Old 05-01-2004   #176 (permalink)
Very little to report on. I'm basically burned out from this project, I'm literally falling asleep standing up. Hopefully tomorrow will be better. Just need to catch up on some sleep I think.
Anyway, got a chance to go to my machinist's shop and glass bead an old flywheel I had laying around, then had him resurface it. It was previously lightened and balanced, and it now weighs 15.5 lbs. I'll be using a heavy duty pressure plate (30% stiffer) with a semi-metallic friction material on the disc. This is substantially stronger than the factory Sachs 2.0 litre HD clutches I used to use, but also costs less. Had it built by Action Clutch Exchange in L.A., they do nice work at a reasonable cost.
File Type: jpg 15.5 lb flywheel for turbo Manta 03.JPG (155.8 KB, 118 views)
File Type: jpg 15.5 lb flywheel for turbo Manta 02.JPG (147.5 KB, 95 views)
Old 05-02-2004   #177 (permalink)
As of today I finally have all the pieces for the fuel pickups fabricated, and most of the items fitted to the fuel tank, waiting only the one-way check valves.
The alternator brackets were completed, upper and lower, for the GM alternator.
I also completed the modifications to the throttle body for the fast idle bypass, and began working on a new center gauge panel. It will emulate the factory 'Rallye' panel, but will house 4 gauges rather than 3.
Sadly, I can't show any more of the progress, as I'm WAYYY over my limit for photos. So, at this point, I won't be updating this thread on a regular basis. I suggest instead, that those looking to see the final outcome of this project show up at Carlisle and see it in person!
Old 05-03-2004   #178 (permalink)
Site Admin
Gary's Avatar
Real Name: Gary
Originally Posted by RallyBob
...Sadly, I can't show any more of the progress, as I'm WAYYY over my limit for photos. So, at this point, I won't be updating this thread on a regular basis. I suggest instead, that those looking to see the final outcome of this project show up at Carlisle and see it in person!Bob
Bob, you are definately not over the limit. Please continue posting....
Gary is offline
Old 05-03-2004   #179 (permalink)
1450 Seeker...
madhatterpdc's Avatar
I think that was Bob's way of encourging those of us that are on the fence about making the trip to Carlisle, to take the plunge and do what we have to do to get there.
Keep it Blitzed
madhatterpdc is offline
Old 05-03-2004   #180 (permalink)
Certified Opelholic
davegt27's Avatar
Real Name: joe blow
more PICS more PICS more PICS
i want to see the Alt bracket
for some reason Marty Reimer has me making 5 GM ALT brackets
When you can go down to NAPA and figure out which ALT to use without making a change
davegt27
davegt27 is offline
Old 05-03-2004   #181 (permalink)
4ZUA787
pvcar's Avatar
pvcar
yes post more pictures i for some of us which can not make it want to see what its outcome looks like.
SPC Juneau
pvcar is offline
Old 05-03-2004   #182 (permalink)
I guess the governor has given me a reprieve....!
Finished Getrag short-throw shifter after welding and bending. Next to a stock shifter for comparison.
Old 05-03-2004   #183 (permalink)
The modified upper alternator bracket. I cut a stock Opel bracket down, and welded a curved GM alternator bracket to it. This is necessary because of the 'clocking' of the GM alternator's upper mount, it's further away that the Opel's Bosch alternator. I have custom brass mounts here too. They keep the alternator from oscillating at higher rpms, which I've seen happen with the original rubber mounts. This can cause premature belt failure.
As it turns out, the lower mount did not have to be ground at all to fit this particular alternator. This is odd, as every other GM alternator I've installed required some grinding to fit. I can only attribute this to the brand.
Still, the lower mount needs new bushings, I have custom delrin bushings that are offset to center the pulley correctly, and they have a 3/8" ID to fit the larger bolt required for the GM alternator.
Old 05-03-2004   #184 (permalink)
Here I made a reinforcement ring for mounting the access cover to,it will be welded to the inside of the tank flange. It's just a piece of 11 gauge steel, drilled and tapped to accept bolts.
You may ask, how are you going to fit a ring inside a gas tank when the hole it fits inside is smaller than the ring itself? No problem, I just made two slots 180 degrees apart, then slid it inside the tank.
File Type: jpg reinforcement ring for access door.JPG (150.9 KB, 104 views)
File Type: jpg access slots for reinforcement ring.JPG (146.4 KB, 106 views)
Old 05-03-2004   #185 (permalink)
shifter
Bob;
Two questions about the shifter as I'm about to do two of these at the same time, and they are both going into a Manta & Sportwagon. how much further back did you bend the shifter, in order for it to mimic the stock 4-spd? Also, how long of an extension did you use?
Thanks,
Gene
Old 05-03-2004   #186 (permalink)
Here you can see where I predrilled some holes in the tank flange, and clamped the reinforcement ring below it. Then I plug-welded at the holes, securing the ring to the tank.
Old 05-03-2004   #187 (permalink)
shifter
BTW, I'm not doing the short-throw, too much to get involved with for now....
Old 05-03-2004   #188 (permalink)
Originally Posted by BQS4
Bob;
Thanks,
Gene
I honestly have no idea on either count. I mimicked the stock shifter location by clamping it to the edge of a counter while seated, and reached for it. I then bent the other shifter until it had a more natural angle to it to fit my reach. Maybe another 10 degrees?
As far as the shifter extension, I made it extra long (about 10-12"?), it will be cut to fit when the car owner shows up and I can test fit it in the car.
Old 05-03-2004   #189 (permalink)
This is the fuel pickup line I made. It will be brazed into the tank where it passes through the tank wall, and then held up near the access door by a retainer clip.
Old 05-03-2004   #190 (permalink)
Details of the fuel pump and pickup. I made a steel fitting that's the same diameter as the pickup on the fuel pump (7/8"), and T'd it out so I'd have two side pickups and one central pickup. No, those hose barbs are not the correct size for the side pickups, I just used them for fitment purposes. The pickups are all 5/16".
The second photo shows the approximate mounting angle of the pump, and it relates to the tube I fitted to the the top of the tank. The steel clamp around the pump body will be welded to a bracket hanging from the access hole flange, then the pump is secured by tightening an allen bolt within the clamp.
Old 05-03-2004   #191 (permalink)
Bob;
Thanks,
Gene
Gene, I just rechecked the modified shifter. It's extended only about 8.5" from the top of the lower shift rod (which normally inserts into the upper shifter with rubber bushings). I also rechecked the increased bend angle, it's more like 20 degrees added rather than the 10 degrees I estimated earlier. When I bent the arm, I also bent it a *bit* more towards the driver's side.
Old 05-03-2004   #192 (permalink)
shifter
Bob;
I gotcha, approx 20 degrees back from normal, you added 8.5" to the stock lower half (to be cut to driver's preference later) and bent it back towards the driver a "bit", lol, sounds easy enough.
Thanks,
Gene
Old 05-03-2004   #193 (permalink)
Bob, doncha just love the "Cliquot". I use them all the time when building my model racing boats. Man, I just wish I had the fab capability you have. Totally imperssive.
Old 05-03-2004   #194 (permalink)
Clecos rock, I have hundreds of each size and yet still never have enough!
Old 05-03-2004   #195 (permalink)
Yep, "Clecos", That's what happens when you "open foot- insert mouth" I need more coffee this early in the a.m. You still do fantastic work. Wish you were here on the west coast, at least you'd have more pleasant days to work.
Old 05-04-2004   #196 (permalink)
Yesterday my fuel pickups/check valves arrived, so I finally got a chance to complete the fuel system. Here you can see the three fuel pickups, the metal lines, and the fuel pump before they're fitted to the fuel tank.
Old 05-04-2004   #197 (permalink)
Here are the pickups and pump installed in the tank. The second photo shows the left side pickup, and the last photo shows the right side pickup. You'll note I reconfigured the right side pickup tube to clear the float for the sending unit.
Old 05-05-2004   #198 (permalink)
Opel Addict Since 73
Sportwagon75's Avatar
Sportwagon75
How do they Work?
Bob- I have 2 questions: 1st - what type of mechanism is employed in your fuel pickups to prevent pulling air from a starved pickup? Is there some type of float mechanism or do the check valves just snap shut if there's no fuel flow? 2nd - I've been following your turbo fab thread and I'm wondering what (if anything) you're planning to do for reinforcing the head gasket sealing to handle the added pressure? I don't recall if you mentioned how much boost you're adding but I was wondering if it's modest enough to be managed by stock gasketing configurations...or are you planning some upgrades there as well??? Thanks. -Scott
Scott D.
Sportwagon75 is offline
Old 05-05-2004   #199 (permalink)
It's a check-valve that senses fuel flow. As you said, it closes when the flow stops, preventing air from entering.
I'll be using a fairly standard AE head gasket for a 2.0 engine. My normal procedures apply, I'll be using copper spray sealer on the gasket, and will torque it incrementally. Should be no problem with 12-14 psi boost. The killer is leanness or detonation.
Old 05-05-2004   #200 (permalink)
Question fuel pickup/check valve type and source?
Where and what type of fuel pickup/check valves did you buy? . . . for future reference.
Tags
cih, efi, Manta, turbo
