Unanswered: cam timing clarification
Needing a little guidance here as far as cam timing. Cam in question is cam techniques, f306/290/6. 4* advance built in C/L for intake is 102* Seein' as how I need the exercise, I used the flywheel method of degreeing. (up, down, up, down) good for the abs. At 2.5* per tooth, 40 teeth gives me 102*. That is exactly what I got on the flywheel at the c/l point. Question is: ...the 4* advance? Is that what put the c/l at 102*? Or should the 4* be added to the 102*. Otherwise all is happening right when it should be. Thanks, Don. |
Hmmm ...
Good question - the usual way to grind a cam with 4 degrees advance would be to shift the whole profile with respect to the cam dowel. So if you install that cam 'straight up' the specs would measure out at 4 degrees advanced - i.e. early.
Once the cam is installed then the centre line should be at 98 degrees by measurement - I would think. Best ask Cam Techniques to be sure! They may have factored the advance into the actual installed position ....
Take that 2.5* per tooth figure one decimal further, OK? Call it 2.57*. See if that makes a little difference.
You'll also need a compression ratio around the 10.5:1 to make it work. Last edited by wrench459; 06-13-2008 at 10:05 PM. Reason: info |
Here are some Cam Techniques profiles if this can help you,
Hiro. http://www.opelgt.com/forums/139401-post4.html |
I just called Cam Techniques Friday....they're closed until the 26th of June, so you'll have to wait.
