After hard wiring the system in last night. I had to play around some.
When you order the controller it has to be one of two options tps or map.
With mine being tps based. I uploaded the default ignition curve and tweaked it for
my use as seen in the picture above.
It runs very nicely without an tps sensor or map installed.
It acts just like the mechanical advance of a distributor.
As ya'll can see its running on one row of the 10x10 map.
Question is what mode is it running in?
Default,limp-in,Alpha-N or "it is what it is?"
