Unanswered: Street Engine On The Cheap?
I have a machine shop that can do the work I can not do myself. This is the build I have in mind. Going into a stock FI 1975 Opel Ascona. -Stock, used flat top pistons-If cylinder bore is in spec. (I will need to source these though) -Recondition rods -Crank checked and balanced-honed if only needs honing -Rod/Piston weights balanced -New Bearings-main and rod -New Timing chain and guides-prefer chain with master link (Know of source?) -Cam sprocket modified for degreeing cam -2.0 or 2.2 intake valves installed -Cam reground to a street performance spec and recondition lifters -Port intake side of head-As per Bob's thread -Mill head to build compression. Not sure how much though (Ideas for this build?) I will be trying to save some cash by sourcing parts on the UK/GR ebay and forums. Dang that VAT and shipping costs though. Hoping this will liven the engine up a bit. I will be adding larger 2" exhaust and a megasquirt with a Ford EDIS system at a later date. This car may see some autocrossing, but just for fun not hard core competition. Trying to get a fun build for under $1000.00. George. |
#3 (permalink) | ||||
No....its not a Buick....
Instead of milling the head...look for a 1.5...might be a cheaper way to go...especially since your putting in big valves. Just a thought....The amount of effort in getting the timing on square after a milling isnt a fun process.Toss a big cam in there...And find a 75 distributor......It'll be worth it..
Joe
What ...we got here...is........failure......................... to communicate.... Some men,you just cant reach...so you get what we had here last week...which is the way he wants it. Well, he gets it...I dont like it, any more than you men... Last edited by yellaopelgt; 4 Weeks Ago at 01:47 PM. |
#5 (permalink) | ||
Thanks for the info.
I was thinking that it should be pretty easy to source stock sized pistons and cheap. Most people rebore their motors and there is not much demand for stock sized pistons. If they do rebore their motors I would assume they would need their rods. Are the piston pins durable? I would not want some pin slap shortly after a engine install. Can the piston/rods be rebored to a common pin and just weigh each item separately or is it better to assemble complete unit and then weigh? I would assume the stock pin would not be reusable once pressed out and are new ones available even? As long as I can use pump gas I am good with 9.5 C/R if it livens up the motor. Do not really want to deck the block though unless there is something wrong with it. How far can you go with the head alone? I would guess .060 or is there something else involved here such as head cc? I have been reading some on piston knurling and molycoating them for tightening up piston clearances with out reboring. Anyone play with these ideas? This is oldschool stuff, but I love it! Thanks, George. |
#8 (permalink) | ||||
#9 (permalink) | |
Maybe I need to reword this reply. The 75 had a simple throttle switch like you said. Idle contacts or wot contacts. A true tps is much needed. The air flow meter is lacking ...I'm wondering if you could use a two wire MAF sensor for the proper input? I believe the megasquirt supports both map and tps(Alpha-N) speed density fuel injection. Just a ramble of thoughts....
Tinkering is my name..fun is the game Last edited by wrench459; 4 Weeks Ago at 10:51 PM. Reason: MAF vs air flow meter |
#10 (permalink) | |
Yes it supports both. Problem with the MAF is a big cam will make it flutter at idle and cause erratic signals to the brian. Plus the door causes air restrictions and air turbulence in the intake. These Opel's had a round about way to get the air from the front of the car to the plenum, looking to get rid of that too with a TPS. The plus side of a MAF is that as the engine wears it will compensate fuel flows. Air speed density will not. George. |
I've got an '03 caravan in the shop...simple speed density system.
The beepin thing is stuck in e-85 mode so its flooding like you would not believe. No adaptive fuel yeah right. This bugger bear use's b1s1 and the lack of switching to figure out the fuel input. Most cars use a fuel identifier.
Tinkering is my name..fun is the game |
#12 (permalink) | |
The set of five bushings cost about $15, and I used one drill bit to drill all the holes to size. Total time invested was about 10 minutes. It's so easy, a caveman can do it....
#13 (permalink) | |
Is the size of the enlarged mounting holes critical so that you still have the side of the bolt bearing on the side of the hole? Just curious.
Since MegaSquirt has a built in MAP sensor there is no problem doing what you want to do. The TPS that I used came from a 2.4 manifold that I got from RallyBob. I would think that some BMW's of the same era would have a usable TPS. MegaSquirt has a very simple system of setting up WOT and Closed Throttle positions and the amount of electrical resistance in the TPS does not matter, almost anything will work.
#15 (permalink) | |
I'm also running a sbc cam bolt locking plate for some extra insurance. ugh me thinks it works ood :-)
Tinkering is my name..fun is the game Last edited by wrench459; 1 Week Ago at 08:04 PM. |
Not really, the offset bushing takes the thrust loads, and the center hole locates the gear. Once the bolts are tightened down I've never had one move on me. Make the holes big enough for a worst case scenario (for example, using the 8° bushing), and you're all set.
Good to know, the Mr Gasket ones are $15.95!
#21 (permalink) |
See this thread post #21
http://www.opelgt.com/forums/opel-en...cked-head.html The thread is a must read theres some dang good info from some gearheads.
#22 (permalink) | |
#25 (permalink) |
Real Name: Neil
3.8l v6
GHCOE, Are you sold on having exclusively an Opel motor? I would suggest you consider what our late friend Ron De Lozier did with the 3.4L V6.
You can read about them here: Performance Articles - The Classic Opel Forums Although I would suggest the Generation II 3800 3.8L Supercharged V6 with 205HP, 19/28 miles per gallon. These motors can be found in 1996-2002 Camaro's and Firebirds (for rear wheel drive) and parts are abundant. I've found examples on craigslist of these motors from $500-1,000
"A dead OPEL in the driveway is a new enthusiasts next project!", NEIL |
