Unanswered: 1.9 w/ 2.2 Long Stroke Crank
This conversion will be very low budget, I will only be using the parts I have. From the 2.2, [1 & 2] I will be using the crankshaft and the head, and maybe some other parts as well. From the 1.9, [3 & 4] I will be using everything exept wat I will use from the 2.2.
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by 2 Fast 4 U; 08-11-2008 at 05:37 PM. Reason: Add photo |
Started with taking of the 2.2 head, the PO used two types of headbolts, two bolts had the triple square and the other 8 were the inside hex bolts, almost wrecked one because of the different bolts.
To be able to turn the crankshaft, I loosend all the nuts from the rockers, so I could seperate the timing chain lock. [#1] After removing the head bolts [and the two extra in the front], I could lift the head off of the block [after tapping it with a hammer]. The piston tops have a lot of carbon on them as well as the 4 combustion chambers in the head.
While I was turning the crankshaft I noticed that the hydraulic valve lifters were moving very smooth up and down, after removing the head and putting it on a workmate, I could remove all the valve lifters very easily, for what I can see they are in very good condition, I made a photo of one, the exhaust valve lifter from the 4th cylinder.
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by 2 Fast 4 U; 08-12-2008 at 04:55 AM. Reason: spelling |
1.9 stroker
![]() Also the picture of the lifter botton looks like it has some wear, make sure you put the lifters back in the same hole they came out of to avoid excessive wear.
![]() Uh, Erick, refresh my memory, why is it that you're not just using the 2.2 engine in its entirety, i.e. rebuild the 2.2 instead of all the trouble of shaving 1.9 pistons and fly-cutting valve reliefs?
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 08-11-2008 at 11:15 PM. |
#6 (permalink) | ||||
That is what I was thinking too. Have to dissapoint you, its from the cleaning company that cleans the offices at work, it was throwen on the scrap metal container, it looked all right so I brought it home, it comes in very handy.
#7 (permalink) | |||
First of all I just want to see if it can be done, and second I want to keep the 1.9 block stock for technical reasons, if I use the 2.2 there wil be power questions at the APK [Dutch MOT], using the 1.9 block I can avoid that and still [almost] have the the power of the 2.2, even though I only have roughly a few cc's more than 2100 cc, but it is more than 200 cc more than the 1.9. So, in fact, I'm doing the same as everybody, only with the few resources I have for doing this and, to be honest, you have to start somewhere in order to get experience so you can step up to the next challenge??
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by tekenaar; 08-13-2008 at 11:51 AM. Reason: costed - cost = present and past tenses (heden en verleden tijd?) |
#8 (permalink) | |
#9 (permalink) | |
That's one thing I'll sure do!! ![]() I hope so
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by 2 Fast 4 U; 08-13-2008 at 05:20 PM. Reason: Add quote |
Did a little work on the 2.2 this morning, turned the block upside down and removed the oil pan and had a look at the crank shaft [#1-3] and the inside of the oil pan [#4]
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by 2 Fast 4 U; 08-14-2008 at 05:01 PM. |
I'm having trouble removing the pulley from the crank I don't know how to get it off the bolt is not budging, I already bent a screwdriver trying
It's easier to hold the end of the flywheel than the crankshaft bolts, more leverage. It's easier still to get a flat piece of metal and drill three holes in it, two for two adjacent flywheel bolts and a third for one of the engine-to-bell housing bolts. Crankshaft can't move then, so you can put enough leverage on the bolt to break it loose.
@ oldopelguy thanks for the tip
![]() I went further with the head, and removed the rocker, nut and some kind of washer [you can see it in the photos]. Because of the oil residue on everything, I tried, with success, to clean things up, in photo #1 you can see the result, this was done with OXI-FIX a additive for washing detergent for clothes, it contains natriumpercarbonate and some other stuff, added to water it free's oxygen for cleaning. In photo #2 the rocker has been done with a dish washer detergent, the result is the same so I'm going to use the oxi-fix [it's cheaper] In photo #3 & 4 you can see my "dish washer"
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by 2 Fast 4 U; 08-14-2008 at 05:02 PM. Reason: spelling |
After the "dish washing" I removed the exhaust valve of the 4th cylinder, not easy even with the special tool [I'll take some photos, removing a valve, tomorrow]
In photo #1 & 2 The complete line up for operating the valve [exept the cam] 1: hydraulic lifter 2: rocker with nut and washer 3: valve spring retainer halves 4: in the front the rotocap this sits between the head and the valve spring, and lets the valve rotate 5: valve spring cover [behind rotocap] 6: exhaust valve [GM T-T 29100] 7: valve stem rubber [next to valve spring cover] 8: valve spring, there are some spots of paint on it does this mean anything?? In photo #3 you can see the "washed" stuff, the only thing that didn't go is the carbon build-up on the valve, how does one remove that, without scratching the valve to much??
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by 2 Fast 4 U; 08-13-2008 at 06:55 PM. Reason: added text |
Quick note on your three valve train pics, first two pics show correct spring mounting orientation . . . in third pic, spring is shown upside down. Opel CIH valve springs are installed with close-wound coils at the bottom . . . just a reminder.
#17 (permalink) | ||
![]() , but it didn't register , thanks for the reminder Otto![]() Haven't done anything on the engine today, [due to a little surgery], but I looked for threads and other stuff on engine work, parts and stuff like that . . .
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by tekenaar; 08-15-2008 at 10:54 AM. Reason: sp |
I have been working on my valve spring compressor today, because when I removed one valve the thing broke down on me, so I repaired it today, the right way
here some photos:
I used a 34 mm socket and cut a ring ± 10 mm off the socket #1
from a 24/27 mm box spanner I cut of the 27 mm piece #2 spot welded the two together #3 and test fitted on a valve spring top #4 cut the front a way as the original looks like #5 and welded the two together
#20 (permalink) |
Here the final welded valve spring compressor #1
Ready to remove the valve lock pieces #2
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by 2 Fast 4 U; 08-15-2008 at 06:46 PM. Reason: photos and text |
#21 (permalink) |
Removed the remaning 4 valves today, and cleaned one set completely.
I tried to remove the carbon built up with oven cleaner on a valve today, didn't do anything at all, only removed some grease that was still on the valve, so I'll be wire brushing the valves to get them clean, and try to pollish them as well. Next on the list is to remove the cam shaft and clean the cam and the head. ![]() Question 1: I put the parts, that I cleaned, in a cleaned old soup can, filled with ATF [Dextron], can I use the ATF or should I use normal engine oil? Question 2: And if I can use the ATF do I have to clean the parts and use engine oil when I assemble the engine or just keep the ATF on the parts??
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by tekenaar; 08-16-2008 at 06:26 PM. Reason: soep - dutch |
#22 (permalink) |
ATF is a good medium to store parts in, but I would clean and re-assemble with engine oil. I'm not sure how the ATF would react to the valve seals. Better to be safe than sorry and lose the valve seals.
#23 (permalink) | |
storage of cleaned parts
#24 (permalink) |
I did't put the valve seals in with the rest of the material as I'm planning on renewing them, but I'm keeping them for spare they are still very fexible.
#25 (permalink) | ||
![]() ![]() Can't get STP out here, what is it some kind of oil, what is Moly grease??
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by 2 Fast 4 U; 08-18-2008 at 04:34 PM. |
