45 PM. |
#28 (permalink) | |
On the bare head flow, I strive for 75-80% exhaust flow. Normally when the header is fitted, the exhaust flow will increase another 4-5 cfm. On this particular EFI intake, the manifold chokes the airflow by about 20 cfm over a bare port. Not great, but far better than the 'stock' carb'd intake that was previously used on this head (2.4). Usually the final numbers are closer to 90-95% exhaust flow once the manifolds are bolted in place. Here's the old thread where I tested a bare 2.4 intake port, a Dbilas DCOE intake manifold, and the 3.0 litre EFI intake manifold. HTH, Bob
My Flickr photos. Jan. 3, 1984 - Jan. 3, 2009, that's 25 years of this damn Opelitis! C.R.L. 9/22/69 - 12/8/99, J.M.L. 3/3/43 - 6/15/04 Last edited by RallyBob; 05-12-2008 at 11:53 PM. Reason: added link |
#31 (permalink) |
It's just the common everyday kind of craftsmanship you see all the time.
At Bob's shop, that is.
#33 (permalink) |
Kick a little asphalt
Very nice work Bob.......again! I've always admired your quality of work, but the part I like best about what you do is the innovation. It's always interesting to see your unique approach to ordinary tasks. Very inspiring.
Duane
"The bitterness of poor quality remains long after the sweetness of low price is forgotten" |
#34 (permalink) | |
Peak power previously on the dyno was @ 6500 rpms, peak torque I think was at 4800 rpms, but that was with a Holley 2-bbl. I think with the new intake and exhaust the peak hp/torque numbers will occur at a lower rpm. Bob
#35 (permalink) | |
#36 (permalink) | |
![]() I say that with full respect, you did an amazing job on your latest car! The rest of you will have to wait until Carlisle to see it....
#37 (permalink) | |
#38 (permalink) |
What plans do you have for the car? Any unique body or chassis mods?
#40 (permalink) |
Thank you, Bob! I've got a good start on the header, just isn't gonna get finished unless for some reason we want to race that car again. (Autocross has crossed my mind, by the way) And it is legal, just out of the ordinary compared to the competitors, yeah like the whole car is! They just aren't used to something being meticulously built in that class.
#41 (permalink) | |
Duane
#42 (permalink) | |
I'm only going to ask only one question yeah right..whats the rod length? |
#43 (permalink) | |
The body will stay as it is for now, but it's due for a restoration soon. I will not be involved with that aspect, I wanted to get it mechanically restored first. The one area I will modify related to the body is the front air dam and rear spoiler. The car needs to be stable, it will have enough power and rpms for 145-150 mph. So I have come up with a custom setup in my head, which I'll likely fabricate from sheetmetal. Bob
#44 (permalink) | |
#45 (permalink) | |
Hastings rings iron I cringe theres got to be a better ring package What 's your thoughts on top ring ? total seals on the top ring? I'm getting two different feedback on this. did I say I hate the metric system. |
#47 (permalink) | |
The Hastings moly-faced rings actually work okay. Deves would have been nicer, but the waiting time is long. I was going to use Total Seal for all the rings, but the price was something like $215 10 years ago! Yes, wide rings suck! Stock Opel is huge at 2mm/2mm/5mm! I like to run 1mm or 1.2 mm top rings for racing, but since this was a street car with a rather large bore I left them at 1.5 mm. For racing use I found that above 8500 rpms the top rings start to flutter a bit and widen the top ring groove in the piston, so the only thing you can do is go thinner...it helps a lot. I have been meaning to try the gapless top rings but have not had to build an engine for myself in a while. Basically if they work well I want to build a two-ring piston for my Bonneville engine, this would allow for a shorter piston, longer rod, and less friction. Bob
#48 (permalink) | |
#49 (permalink) |
Great work Bob, I try to create some sweet stuff but yours smokes mine every time, and I love the innovative over the axle widened pipe. The thing I really like is the LIFT that the car is on, I sure could use one of those.
#50 (permalink) | |
1970-GT
Our racing go-Karts use only one ring (2-cycle). I'm sure you noticed how small and narrow the skirt area is on the F1 pistons we saw at the PRI show. Some even had skirt inserts made from graphite/ceramic or something! Coatings are illegal in Karting, but a must for your Bonneville car. All the Aerospace coatings are reaching the racing world, new stuff coming out all the time. The ultimate friction reducer..........roller bearings! Ever think about trying to machine the Opel engine for roller bearings? I'm sure you have! ![]() Oh, nice fab work on the exhaust. I love the over the axle pipe...........you are clever! Lyle |
| Tags |
| exhaust, header, sportwagon |
