Old 12-29-2005   #401 (permalink)
Some of the improvements, showing the new heater core, lined heater box, revised coolant inlets and outlets (made from copper pipe), and all components cleaned and coated with truck bedliner for sound attenuation and as a thermal barrier to keep the heat in. Note the new foam seals everywhere, the stock stuff was non existant, having dried up and crumbled off. Less leaks equals more efficient heat transfer.
Old 12-29-2005   #402 (permalink)
Today I got a new intercooler core for this project. Yes, I already had a WRX intercooler, and had modified it already, but when I went to test fit it earlier this week with an engine block in place and the radiator fitted, the WRX intercooler just wouldn't fit (too tall). I said screw it and got a new core, and will fabricate the end tanks from scratch. This new intercooler core is longer, but shorter in height, so it will provide the clearance I need. It will also allow for more horsepower potential, and with greater safety for the engine.
Old 12-30-2005   #403 (permalink)
asdasc's Avatar
Beyond Anal Retentive
Bob, what you did to that heater box is beyond anal retentive, that is a work of art. I was wondering when you said you spent 3 days on it.
I never thought I would be jeolous of another mans heater box....
Steve
asdasc is offline
Old 12-30-2005   #404 (permalink)
As always Bob, and I've said it numerous times, what you're doing is an art form. I can emphasize with you on the cooler. Margaret has oft told me working on a prototype is sometimes a real PIA. Next week the AC compressor brackets get built, I hope, depending on welder availability. Then the real fun of building an airbox to go to the throttle body from the Lenk Tuning Hood nostrils via a K & N air filter, with some sort of rain diverter in the mix. The only thing between what you do and what I do is skill, workmanship and aesthetics, your stuff looks much much better, by far, real far. Definately inspirational.
Old 12-30-2005   #405 (permalink)
Thanks. Wait until you see the defroster duct I made from aluminum! I need to take some pics of it, it's all done except for the upper flanges. I'm actually kinda proud of this piece of work, too bad it will be completely hidden under the dash!
Old 12-30-2005   #406 (permalink)
Bob;
Where did you get the little bead seal for all the edges of the heater box and all?
Old 12-30-2005   #407 (permalink)
Originally Posted by BQS4
Bob;
I found a huge roll of it in my dad's (woodworking) shop. I guess it's some kind of window seal material, left over from when he had a window/door business too.
If you want some, let me know, we have a ton of it. Just used contact adhesive on both surfaces, and voila....no more air leaks, and no sticky/gooey mastic sealer either.
Old 12-30-2005   #408 (permalink)
Works for me.
Gene Smith
1665 Norton Estates Circle
Snellville, GA 30078
Old 12-30-2005   #409 (permalink)
Definitely . . . not definately
Definitely true . . . but, once and for all, definitely NOT definately!
Old 12-30-2005   #410 (permalink)
Works for me.
Packed up and ready to go out tomorrow morning Gene. I probably sent enough for 3-4 cars BTW. If you have any questions on application of the foam, particularly at the diverter flap, let me know. That part was a bit of a PITA to fit, since with contact adhesive, once it's stuck...it's stuck.
Old 12-30-2005   #411 (permalink)
GREAT!! Then I can do my wife's Wagon too. She's driving it regularly now and I can pull the heater unit off this summer and redo it for better heat next winter. You didn't put that thick padding back on around the heater unit, you just used the "rhino liner" stuff correct?
Old 12-30-2005   #412 (permalink)
Correct, I used the spray-on bedliner. Between that and the aluminum tape I used inside the heater, the heat transfer is greatly improved. I tested it with a heat gun and an infrared pyrometer.
Old 12-30-2005   #413 (permalink)
Okay, here's the defroster duct pics. Not quite done yet, but not much left to do. I polished the interior surfaces before welding the two halves together, then the outside will get the bedliner treatment. This should aid in keeping the temperature high within the ductwork and improving the Manta's notoriously crappy defroster system. Not to mention the days of cracked defroster duct tabs is over.
I started by tracing the stock plastic duct shape onto two pieces of 3/4" solid wood (I used poplar). I cut out the two shapes, one to the exact dimension, the other approximately 1/2" smaller overall.
Then I used a 3/8" radius round-over router bit to create a radiused edge to the piece of wood that was the same size as the duct.
A piece of .050" thick aluminum was clamped between these two pieces of wood, and I proceeded to hammer the edges of the aluminum to wrap around the radiused wood edge. I should note that I first annealed the edges of the aluminum to make it more malleable, and used plastic hammers to avoid damaging the surface of the aluminum.
Another identical panel was made using the same hammer-form technique, and then I trimmed the edges of the panels with aviation snips, and filed them smooth.
Next step was to polish all the inside surfaces of the two aluminum panels, and then to clean them well and weld them together.
The final steps are to finish-weld the top flanges I made in place, and trim the overall length of the duct, then spray the bedliner coating and install.
Old 12-30-2005   #414 (permalink)
asdasc's Avatar
Better than original
Bob, I am guessing you spent more time engineering and testing than the guys at Opel did 30 years ago. A heat gun and a pyrometer....too cool!
It is one thing to look at it and try to add something to make it better, but then to do validation testing prior to reassembly is going the extra mile. I am sure you took notes on the before and after data so that you can refer to it later!
From now on, if you do two of everything you do, and auction off the spare, you will live a life of luxery!
Steve
asdasc is offline
Old 12-31-2005   #415 (permalink)
opelwasp's Avatar
could you send any of that foam strip my way,Bob? my 74 manta is in dire need too?
opelwasp is offline
Old 01-01-2006   #416 (permalink)
Opelitis since 1984
GoinManta's Avatar
Real Name: Charles Goin
Thats nuts... I cleaned core and a properly lubed fan runs me out of the car as it is.. I guess its hard to disagree with you stating your anal retentive..
Charles
CURRENT
'06 Pontiac GTO
'74 Opel Manta (Bens Manta)
Past
'73 Opel Manta (Blue Max)
'75 Opel Manta (Yellow)
'85 Bitter SC
'73 Opel Commodore B GS
'73 Opel GT (w/ Vinyl Roof)
At least 16 or So Parts Opels
GoinManta is offline
Old 01-01-2006   #417 (permalink)
Opelitis since 1984
GoinManta's Avatar
Okay, here's the defroster duct pics. Not quite done yet, but not much left to do.....
Everyone please let me introduce Bob Legere the Chip Foose of Opels
Charles
CURRENT
'06 Pontiac GTO
Past
'85 Bitter SC
Old 01-01-2006   #418 (permalink)
Opelitis since 1984
GoinManta's Avatar
Speaking of which.. ever contact Foose for a job.. YOU would seem to fit right in with his style, and attention to detail and fabrication..
CURRENT
'06 Pontiac GTO
Past
'85 Bitter SC
Old 01-02-2006   #419 (permalink)
2 Fast 4 U's Avatar
Thumbs up
Just when I was thinking that nothing could impress me anymore, he just does it again
Opel Ascona;
Only built from 1970 - 1975
2 Fast 4 U is offline
Old 01-02-2006   #420 (permalink)
Certified Opelholic
davegt27's Avatar
Real Name: joe blow
You got that right I had been thinking there had to be a way to come up with some under dash duct work for a GT so one could add AC without the big old ARA/GM thing.
Now I see another option.
Davegt27
davegt27 is offline
Old 01-02-2006   #421 (permalink)
You guys are all gonna give me a complex!
Thanks for the comments, but I'm no Chip Foose. I'm just a slightly mental car enthusiast who hates the thought of spending 40 minutes cutting his grass during the summer but thinks that spending a day-and-a-half making an aluminum heater duct is somehow considered 'normal'.
Yea, I got issues.
Old 01-02-2006   #422 (permalink)
No Access
Bob, great work as always and don't worry about a complex. It's only when you start building things in the living room because it's cold out that they look at you funny. Try explaining a 40 gallon parts cleaner and 2 motors indoors to a prospective girlfriend. Na your normal.
nobody is offline
Old 01-03-2006   #423 (permalink)
2 Fast 4 U's Avatar
Yea, I got issues.
Who's Chip Foose ?????
Opel Ascona;
Old 01-03-2006   #424 (permalink)
Erick;
Go to www.chipfoose.com and you'll find out. He's a car customizer/fabricator/artist PAR EXCELLANCE!!!!!
Old 01-03-2006   #425 (permalink)
hes a custom car builder in the states , can be seen on TV shows like Overhauling (shows here on discovery home and leisure)doing some very nice work,kinda like boyd covingdon on American hotrod but without all the bondo on the bodywork
Tags
cih, efi, Manta, turbo
