#376 (permalink) |
#377 (permalink) | |
It's not quite stock, it has been ported and fitted with 1.94"/1.625" Chevy valves. |
#379 (permalink) |
Help-Valve Guide
I am looking for the Chevy Bronze Valve guides for my 2.2 head. Earlier in this thread they are listed as .503 O.D. for 11/32 stem and 2 3/8" Long. Problem is when searching suppy houses they always list by make,year,model, engine.
What are those criteria for the guides I am looking for. TIA.
#380 (permalink) | |
#381 (permalink) |
This is so far the best piece of master craftmanship i've seen yet, it's a pitty that you need to put the valve cover back on the engine, but when are you going to finish this report?????
#382 (permalink) | |
#383 (permalink) |
well don't get a burnout, take some time of or take a weekend vacation just get some rest. If you go nuts who's going to help the forum with technical info??????
if you have time please take a look at this: http://www.opelgt.com/forums/opel-engine-performance-modifications/8215-2-2-efi-intake-manifold-versus-2-4-efi-versus-carb.html and give me advice thanks a lot
#384 (permalink) |
Keep Looking!
2 fast 4 U
Most of the answers you require are actually in the thread you indicated. Plenty more on carbs vs injection is available with the search function. Just a hint - Bob will get tired and go away if we keep insisting that he answers each little question that he has answered numerous times before .... do a LOT of searching then pose the question in general and a few of the rest of us may be able to help take a bit of the load from Bob's tired shoulders! I just noticed that this is rally Bob's Turbo Manifold Thread - would some kind moderator like to remove these last posts to a more appropriate Thread - or just delete it? Let's just "chill out" for a while ...... Eh?
GTJim Opel Owner since last Century! Copyright © 2000-2009 J D Henry All Rights Reserved Last edited by GTJIM; 12-05-2005 at 04:19 PM. |
#385 (permalink) |
The Getrag 265 tranny fits surprisingly well in a Manta's tunnel. The only real area of concern is the reverse light switch, it nearly strikes the driver's side of the tunnel. Of course, the other are which I knew would be trouble is the shifter itself. It sits 7" further back than a 4-speed shifter, but after some mods I did to it, that distance is reduced to 5.875". This is still enough to require cutting the tunnel, but not enough to have to relocate the emergency brake handle.
I modified the shifter into a short-throw shifter, but this presents its' own issues, namely increasing the shift tower height by 3/4" (the same amount I changed the shifter throw). Here you can see some of the mods I had to do during the mockup stages. |
#386 (permalink) |
At this point the factory shift boot retainer was laid in place, but it was turned around 180 degrees to coincide with the shifter location. Getting close.
I mocked up a 4-speed with mount and crossmember, and measured the output shaft height relative to the crossmember. I used a GM auto tranny mount and made a pattern for a new custom offset crossmember I'll be making. I'll be using 3/16" flat plate, bending it to match the engine tilt, and rolling the edges for more strength. |
#388 (permalink) | |
#389 (permalink) | |
#390 (permalink) | |
#391 (permalink) | |
I don't know you tell me
#392 (permalink) | |
Opelitis since 1984
Real Name: Charles Goin
#393 (permalink) |
Opelitis since 1984
BTW do we dare ask how much all that cost? (A round figure would be fine...)
I am sure its outside my budget.. but with a number in hand I can start adding it to the "When I win the lottery" list of to do things.. Charles
#394 (permalink) | |
#395 (permalink) | |
Opelitis since 1984
#396 (permalink) | |
There's no 'final bill' yet, as it's being done piece by piece as time and money allow. If Gregg has no money and I have no money, but parts are needed...the car sits until money is found. But that cost is basically for all the parts and my labor, plus outside labor (machine work, chrome, etc.). I didn't charge Gregg any money for parts, he paid what I paid. So that's the engine, ECU, fuel system, cooling system, tranny mods (he already had the tranny), tunnel mods, driveshaft, turbo and accessories, etc. And a ton of time of course. But of course I spent three days rebuilding/modifying the heater box, replacing the heater core, lining the heater with reflective aluminum tape, rebuilt the fan motor, and made an upper heater duct from scratch from aluminum sheet (the OEM plastic was cracked). How do you charge for this kind of stuff? There were remnants of a mouse nest in there, and the core had leaks and the fan was frozen....I could have left it 'as is', but that would have bothered me, so I felt obligated to repair it. What good is 300 hp if you have to smell mouse turds and you can't get the defroster to work? So it's those little details that kill me (financially), it pretty much has to be done, but who's gonna pay me for three day's of labor on a heater system? I'm a slave to my own anal-retentive ways. Bob |
#397 (permalink) | |
I'm with you on this. I went through Tech school and could have been hired by any of the local dealerships. But, what you're actually saying is you have a "conscience" in that you see something wrong, or something that NEEDS to be fixed, you fix it. I can't work for a dealer knowing that all I did was change out a broke part and warranty pays for it, but, it bothers me to know that the part will break again and you didn't fix what made it break in the first place. I can not do that to someone's car, Opel or not
#398 (permalink) |
Opelitis since 1984
The real trick is finding someone willing to pay for that kind of service.
I would love to find someone local I could trust to do a lot of the work I will need done for my conversion project. Also one reason I havent started the Blue Max.. no one found to trust with a 100 point quality restoration on the body. Charles
#399 (permalink) |
Charles, Bob, and Gene, That's one of the reasons Willit? is taking so long. Everything taken off is made functional if it isn't already. Of course it's not as good looking as Bob's "Workmanship", but it won't break shortly after I'm done, I hope. You can find artisans if you're willing to pay for their expertise, or they get interested in your project. I was lucky finding the welder and body shop that took the extra steps needed, and over the years we've become good friends that I'm not concerned about sending work their way. Bottom line here is what I told the youngsters working for me in the USAF. "The aircraft will take off, no problem. How it lands is up to you." Shortcuts just don't get it.
| Tags |
| cih, efi, Manta, turbo |
