Old 12-31-2008   #1 (permalink)
opeldidit
Real Name: mike
mkmsam is on a distinguished road
Question Unanswered: Camshaft Info
I purchased a cam from paeco Industries on 06/14/85 does anyone have info on the lift/duration? the# from the paeco invoice is OP-6500 the# on the cam is XS270,10 and F9648 Hope I did this right. Thanks
mkmsam is offline
Old 12-31-2008   #2 (permalink)
Uber Genius
First opel 1981's Avatar
Lift .290"
duration .050" - 236
Reed Performance Products, Inc. - Solid Flat Tappet Profiles
First opel 1981 is offline
Old 12-31-2008   #3 (permalink)
SpringGT's Avatar
From the 1985 Paeco catalog, the 6500 cam is the mid performance cam of the three that they offered. (the 6000, 6500 and 7000). Their description of the 6500 is as follows:
"OP-6500. For slaloms and heavy street use. This grind gives tremendous acceleration and a very nice boost in top speed. Best power range is 3200-6500 RPM and it will rev to 7300.
INT: 27/63, EXH:67/23, Duration 270, Lift .435".
Necessary mods: 10-11:1 compresion, full Paeco valve train, extractor exhaust header, racing ignition, weber carbs. A modified cylinder head and a primaflow exhaust system will give even more power, but are not mandatory. You must use solid lifters with these cams."
The cam cost $120(exchange) in 1985 and a new header was $120.
A new Weber DGEV 32/36 cost $225 and new DCOE 40's and 45's were $240. Eat your heart out!
Hope this helps.
SpringGT is online now
Old 12-31-2008   #4 (permalink)
opeldidit
Real Name: mike
Talking
Thanks thats alot more info then I got when I called them.[I payed $140] - a $20,00 coupon Ya $120
mkmsam is offline
Old 12-31-2008   #5 (permalink)
Uber Genius
Looks like I provided wrong info on the cam. My bad.
Old 12-31-2008   #6 (permalink)
Nope, you got it right.
XS270 - .290" lift at lobe/.435" lift at valve, 236° @ .050" duration, 270° advertised duration. 110° LSA.
2 out of 2 members found this post helpful.
Old 12-31-2008   #7 (permalink)
opeldidit
Real Name: mike
Is this a good one
Will this be a good cam for my 1970 1.9. Bore is 3.6855 stroke is standard pistons are from ross domed @10.5 Cr head cc is 55 head is ported to rallybob's street porting 1.9 big valve head intake is ported with tent as per rallybob valves are 2L from ogts 38 dgas from ogts Aluminum flywheel s10 clutch and a header from 1985
mkmsam is offline
