+ Reply to Thread
Page 1 of 2
1 2 LastLast
Results 1 to 20 of 26
Thread: Legere Spec 2.4L pinging
    Non Civilian opelwasp is on a distinguished road opelwasp's Avatar
    Mar 2003
    Between Chico and Sac, CA
    1,667
    OK here it is. I have a 1.9L to 2.4L conversion. Combo cam from OGTS and dished pistons. I am using a 75 EFI distributor with the Crane XR700 ignition.
    I can't set the timing according to the manual because the machinist who drilled my flywheel for my S-10 clutch drilled right through the timing ball. So I have to do it by ear.
    I have the timing set to the point I can drive around town and on the highway fine, but...
    I can set it so it wont ping under hard acceleration, but it will miss and buck at about 105 mph and will not go any faster.
    Or I can set it more advanced and I can acheave speeds much faster but it will ping terribly during hard acceleration.
    What gives?
  2. #2
    Uber Genius First opel 1981 is on a distinguished road First opel 1981's Avatar
    Apr 2003
    Portland, Oregon
    779
    Is your vacuum advance working correctly? It sounds like you might have a sticky one, or possibly your centrifugal advance could be gummed up.
  3. #3
    Tennessean hrcollinsjr will become famous soon enough hrcollinsjr will become famous soon enough hrcollinsjr's Avatar
    Jan 2003
    Chapel Hill, TN
    2,670
    hrcollinsjr has made a donation to the forum!
    105 mph? Hmmm, what's the speed limit out there?
    Have you checked to make sure your mechanical advance mechanism is working properly?
  4. #4
    1000 Post Club wrench459 will become famous soon enough wrench459's Avatar
    Jul 2005
    Milner, GA.
    1,795
    Blog Entries
    12
    Quote Originally Posted by opelwasp View Post
    What gives?
    Fuel starvation comes to mind.
  5. #5
    Pleasant Valley, CT
    7,561
    Three things should be attended to IMO, most of which others have already addressed.
    1) Make a proper timing mark...guessing the timing is not the thing to do on any performance engine!
    2) Recurve the distributor. A 1975 distributor has 25 degrees of advance. Set it at 5 degrees BTDC, and the total timing will be 30 degrees. With a small cam and 91 octane CA fuel, there's a narrow window for correct timing. I'd pull 5 degrees out of the mechanical advance, and set it at 10 degrees BTDC for starters. It would leave you at 30 degress total still, but a bit more initial advance to help it from a standstill. You may need to slow the curve down too, I'd start by increasing the spring pressure a bit.
    3) If you don't have at least a 25 gph fuel pump and 3/8" fuel lines on a Weber 38 DGAS, then you are emptying the fuel bowl out most likely. STOP driving it fast until you cure the problem. You will melt a piston and destroy the engine!
    The first time I starved an Opel of fuel at high rpms it bobbled for about 3 seconds, and in that brief time I melted the electrode off the #2 spark plug. It doesn't take long to do damage without fuel.
    HTH,
  6. #6
    I ran into a similar problem after beefing up my 71 low compression motor to close to 2.0 (1.9 bored 60 over), with flat top pistons, OGTS combo cam, and a 38 Weber, stock distributor, and Pertronix.
    Even after tinkering with the timing, only higher octane fuel got rid of the pinging. Now I am running about 1/4 tank 108 race fuel, the rest 91 octane (which gets me to about 95), and my motor seems happy at any driving conditions.
    Dieter
  7. #7
    Supercharged 2.4 Gumby is on a distinguished road Gumby's Avatar
    Mar 2006
    Oregon
    614
    Put a dial indicator on the block and measure the actual top dead center of the piston (it's really easy). Mark your flywheel for future reference.
  8. #8
    opel free after 26 years baz is on a distinguished road baz's Avatar
    Jun 2002
    sunderland england
    5,074
    and your front pulley and timing cover for easy setting
    B.O.O.B. founding member
  9. #9
    Mar 2003
    1,667
    Quote Originally Posted by Gumby View Post
    Uh...I really didn't feel like removing the head just to set a timing mark. I had the flywheel done after the engine was assembled.
  10. #10
    former opel racer jeff denton is on a distinguished road jeff denton's Avatar
    Nov 2002
    near some glaciers
    2,839
    You can use a valve as a piston stop to find TDC. Just be careful, and think about what you are doing.
  11. #11
    Mar 2006
    Oregon
    614
    Quote Originally Posted by jeff denton View Post
    If you can get a indicator on it a cam lobe would be more accurate.
  12. #12
    Saint Michael, MN
    1,724
    Blog Entries
    By "think about it" I assumed he meant getting the piston very near the top of the cylinder, removing one rocker arm and valve spring, and letting the valve fall on top of the piston. Then by carefully measuring the valve stem extending out of the head as you move the piston you can use it as an indicator.
    Alternately, with solid lifters, you could over tighten the rocker arm to get the valve partially open, and then mark the crank where the piston hits the valve (gently), back the crank around the other direction until the piston hits again (gently), and split the difference for where TDC must be.
  13. #13
    Opeler grslightng02 is on a distinguished road grslightng02's Avatar
    Mar 2005
    Sacramento, California, USA
    674
    Don't y'all forget CalifornayA is about 70% flat farmland. We have our of movie stars, palm trees, and beaches.... but we also have our share of redneck country roads.... Smokey and the Bandit territory.
    And of course OpelWasp has his share of Buford T. Justice contacts, bein' non civilian and all !
  14. #14
    long time Opeler deaner is on a distinguished road deaner's Avatar
    May 2006
    Fallbrook, Calif.
    297
    You can use a spark plug to do this. I've taken and old plug clean out the center and replace with an extended bolt. (trial and error on the length) install it in #1 hole. Rotate the engine until it stops. make a mark on the front pulley or flywheel. rotate in other direction until it stops. mark it again, exact tdc is half the distance of your 2 marks.
  15. #15
    Pleasant Valley, CT
    7,561
    Quote Originally Posted by deaner View Post
    Note: Rotate engine slowly....
  16. #16
    Pleasant Valley, CT
    7,561
    Addendum to above:
    4) Put in a bigger cam suitable for a 2.4. It will stop pinging. It will be much faster....
  17. #17
    Mar 2003
    1,667
    Addendum to above:
    Yah, I'll run that one by my funding manager.
    I'll have to wait till the Geo is back up. The plan is to put the motor into the Manta so I can drive it to the Tacoma meet.
  18. #18
    Mar 2003
    1,667
    Would using a different year vacuum advance distributor work?
  19. #19
    Jun 2003
    New Zealand
    5,690
    Destrction Imminent!
    Do you 'feel' like rebuilding the entire motor after burning a hole in a piston OR wiping out a rod bearing ??
    'Pinging' is just like swatting the tops of the pistons with a 7lb hammer - hard and often!
    1) Do not drive it until the problem is resolved
    2) Use the piston stop through a plug hole method of finding TDC
    3) Re-curve distributor to Bob's specs
    4) Ensure an adequate supply of fuel at high speed
    5) You may need a longer duration cam or less compression to fully 'cure' the pinging.
    Please - some of us have been there before - It is the mistake only made twice ... the first and last time!
    A different Opel distributor has even more advance in it - WORSE!
  20. #20
    Jan 2003
    Chapel Hill, TN
    2,670
    The vacuum advance distributors have way more advance than is needed. There is a chart somewhere, maybe in the tech. section, with the specs copied from Mitchell's Manuals for each distributor. It has them listed by years with identifying Bosch P/N's as the distributor may not match the year of the car or engine that it was originally installed in.
+ Reply to Thread
Page 1 of 2
1 2 LastLast
