'72 Opel GT (Sara)
Unanswered: Carb needs tuning?
![]() Anyway, besides relating my tale of victory this leads to a question. In third gear I was at about 5K+ RPM doing around 90MPH when the engine just went "flat". My foot was to the floor and I wasn't at redline but she wouldn't accelerate further until letting up on the accelerator and shifting into fourth. It felt very similar to hitting a rev limiter on a modern car. Any ideas on what might cause that? Is it carb jetting possibly? Note that when I installed my CAI my idle jumped from ~800 RPM to ~1,500 RPM (which I take as a good sign BTW on the CAI impact). So, I followed the instructions on the REDLINE website and adjusted the mixture and idle screws to get a good idle. Other than that, I haven't done anything else to tune the carb since adding the CAI. Any chance that has something to do with it? I guess I hadn't hit this problem before because I rarely push it (probably hadn't opened up the secondary since the CAI install). Anyway, it's not a big deal as it has no impact on my normal driving but I'm just looking for some opinions. Thanks, Matt
#2 (permalink) | |
![]() First get someone to check the total ignition timing. Did it make any strange noises or just stop accelerating? The rate of acceleration slows quite a bit above 5K. A free flowing exhaust would help some and the next step would probably be a different cam. Harold |
![]() Harold |
I agree that your jetting may need to be fatter on the Sec. side of the carb. and make sure your dist. has not moved and dropped your timing down . HTH
John
'72 Opel GT (Sara)
This was definitely a late model VW with shiny red paint BUT I think something happened forcing him to back off. Or, maybe he hit his rev limiter and didn't react fast enough to get it into the next gear before the backfire occurred. Still, when the Braves win on an error by the other team in the bottom of the ninth, it still puts a win in the win column
.The engine definitely went "flat" not a case of slowed acceleration, rather NO acceleration - it just sat there. There were no strange noises either. Thanks for the suggestions on the possible causes. Matt
Matt,
I forgot to add that you should check the acc. linkage for Carb. full throttle , bushings may be worn or out of position ..It's always the simple stuff HTH John
Weak Ignition Spark?
What do you have for ingition? Points & stock coil? pertronix and stock coil? An iffy spark and a lean mixture at higher revs might give that result..
Paul |
#13 (permalink) | ||||
'72 Opel GT (Sara)
Sounds to me like it may be a fuel delivery issue. I had a similar problem recently. It turned out to be my cheap electronic fuel pump and a dirty fuel filter. The car ran great at normal driving conditions, but under hard acceleration the motor would “flatten out” until I lifted off the gas pedal. Just my thought……..
Ron |
'72 Opel GT (Sara)
I got some good advice here and from John via PM which I plan to follow up on. While under the car today checking out all the suspension bolts, etc. (getting ready for tomorrow's GA meet) I looked up and noticed the front-most exhaust manifold bolt was hanging on by a thread. I tightened it back down but was wondering what symptoms (if any) that might contribute to. The rest of the bolts were tight BTW.
Bolt might fall out and hit VW that is trying to catch up to
you !! ![]() John
#17 (permalink) | |
'72 Opel GT (Sara)
BTW, I recreated the scenario today by running 3rd up to 5K RPM (after tightening down the manifold bolt) with the same result - "flatness". I need to get a bigger jet on that secondary I think .
#18 (permalink) | |
Does it flatten out if you rev it to 5000 in 1st gear? If it does flatten out in 1st as well, then it's probably jetting or ignition timing. If it revs out in 1st gear fine, then it's probably fuel delivery/starvation.
I had the pleasure of following Matt's '72 GT today.
From my angle it moves out very smartly in the lower gears(no smog motor under that hood). More that likely a fuel delivery problem. What about the vette and the biker girl on 985 Matt on the way home? What was up with that? Last edited by wrench459; 07-25-2009 at 09:59 PM. |
#20 (permalink) | ||
'72 Opel GT (Sara)
