1971 GT
Unanswered: AEM Air/Fuel Monitor installed
I'm not much of a welder (only having done it once before) so placing the bung on the exhaust was the time consuming part. (Which I #%@#ed up by putting it at the wrong angle when my clamp moved so may have to be redone ).Anyway other than that it went ok. The unit I bought is an AEM unit that has the sensor and gauge as a kit. I got it on E-Bay for $157 which is a decent price. pic 1 I made a little pod for it out of fiberglass which sits in the ashtray hole and angles it toward the driver and wired in a switch so as not to crowd my fusebox any further. Pic 2. can't seem to upload photos right now....add them later Now I just have to figure out what to do with it. ![]() BTW, when warm and idling at 1000rpm it reads about 12.5, then when I give it gas to about 2000-2500 rpm it drops to about 10.5. Rich I guess. It's a place to start tuning this DCOE.
#2 (permalink) | |
Tuning is half art and half science. Make sure WOT stays under 13:1 and 10.5 is very rich for an NA motor. When you start data logging over time with a big cam/carb you'll find wild swings from rich to lean. Check around you'll find some very good charts on this site with real life Opel A/F readings.
Tinkering is my name..fun is the game |
1971 GT
Tuning with the A/F monitor?
Anyone care to give a quick "How to" on tuning with the A/F monitor?
After finally figuring out that the car won't run well with the carb fuel bowl vent blocked off...... , I'm ready for some road tests.Is there a good system to tuning or do I just drive at different speeds and rpms and record the ratios?
I like to get the motor to idle first.
Then do a no load step. After getting the low rpm A/F close. I'll make a full throttle pull in third gear at the lowest possible rpm. performance :: another pull picture by wrench459 - Photobucket If at any time during the WOT pull the ratio goes over 16:1 abort!!
Tinkering is my name..fun is the game Last edited by wrench459; 09-27-2009 at 10:38 PM. |
1971 GT
From memory:
Specs for the car are in my signature plus header, 2.25 exhaust. pegged at ~125 hp by Mr. Legere.
#8 (permalink) | |
Remember, you don't need to worry as much about AV signal strength in an SSD carbed engine as each barrel feeds TWO cylinders (1200cc), doubling the flow volume per combustion cycle in each barrel compared to a DSD engine! I prefer staying around an 85% "choke-to-throttle-size" ratio in SSD engines, so 38 chokes in your 45DCOE! I'm running 42 chokes and the largest AV available in my 48 DSD, 10.6CR 2.2CIH GT. Search old posts for SSD tuning info as I posted complete jetting recomendations for a 40/45 SSD on a flat-top 1.9 some years ago . . . of course you'll have to adjust "jets and airs" to optimize mixtures for the much higher flow volumes in your carb.
#9 (permalink) | |
1971 GT
I know that main Weber deal in Calif. says to never use anything smaller than a 34. ps - not flat tops in this car........
#10 (permalink) | |
Get the "Speedpro Series" book titled "How to build & power tune WEBER & DELLORTO DCOE & DHLA Carburetors" by Des Hammill . . . It'll answer most of your questions about DSD and SSD installations and has some good volumetric jetting info for small and large 4-cylinder engines, individual and siamesed runner heads . . . and it's in English!
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 09-28-2009 at 06:13 PM. |
#11 (permalink) | |
1971 GT
I'm working my way through "Weber Carburetors" by Pat Braden at the moment. Another good one.
It's not perfect.
Lets see if you can get the carbs to do this. Forget the top graph look at the bottom one. wed_pull_5.jpg
