Old 01-03-2006   #426 (permalink)
2 Fast 4 U's Avatar
when I saw his picture on his site I reconised him.
Opel Ascona;
Only built from 1970 - 1975
2 Fast 4 U is offline
Old 03-10-2006   #427 (permalink)
David McCollam
Valve cover spacer
Bob,
How thick was that aluminum spacer that you welded to the bottom of the GT valve cover? I'd like to create a setup like that for mine if I ever get the roller rockers fixed.
Thanks,
Dave
David McCollam is offline
Old 03-11-2006   #428 (permalink)
Originally Posted by David McCollam
Bob,
Thanks,
Dave
http://www.opelgt.com/forums/66445-post355.html
Old 07-30-2006   #429 (permalink)
cihturbo is on a distinguished road
A big Hello to dear Opel-friends and RallyBob in America from Europe. I'm sorry for my bad english. I'm the Webmaster of http://cih-turbo-manta.tripod.comI have looking on this side for CIH-Turbo and finding the sites made by RallyBob and i must say it's very good making! Have you newest pictures or some more information of your project? Dear RallyBob, can i publish your project on my site - is this possible and OK for you? Or is anybody hear and have an other cih turbo- or supercharged project for my website?
Greets from Europe to the land of freedom - See ya VEDI
cihturbo is offline
Old 07-30-2006   #430 (permalink)
bosco's Avatar
bosco
Great work, Bob.
1973 Opel GT
1977 Datsun 280Z
Previously:
1971 Opel GT
1973 Opel Manta
bosco is offline
Old 07-30-2006   #431 (permalink)
This project has stopped for some time because of no money to continue. I will be disassembling the 2.0 block, and will replace it with a 2.5 litre block with forged 8.5:1 compression pistons. But the cylinder head shall remain the same, except for a camshaft change. Other projects are more important right now, and until more money is available, nothing else can be done.
I have also allowed another site in Europe to use these photos with my permission here: Retro Racing Opel club
For now, I will ask that you do not use these on your site. When it is completed and running though, then I don't see a problem using these photos as long as they are credited. If you want to supply a link to this forum though, that should be okay.
Old 07-31-2006   #432 (permalink)
Hallo RallyBob, yes is good - i will not show your cihturbo projekt thanks.
cihturbo is offline
Old 11-22-2006   #433 (permalink)
'77 Manta B - yellow
emircea's Avatar
emircea is on a distinguished road
lack of words
I just spent hours reading this... and I am speachless...
Keep up this amazing work, Bob. I'm happy I'm not the only one who forgets about him with his hands deep inside the car... And, maybe, a short mouvie with the beauty running, in the end? - just an idea...
emircea is offline
Old 02-03-2008   #434 (permalink)
tomking's Avatar
I recently asked RallyBob about dizzy recurving for a 2.4 stroker. This copied from this thread around page 8:
So Bob, what is the trick to removing that pesky little clip to separate the distributor cam assembly from the center shaft???
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18
1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P ♥ '73 GT 1.9FI 4S 3.44 ♥ '75 1900 1.9FI 4S 3.44
1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P
Top Home
tekenaar
View Public Profile
Send a private message to tekenaar
Send email to tekenaar
Find all posts by tekenaar
Add tekenaar to Your Buddy List
#156 (permalink) 04-26-2004
RallyBob
Project 1450 supporter... Join Date: Mar 2002
Rating: 0% (0)
No trick Otto, takes 5 seconds. Clamp the cam portion in a soft-jawed vise, remove the felt plug from the center of the assembly, take a suitable drift (I used a 3/16" drift), tap once with a hammer, the main shaft falls right out.....
Best done with a set of helping hands so the parts don't fall to the floor. I usually end up doing it myself, but I taped the parts loosely together so they don't fall far.
Now replacing the clip is another story. Sometimes it takes me 10 seconds to put it back on, other times 10 minutes. Thankfully this time it only took me three attempts. I just drop the clip in place over the end of the main shaft, then using a pair of tiny needle nose plier push downwards. That's it.
Here are some pics of the tool I made to reinstall that little wire snap ring that holds the cam shaft to the center of the dizzy. I used one of the nuts and stud that hold the gauges in the GT dash. Turned it down on the outside so it would fit inside the dizzy hole. Drilled a hole just larger than the OD of the wire snap ring. Then use the stud threaded into the other end and use this to push the wire snap ring home. Works like a charm.
TMK
tomking is offline
Tags
cih, efi, Manta, turbo
