Old 07-30-2008   #101 (permalink)
Here's the crossmember and some of the mods done to it. Most notable is the addition of the steering quickener to the mix. I mocked it up while the front suspension was still in the car. It was actually very straightforward. It's a Howe 1.5:1 quickener, so the steering goes from 3.9 turns lock-to-lock down to 2.6 turns lock-to-lock. Plus the factory sloppy u-joints and rag joint are eliminated, making for far more precise inputs at the steering wheel. While doing all this, I tore down the steering quickener to re-pack it with synthetic grease (Redline CV-2). So I took the opportunity to polish the housing halves at my friend's chrome shop.
I also extended the upper spring perch sleeves in order too allow for shims to be used above the coil springs and spring seats, without the coils falling off the seats. I used 3.25" exhaust tubing, it aligns nearly perfectly with the OEM spring guide.
The upper bump stops on the a-arms were essentially cut in half to alow for more travel before they strike the crossmember, but given that this is a real car that will see real roads (not just a race track), I opted to create even more travel by moving the upper a-arm stops on the crossmember upwards. I just sliced a 5/8" pie-shaped wedge out and bent it upwards, then re-welded it. You'll note that as the a-arm travels upward it also arcs inward, so I tried to match this arc.
I came up with a far simpler bracing method for the upper a-arm pivot tubes in the crossmember. This stabilizes the tube for less deflection, and hopefully prevents them from being bent in case of a small impact. It's easier to replace an a-arm than it is the entire crossmember.
Lastly here are the solid upper crossmember mounts I fabricated. I used 6061-T65 aluminum bar stock, and cut and sanded it to fit into the upper crossmember 'holes'. Then I drilled and tapped the aluminum for some new hardened 10mm studs, and added a piece of 90 durometer 1/4" silicone sheet material for some sound deadening qualities.
http://farm4.static.flickr.com/3223/...fa5c635d_o.jpg
http://farm4.static.flickr.com/3287/...f4228a69_o.jpg
http://farm4.static.flickr.com/3280/...17187813_o.jpg
http://farm4.static.flickr.com/3172/...de2fed15_o.jpg
http://farm4.static.flickr.com/3012/...6f7c67bf_o.jpg
http://farm4.static.flickr.com/3043/...4b1acb23_o.jpg
http://farm4.static.flickr.com/3237/...07911424_o.jpg
http://farm4.static.flickr.com/3030/...a1b0360e_o.jpg
http://farm4.static.flickr.com/3269/...8309ee47_o.jpg
http://farm4.static.flickr.com/3222/...07278fd6_o.jpg
http://farm4.static.flickr.com/3273/...a9e61d6d_o.jpg
http://farm4.static.flickr.com/3128/...1294dc8d_o.jpg
http://farm4.static.flickr.com/3095/...d737737a_o.jpg
http://farm4.static.flickr.com/3277/...8b25e52e_o.jpg
http://farm4.static.flickr.com/3065/...b0cd017f_o.jpg
http://farm4.static.flickr.com/3153/...7e945d2c_o.jpg
http://farm4.static.flickr.com/3232/...0f9717f7_o.jpg
http://farm4.static.flickr.com/3086/...4590ec4d_o.jpg
http://farm4.static.flickr.com/3140/...91c2cb6c_o.jpg
http://farm4.static.flickr.com/3208/...5ec6449b_o.jpg
Old 07-30-2008   #102 (permalink)
Originally Posted by oldopelguy View Post
Those sure are some nice pictures, is that camera still holding out or did you get another?
Same camera Stephen. Still working fine, it's just a bit touchy in low light situations. I need to set up a tripod for the longer exposure times, otherwise it gets blurry from my hands shaking.
We also need to get you a plasma torch, those outer ball joints would have taken seconds to cut for the new mounts.
I have an awesome 50 AMP plasma cutter, still have no air to run it, that's all!
Did you recess the sway-bar mount some up into the "L" bracket, or is the notch always that "deep"? I don't remember it being so is all.
That is indeed stock.
I've been planning on swapping out the rubber sway bar bushing in the lower control arm with a load-rated spherical mono-ball, and looking at those pictures makes me wonder if swapping out the inner one might not be a bad idea too. The outer sleeves typically used with them are so much thicker than what's in there stock and it might help keep the arms together. Sure the ride would be a bit rougher, but it wouldn't be on a DD car anyway...
I've done this before on race cars. The down side is that it can cause a bind (believe it or not) due to the sway bar arm and the lower a-arm traveling in different arcs. On a lowered car especially, the sway bar draws the lower a-arm rearward. This does two thing primarily, it changes caster (reduces it) and it binds the lower a-arm bushing. On a pure race car with very stiff springs (700 lb or so) and maybe 2-3" of total travel you can design the bind to be 'outside' the normal travel window, but on a longer travel street car it will show up somewhere during your driving and can wreak havoc.
Old 07-30-2008   #103 (permalink)
A little rust repair work. The jackpad was totally shot. I thought the frame was 100%, but it had a bit of blistering, so I cut away some of the outer skin and the bottom skin. I didn't have and mild steel in the proper gauge to weld back in, but I had some stainless steel, so I figured, 'What the heck!'. The underlying 'real' framerail section was in good shape other than some surface rust, so I ground that rust away and painted it over with some high zinc weld-thru primer before capping it.
I also started to patch the rust hole in the floor and to re-create the driver's side jack pad, but the recent heat and humidity has cause me to neglect this for the past few weeks, so I haven't gone any further on it. I did pick up some 1.125" chromoly round tubing with .083" wall thickness which will work perfectly as a jack 'tube' on my re-created mount.
http://farm4.static.flickr.com/3272/...cb017713_o.jpg
http://farm4.static.flickr.com/3250/...cce40701_o.jpg
http://farm4.static.flickr.com/3111/...5082672c_o.jpg
http://farm4.static.flickr.com/3144/...5e62b9f1_o.jpg
http://farm4.static.flickr.com/3026/...bf8c8893_o.jpg
http://farm4.static.flickr.com/3009/...bcc1c2d1_o.jpg
http://farm3.static.flickr.com/2035/...6632556d_o.jpg
http://farm4.static.flickr.com/3223/...6b7b2ae5_o.jpg
http://farm4.static.flickr.com/3105/...ee67626c_o.jpg
http://farm4.static.flickr.com/3255/...74ecd33f_o.jpg
http://farm4.static.flickr.com/3098/...2cdd57d6_o.jpg
http://farm4.static.flickr.com/3156/...9b9e3a6d_o.jpg
Old 07-30-2008   #104 (permalink)
Looks like we're gonna go all out now. On this past Sunday I received a front clip from a Manta, to be grafted onto the Sportwagon. Unfortunately I have my work cut out for me, there's a bit of the typical New England rot on everything!
I will probably replace the top valance with a carbon fiber part. I have a mold already made but I have no vacuum bagging equipment so I'll send it to a friend in Vermont who used to do a lot of composites work for race/rally cars. Carbon is extremely stiff so unless the part being made is flat you must vacuum bag it or it will not fit the contours of the mold. I will be making a custom front airdam as well, so I will pull a mold from the metal prototype and do the same thing, although it will probably be a carbon/aramid hybrid fabric for more impact resistance. And I'm seriously thinking about doing the hood as well. If I can gain the aero advantages of the Manta front end yet make it lighter than the Ascona front end the payback would be better top speed, better mileage, and better handling.
Unfortunately, in order to repair the rust that IS there properly, I have to disassemble the entire front clip. I went through 2 cobalt spot-weld bits, having un-done about 400 spot welds to get it to this point! and I'm not quite done yet either.
BTW, Castrol 'purple' cleaner works awesome, it removed 34 years worth of grime from underneath the hood in just two applications.
http://farm4.static.flickr.com/3123/...c89245a5_o.jpg
http://farm4.static.flickr.com/3267/...0ff71022_o.jpg
http://farm4.static.flickr.com/3278/...a6f04efa_o.jpg
http://farm4.static.flickr.com/3168/...e4c34aa1_o.jpg
http://farm4.static.flickr.com/3220/...80549342_o.jpg
http://farm4.static.flickr.com/3070/...5ed35d42_o.jpg
http://farm4.static.flickr.com/3171/...f5d696f3_o.jpg
Old 07-30-2008   #105 (permalink)
Oh, and a special thanks to Mach1Tom for searching out some Shiner Bock beer and bringing it to MantAscona. And of course thanks to MantAscona for bringing up to CT! We can't buy this stuff up here. It has made the hot humid days much more tolerable for me...
Old 07-31-2008   #106 (permalink)
Hiro's Avatar
Hiro
tremendous work Bob!
the mods you make are so clean they would look "stock" for a race marshall here,
very important when passing the tech visit before each vintage race...
superb!
Hiro
Hiro is offline
Old 07-31-2008   #107 (permalink)
opelnut10's Avatar
Manta nose onto Sportwagon
The two that we did was cut just forward of the top of the inner fender panel, we found that it matched up better with the contour of the Manta inner panels. After the pieces were grafted together and ground down it was very hard to find just where it was done, it was tigged and done a small space at a time and allowed to cool in order not to warp the metal. We also fill the front header panel with spray in foam to stiffen that panel to keep it from looking "wavy", worked very well. I always liked the look of the small bumper Manta front end on the wagon, Opel should have made one
opelnut10 is offline
Old 07-31-2008   #108 (permalink)
superb!
Hiro
Glad you like it Hiro. Maybe it will give you some ideas for your racing?
Old 07-31-2008   #109 (permalink)
I'm trying to understand exactly where you cut the front end....did you just snip the front end off the wagon @ the headlight area, or did you swap out the entire Manta inner fenders and front headlight area? This'll be my first front end swap so any pointers/advice are very welcome!
Old 07-31-2008   #110 (permalink)
oldopelguy's Avatar
Logbook Entries: 3
There's a flat spot in the inner fender in the front on the Manta that goes out to just below the headlights, about 5" long, that's about all you actually need to cut off. (Pretty much what you have left attached to the front end.) Problem is that only the rear 3 or so fender bolt holes line up, the spacing gets different on the front half of the fender and the Manta fenders won't bolt to the Ascona inner fender wells without some modifications. The further you go back the more of the bolt holes that line up, if it's important to you, otherwise you just modify either the inner fender well or fender to use the other side's holes.
Since you have the spot-weld cutter out anyway, start drilling on the Ascona. The actual "frame" rails are the same, as is the front crossmember between them just ahead of the radiator. On the Ascona the front panel fits right up to them, on the Manta there's a tunnel of sorts for the radiator out to the nose. If you start drilling out spot welds on the Ascona you can get down to the front crossmember, leaving it in place, then line up the Manta nose with it and use the fenders to hold it all together. The gap in the inner fender will be obvious, but the inner fender piece from the Manta nose should overlap easilly enough for a lap weld, or flange if you wanted to connect them that way.
Now with a carbon fiber top panel for the nose it would be easy enough to keep it removable. With it removable it would be easy enough to cut into the air tunnel in front of the crossmember and install the radiator from the top 8" ahead of it's normal position. Then there would be a whole lot more room in the engine bay.....
If I send you the carbon fiber cloth can I get in on one of those nose pieces too.....?
oldopelguy is offline
Old 07-31-2008   #111 (permalink)
The crossmember between the framerails is definitely different. At least on these cars it is. I am removing it altogether though, and making a tubular crossbar. Too much airflow obstruction to the lower part of the radiator IMO, and I'm fitting an aftermarket 19" tall x 22" wide aluminum radiator anyway.
I'll let you know what they cost once I send the mold to my friend in VT. Because of the 'wraparound' nature of the upper valance, the mold is a 5-piece bolt-together deal. He needs to see it to quote it. The mold took me quite some time to build, I had to do it in three phases. He probably has a bolt of 5.5 oz. carbon cloth left over from his rallycar, so he has plenty of the stuff.
Old 07-31-2008   #112 (permalink)
opelnut10's Avatar
The Ascona inter fender panels were cut just forward of the middle and the Manta was cut in the same way to butt up to the same contour of the clipped Ascona panels. The entire front end was removed and the Manta front end grafted on. The critical measurement is to make sure the Manta hood fits properly. Look at the Manta sedan-delivery in my photo album that is the way it was done.
Old 07-31-2008   #113 (permalink)
oldopelguy's Avatar
Logbook Entries: 3
The whole crossmember might not be the same, but the rear most piece of it was the same stamping on both the '75 sportwagon and the big-bumper Manta I used the nose from. For me it was an easy piece to reference off of.
Old 08-01-2008   #114 (permalink)
Interesting. The ones I have are definitely different from car-to-car. 1975 Sportwagon vs. 1974 Manta however...I wonder if that's the issue? I'll take some pics to clarify.
Old 08-01-2008   #115 (permalink)
Hiro's Avatar
Hiro
Bob these German guys are familiar with this swap:
Manta-A-Club Südhessen e.V.
pw3
00936
es3
HTH,
Hiro
Hiro is offline
Old 08-01-2008   #116 (permalink)
opelnut10's Avatar
Manta wagon
Bob, in the picture 00936 in Hiro's post you can see a raised panel on the inner fender. Just in front of that about one inch is the best match between the contour on the Manta and the Ascona. On a big bumper car I am thinking you will need to cut the stub frame off with the front clip in order for the bumper supports to be in the right place, but we only did small bumper cars so I have no experience with them. As you can see, when done right they look like they were factory built and really makes a good looking unit when finished.
Old 08-01-2008   #117 (permalink)
Bob, at Tacoma 2004 there was a Mantscona that had the inner fenders grafted just in front of the front wheel center-line. I posted some photos back then, so look at:
Robert_Blundell-6 - Opel Photo Gallery
and the photos on either side of it. HTH
Old 08-02-2008   #118 (permalink)
Thanks for the additional info guys, very much appreciated! We'll make this work somehow. I just wish that more of the inner fenders had been left on the donor front clip.
I took a day off from working on the old sheetmetal and picked up the front suspension parts from the powdercoater. They look sweet as usual, but the real impressive thing is the attention to detail. Every bit of the 'interior' of the lower a-arms and the interior of the crossmember itself is coated. I don't know how they did it, but they did! I'm definitely happy with my new powdercoating guys. You can't paint inside there unless you dip it in a vat of paint!
Old 08-09-2008   #119 (permalink)
Here are some of the front end parts back from the powdercoater. Still remaining to prep and have coated are the rack and pinion housing, the spindles and steering arms, the front hubs, the shift tower, and a few other brackets. These guys did an amazing job, they got into every nook and cranny of the lower a-arms and the crossmember.
http://farm4.static.flickr.com/3243/...e8833585_o.jpg
http://farm4.static.flickr.com/3136/...87a55af2_o.jpg
http://farm4.static.flickr.com/3033/...92b3447d_o.jpg
http://farm4.static.flickr.com/3260/...fa2dc894_o.jpg
http://farm4.static.flickr.com/3160/...d40283f1_o.jpg
http://farm4.static.flickr.com/3227/...0d24284b_o.jpg
http://farm4.static.flickr.com/3257/...0ddbb433_o.jpg
http://farm4.static.flickr.com/3054/...35133dfd_o.jpg
http://farm4.static.flickr.com/3277/...6597d54a_o.jpg
http://farm4.static.flickr.com/3290/...d457743f_o.jpg
http://farm4.static.flickr.com/3225/...b522311f_o.jpg
http://farm4.static.flickr.com/3056/...73e9eb73_o.jpg
http://farm4.static.flickr.com/3142/...0e617d7c_o.jpg
Old 08-10-2008   #120 (permalink)
Hiro's Avatar
Hiro
'Bei dem Kerl ist Genie und Wahnsinn auch nah beieinander.
Alles würde ich dem nicht nachmachen, aber er bringt einen auf neue Ideen/Sichtweisen'
I agree,
Except I'm trying to imitate lots of your work,
And I know I will never complete most!
Cheers,
Hiro
Hiro is offline
Old 09-10-2008   #121 (permalink)
Haven't done much to the car lately, but thought this might interest some of you.
Needing a new EFI outlet hose (between the sender and the fuel pump), but not having a good OEM one available, I tried at first to bend my own from stainless tubing. This was not to be, as the tubing would kink when nearing 80% of the required bend.
And normal rubber hose won't work for a couple of reasons. Prebent hoses tend to be for air or coolant and thus can't cope with gasoline without softening, plus they will usually collapse because they're on the suction side of things. And normal straight fuel line can't bend that tightly without kinking and blocking off fuel flow (this car has this problem previously).
So I made a new fitting from 1/2" copper plumbing elbows, and silver-soldered them together. It has a much higher melting temp that regular solder, which usually melts between 360-480° F depending on the specific alloy. The particular silver solder I used melts at around 1020° F, which is a plus because of the proximity of the fuel fitting to the rear exhaust pipe...less than 3 inches.
I had to shorten all the fittings a bit to make it work, and flared the smaller pieces of tubing to ensure a leak-free install, but in all it was worth it knowing it won't collapse inwards or fail at an inopportune moment. I had my friend at Allied Metal Finishing give it a quick flash-plating of nickel, basically because I didn't want it to look like a plumbing fixture!
Old 09-10-2008   #122 (permalink)
Bob;
I know the OEM exhaust had a resonator/pipe in the same location as your final muffler/tail pipe is, but, the OEM piece was much smaller and had more clearence to the gas tank, yours looks like it's right there, albeit still clearing the tank. If you're concerned about this fuel pipe, what about the heat off the muffler to the tank?
Old 09-11-2008   #123 (permalink)
Certified Opelholic
davegt27's Avatar
Real Name: joe blow
Bob correct me if I am wrong
the stock Manta/Ascona 1975 FI model has like a special 1/2 fuel line
the reason for this is the FI pumps don't pull fuel to well so they come stock with this large fuel line
when I had a 75 Manta FI car I wondered where in the world I would find a replacement line of that size
Marty a friend of mine and a long time Opeler recommends a filter between the tank and the pump
also when I put FI on a GT I started to run cooper fuel line but was afraid since it is a soft metal that a rock could kick up and nick the cooper fuel line
that's when I went to bendable brake line
I would recommend some brake line instead of the cooper
Davegt27
davegt27 is offline
Old 09-11-2008   #124 (permalink)
I thought about that too, but I suspect the fuel volume inside the tank will have a cooling effect on the metal of the tank itself, especially sloshing about and all that.
Old 09-11-2008   #125 (permalink)
Yup.
These fittings are actually quite rigid, so it shouldn't be an issue. It's not dead-soft copper.
I tried this already, but couldn't get 1/2" steel tubing to bend that tightly without kinking. At least not on a Manta/Ascona chassis.
Tags
exhaust, header, sportwagon
