Old 06-13-2008   #26 (permalink)
Originally Posted by neuropel View Post
If you have a design for a turbo header that you're using in a GT, I'd be interested - steel would be fine but stainless steel would be superior.
Make sure you guys are using the same turbo then. Flanges differ, as do external dimensions, which will affect the clearance to other components.
I think mild steel would be fine, with a similar Swain coating.
As long as it's thick wall, then mild steel will be okay. Schedule 40 (.134" thick) steel pipe is okay in mild steel, but you can use schedule 10 (.109" thick) if you make in it with 304L stainless 'weld-L's'. Regular thin wall (.049" or .065") header tubing is a no-no! Or you can use .065" thin-wall if it's type 316 or 321 stainless, but at that point the materials will set you back $400-500 alone!
Old 06-13-2008   #27 (permalink)
Hiro's Avatar
Hiro
Originally Posted by Gumby View Post
I'll send it on my personal name and declare it used then. What is the threshold before they charge you?
less than $100 should be OK to escape custom survey,
Hiro
Hiro is offline
Old 06-13-2008   #28 (permalink)
1970-GT
I would be interested in a steel flange, my header won't last forever.
How are you planning on cutting the flange?
Plasma, water-jet.....
Thanks for thinking of us.
Lyle
Tru-Craft is offline
Old 06-13-2008   #29 (permalink)
Supercharged 2.4
Gumby's Avatar
As long as it's thick wall, then mild steel will be okay. Schedule 40 (.134" thick) steel pipe is okay in mild steel, but you can use schedule 10 (.109") thick) if you make in it with 304L stainless 'weld-L's'. Regular thin wall (.049" or .065") header tubing is a no-no! Or you can use .065" thin-wall if it's type 316 or 321 stainless, but at that point the materials will set you back $400-500 alone!
haha what no one wants an inconel header?
They'd all likely be built to order because everyone is going to want something different. Alternatively I've given some thought on what it would take to make the header capable of accepting adapter plates so the end user could make the choice of what turbos will meet their needs and still fit.
Hiro
It's a good thing shipping isn't part of the declared value. Thanks for the info.
Lyle
CNC Mill
Gumby is offline
Old 06-13-2008   #30 (permalink)
How much then?
The issue is that not only does the flange potentially change, but the turbo gets bigger. So it will enlarge in almost every direction, which might prove to be a BIG problem for clearance in already tight confines. I think you need to establish a turbo size you will use, and build that header. Others will have to follow your lead, or build their own header! Too much variation otherwise.
How much power are you honestly looking to make? Remembering a stock 1.9 Opel makes 45-55 wheel HP, is 200 whp a target...or more? The Garrett GT2554 turbo I bought for my Opel wagon can support up to 240 hp, and that's about as small as they come in a ball-bearing T25-style turbo (T25 is the family of turbos, it's defined by the small flange dimensions).
I'm (really!) not trying to complicate things, just bringing some potential issues to light before they confuse matters more and skew the whole project.
Old 06-13-2008   #31 (permalink)
This might help:
T25 flange
T3 flange
T4 flange
Old 06-13-2008   #32 (permalink)
Supercharged 2.4
Gumby's Avatar
Good point. Building the header to fit a small common turbo is probably the best and most cost effective way to go.
200hp at the wheel is plenty from the 1.9 at least for me. I am not sure what everyone wants from a turbo 1.9 but my goal is to make boost nice and low in the RPM range. An increase in torque is what I am really looking for, max hp is irrelevent to me since the engine will never see those rpms on the street.
Gumby is offline
Old 06-13-2008   #33 (permalink)
This was the turbo I picked up for my wagon.
Garrett GT2554
Old 06-13-2008   #34 (permalink)
Believe me, 200 real whp (not speculated) in an Opel moves right out! We're talking 4x the stock power. We're talking trashed 4-speeds, smoked clutches, busted torque tubes, and blown rear ends.
In order to make a 'big' turbo work on a small lower powered engine, you'd need to modify the engine not only for strength, but for breathing (cam, head porting, etc) so it doesn't run into compressor surge in normal driving conditions.
So as you said, sizing the manifold for a small turbo that can make between 150-250 hp and spool up fast is a better choice. You can increase the hp just by increasing boost if you want to (and if octane + tuning allows it).
Old 06-13-2008   #35 (permalink)
neuropel's Avatar
This is partly why I asked about flanges - the header could be left with a collector so that others can add any flange they want. I'd be good with the T25 flange since space is at a premium in a GT. Good suggestion to go with one flange type and others can either follow or make their own. Getting this in stainless would be pricey I'm sure, but wouldn't it essentially last forever? Any chance they'd come in under $600?
Todd
-Abraham Lincoln
________________
1972 GT 2.4L
1974 Manta GT/E 2.2L
1973 Manta Rallye 2.5L
neuropel is offline
Old 06-13-2008   #36 (permalink)
Not so simple as I explained before. The flange dimensions vary greatly, so a collector for a T25 is too small for a T3 flange, and vice-versa. And the location of the collector (and therefore flange) would likely change as the turbo size grows due to clearance issues. I think this is a perfect example of the 'Choose any color you like as long as it's black' mentality you need to make this work. Space is at such a premium you won't have the luxury of making one size fit all.
Old 06-13-2008   #37 (permalink)
Supercharged 2.4
Gumby's Avatar
200whp seems like an attainable goal. Besides that brings the power to weight ratio in the neighborhood of 10lbs/hp. That's good enough for me. I just want something more peppy. I am not into street racing.
Garrett GT2554
Nice turbo but yikes fitting is going to be a little bit of a challenge even with one that small. I am not sure equal length runners is going to be economical/possible without cutting sheet metal. I think we may have to have the turbo close to level with the exaust ports and towards the front of the engine to make sure it can fit without cutting any sheet metal. What are your thoughts Rallybob?
Also what was the price on that turbo?
Todd
Not exactly... most opelers looking for SS would go with 304 which is more durable than A36 mild steel but still one of the cheapest and least durable stainless you could use to make a header. The real reason to go with a better header material is weight and durability. 316, 321, 625, 630 etc can be made progressively lighter because the material is more durable at higher temperatures... but costs will skyrocket with the better metals and obviously there are diminishing gains. Cost of owner ship on a street vehicle will be cheaper for the A36 turbo header even if it has to be replaced a few times during the lifetime of the car. The cheapest I can find 304 is still more than two times the expense of A36... 316 or any of the other alloys are only going to be worse.
Gumby is offline
Old 06-13-2008   #38 (permalink)
Detritus Maximus
A correctly designed mild steel non-turbo header would be nice. Short of that, I'd be happy with a tubular version of the stock exhaust manifold. Keep the same headpipe flange location so that it could be bolted in place of the stock manifolds and it would fit any 1.5-1.9 Opel.
Does anyone know if a thin copper gasket would work well with the exhaust/intake combo on the Opel? I really liked the copper gaskets used on the Alfa exhaust, but I don't know if it would be good on the Opel given the manifold arrangement. A single gasket like the stock one (is a copper gasket okay for the intake portion?), or a separate copper gasket for the exhaust only (would this cause too much of a problem with a decent seal for both gaskets?)? I don't mind having to make the raised compression rings by hand, that is relatively easy.
Would the copper be good for a turbo set-up?
"No, it's not fiberglass."
opelbits is offline
Old 06-13-2008   #39 (permalink)
Supercharged 2.4
Gumby's Avatar
It sounds like you basically want a tubular "sprint" manifold.
I think the plain header project is in the works. I'm not heading that one up so I can't really speak for anyone. Personally I think those would be the easiest to make. I still haven't heard back from my welder friend. I'll be calling him tonight and post an update afterwards.
Gumby is offline
Old 06-14-2008   #40 (permalink)
Oldpiler
oppositelock's Avatar
oppositelock
Is anyone other than Rallybob interested in stainless steel flanges?
You can count me in for a stainless flange for sure. I want to make a header for my rally car and stainless has better scavenging and less radiated heat.
Be warned, it makes a mess and a lot of smoke so have plenty of ventilation. Trust me, it works. I used to restore old British cars.
- Dave Clark
current Opel stable:
1980 Ascona B rally car
oppositelock is offline
Old 06-14-2008   #41 (permalink)
Detritus Maximus
Well, if the regular header doesn't pan out, I think a tubular version of the sprint would be nice. The prices for those are getting high enough to justify checking out the viability of a tubular replacement. The primary tubes could be enlarged a little to mate up to a larger headpipe. It wouldn't be equal length, but it would fit more cars (which might mean more sales and a lower cost?). It might weigh a bit less than a cast iron sprint, too. Unless I did the welding...
opelbits is offline
Old 06-14-2008   #42 (permalink)
Yup, and most 'junkyard' turbos are even bigger by virtue of their vehicle-specific bracketry and flanges. This is about as small as they get while still flowing enough to make decent power.
I gave up on making the manifold for my wagon equal length, as the benefits of making the bends less severe (better flow and faster spool) outweighed the benefits of 'equal length' primaries in a street turbo application. Plus, have you looked at some of the OEM cast manifolds out there? Some are horrid-looking, yet still make very good power.
I paid $835 for mine last August. Probably more expensive now... got it through TurboKits.com, great to deal with! List price was about $1000 BTW.
HTH,
Old 06-14-2008   #43 (permalink)
opelwasp's Avatar
Would the IHI VF24/24/29/38 turbo fit? Or even Mitsu TD04? A GT/Manta?
opelwasp is offline
Old 06-14-2008   #44 (permalink)
I used an IHI VF22 on Gregg's turbo Manta. As small as that turbo really is (same as all the VF series BTW), the appendages really add up to the overall space it takes up. By this I mean the flanges, the wastegate and actuator, and the oil lines and coolant lines. The TD04 (Subaru-spec) is the same size too overall, although the housings are a bit smaller than the larger IHI's. The difference is negligible when fitting the turbo. I can't comment on the TD04 applications from other vehicles.
TD04 housing on left, complete VF22 on right.
The VF22 relative to the 1.9 EFI intake. For a 'small' turbo it takes up a lot of space!
The Garrett GT2554 turbo is smaller overall than any of the Subaru TD04 or V-series IHI turbos BTW.
Old 06-14-2008   #45 (permalink)
Supercharged 2.4
Gumby's Avatar
Update: I still haven't heard back from the welder. I suspect he may be on training with the National Guard since he doesn't usually take this long to get back to me. I also know another welder looking for additional work. I left a message with him today. At the very least one of them should get back to me.
HTH,
Still not a terrible price even with the manifold it would be well under 2k.
What kind of power would you realistically see on a mostly stock engine (EFI is a must as I see it) at 8lbs of boost?
Gumby is offline
Old 06-15-2008   #46 (permalink)
EFI is a must for safe tuning and driveability. I consider an intercooler a must as well, even at 'only' 8 psi. Even though it might not ping initially with 8 psi of boost and 93 octane, if you have lower octane or you make a hard pull at max boost up a hill the heat buildup will likely cause detonation the next time your foot is in it. But figure 145-150 whp with an intercooler and 8 psi. With an appropriate exhaust (min. 2.25", preferably 2.5") of course, stock exhaust will choke the power, make it laggy, and make it run hot.
I was planning to run 14 psi, still well within the turbo's efficiency range and it should be almost lag free. It would actually be 'laggier' with less boost.
Old 06-15-2008   #47 (permalink)
neuropel's Avatar
How much of a factor is the 1.9 EFI plenum when turbocharging? Are there any suggested tips or changes (i.e. porting) to make to the plenum?
Todd K.
-Abraham Lincoln
________________
1972 GT 2.4L
neuropel is offline
Old 06-15-2008   #48 (permalink)
Todd K.
You'll max out the turbo before the intake. Stock intake can feed 175-180 flywheel HP naturally aspirated. With forced induction more is easy! Remember it's pressurized beyond atmospheric at that point, you're not relying on the engine's VE to draw air into it as much.
Unless you have a big-valve head and a big cam for high rpm use and a big turbo, don't worry about it.
Old 06-15-2008   #49 (permalink)
Supercharged 2.4
Gumby's Avatar
I also plan to run water/alcohol injection as well. I also still have my 2.4 sitting on the floor and all of this talk is making think what kind of potential I'd see from that engine. Has anyone ever run an A/C system to cool an Air to liquid intercooler below ambient temperatures?
Gumby is offline
Old 06-15-2008   #50 (permalink)
Supercharged 2.4
Gumby's Avatar
Update: We are good to go on the turbo manifolds. The price will be $200 + material cost (flanges and tubes) for mild steel.
Gumby is offline
Tags
cnc, exhaust manifold, header flange
