#126 (permalink) |
what would be the best way of heating it up? we have a 1.5 million btu forge, 200k btu forge, and several rose bud torch tips. Im afraid of melting it with the big forge, and our pyrometer isnt fast enough to detect the temp. we have an infared thermometer but it only goes to 500ºf. we have a 55 ton press but I don't see where that would help, but I do have a porta-power that may help.
1970 Opel GT 1.9
1980 Moto Guzzi V50 2000 Saab 9-3 2.0 turbo 2000 KTM 200 exc STOLEN |
#127 (permalink) |
Knowing the low temp aluminum melts at, I think the forge is risky. But if can get your hands on some Tempilaq (temperature-sensitive paint) and use a rosebud tip, that will work just fine. The key is to heat at the radii and gently pry the flanges apart with some sort of tool....as I said I have a simple spreader made from threaded rod and a coupler nut. I think you have wayy more tools than you need, the tough part is deciding what to use! Good luck.
Bob |
#128 (permalink) |
4246 Post Club
A LPG/air torch is probably best - the flame temp is much lower and you will hear the casting creaking and moving, if it has some pressure on it, long before melting starts!
#129 (permalink) |
A little late, but this was my solution today for jigging up multiple intakes for welding without warping. I used a piece of 3/8" steel plate, and fitted dowels for the flange alignment, with steel welded pads to keep the inner mounting flange edge from moving inward. Lastly, the intakes are bolted together at the outer flange edges.
I will be welding them tomorrow, so I'll let you know if it doesn't work out. |
#130 (permalink) | |
#131 (permalink) |
Per some suggestions from other members of these forums, I tried a different method of instituting a 'tented' plenum floor on an intake manifold. This required cutting the plenum floor out completely, which made it easier to port the manifold too BTW. I then welded in a piece of .060" thick aluminum from the underside of the plenum which was bent into the 'tent' shape.
#133 (permalink) | |
#134 (permalink) |
porting
The manifold is a good place to start.
The intake and exhaust ports in the head are badly restricted and there's alot of metal there to be removed. Just by looking at a strippled head you can see how restricted it is..A stock intake manifold actually has better airflow than the head. |
#135 (permalink) |
Bob;
This looks like a "do-able" mod for $$, especially if the customer sent you their manifold. What do you think? How much? Did you do this on a '74 manifold? I, myself, am looking to have this mod done, but, I don't have a sprint manifold. I would like to finish out the header flange I bought from you to go with this type of intake, but, I'm running the the stock "bolt together" manifolds. Gene |
#136 (permalink) | |
Bob |
#137 (permalink) |
Bob, how did you weld the center divider in charle's manifold? The fella who is welding the divider in mine can't figure out how to get the tig torch that far down in the plenum to weld, I believe it is a cover gas issue because the ceramic guide will be too far away from the point where the welding is occuring.
1970 Opel GT 1.9
#138 (permalink) | |
Bob |
#141 (permalink) | |
Intake manifold porting....good. Intake port porting w/stock valves....bad. The ports are already too big relative to the size of the valve. Sure, you can blend the bowls a bit, but enlarging the ports gains no airflow, reduces port velocity, and reduces power and torque. HTH, Bob |
#142 (permalink) | |
#143 (permalink) |
1970-GT
Another way!
OK just got back from the shop. Was working on things to fit my new 38DGES carb. I rough ported the the intake manifold, made up an aluminum spacer.
I was thinking about the tent in the plenum and came up with a different type of plenum floor insert! It is made from a 1-1/2 round aluminum sawed in half, milled flat and (2) 1/4-20 tapped holes. Then I drilled and counter bored 2 holes thru the plenum floor. It will reduce the volume of the plenum and split the air equally to both sides, like the tent design. No welding, easy to make and you can change it easily! Think it will work? Lyle |
