#76 (permalink) |
valve clearence.
i did exactly what you are doing. i have a flat top piston engine that i went to bigger valves about 5 years after engine was built.i also did not want to pull engine or dissasemble. after head was finished(valve lash set-ect)oil the valves so clay wouldnt stick to valves.and clay put on top of 1 piston(big blob/disk)i set head on engine(no head gasket) and started 2 bolts--left the bolts 1/4 inch loose-hooked up the timing chain. then turned engine over by hand--guess what--it lifted the head!made sure that bolts were still loose enough and keep turning until i made 2 complete revs. when the head would lift up with i kept pushing down on head with my hands to make sure i had good impression in clay and then removed head. next i took x-acto knife and cut through clay at the edge of the mark left by the valve and then pealed the excess clay off(the clay under the valve was left. then i scribed a line around the clay that was left(this markes the outline of valve on the piston)and removed the rest of the clay. then transfer marks to the rest of the pistons next seal the bore at piston edges with grease.(the ones at tdc) then duct tape top of block and cut holes with x-acto to access work(only have one hole open at a time)and wrap timing chain with rag. oh-bring 2 pistons to top dead center(close is good enough) the pistons should already have notches for small valves--as i was using the same cam i used this to locate my depth of cut. now whip out the die grinder with a square edge cutter that will also end cut(mill)and go to work--take your time--sit in the engine bay with feet where you can brace your arms on legs and knees-put pillow under butt-have female rub back during process helps(dont get distracted) finish with dremel tool find a good chiropracter! check agin with clay--couple of strips per valve should do at this point i did not check with head gasket--just extra room for floating the valves!? Try to make all identicle to maintain equal piston weight(this was a pisser as i had previously balanced the piston/rod ect) after doing first 2 pistons bring up the other 2 and cut tape away wipe grease out of first 2 and tape them up when finished oil down the cylinder walls and turn engine--every time a piston makes it to bottom dead center wipe it clean (with clean blue paper towels)and re oil--keep doing this until all traces of grinding material are gone take paper towels into sunlight to look for traces of metal. check agin with clay--couple of strips per valve should do at this point reasemble engine Go to chiropractor!(belive me your back is going to hurt when your done) test drive--yee hah!big valves are a blast! go to chiropractor! this engine has been inuse since 93(after valve work)and still runs perfect. Hope this helps! when cars fly--i duck! David ps--Bobs spring info -LISTEN on this one. the springs i run only have about 75lbs when valves are seated. they are stock worn out chev 305 and only float above 6000rpm on really hot days.most of the time it will pull past 7000(scary with cast pistons!) im running 1 3/4 intake--1 1/2 exhaust chevy valves Last edited by supertiga; 01-16-2006 at 01:42 PM. Reason: x |
#77 (permalink) | |
- measure valve notch depth in piston head - measure piston position above/below deck @ TDC - measure pressed headgasket thickness - put camshaft in the head with complete valve train (soft springs) for cyl n°1 - set camshaft @ crossover position using dial indicator on both inlet and exhaust tappets for cyl n°1 - measure protruding inlet valve distance versus headgasket plane - calculate clearance with above data. This method is only valid for static clearance @ TDC, What happens @ 9,000rpm is another story! Hiro |
#78 (permalink) |
With the comments, now I have to ask
....What spring pressures should I run with the valves mentioned above.. I thought I had it right.. pressure at installed height? and spring rate for .500 lift?
#79 (permalink) | |
What are your spring's specs listed at? By this I mean the pressure at a given installed height, and the rate of the spring itself. From this a bit of math should give you your open pressures, but it's best to have a machinist test the springs with your particular retainers (the retainer step on a double spring setup will alter the rate) for confirmation. Bob |
#80 (permalink) |
Isky Spring #4205 is 110 lbs @ 1.750 installed height and has a spring rate of 320 lbs/in. Outer spring is 1.240 O.D. and .925 I.D., Inner spring is .915 O.D. and .660 I.D.. Spring bind is at 1.020". So if I shoot for 1.765 installed height I should get about 105, then with approx. .490 lift I will have 262 open pressure. This leaves .255 before spring bind.
Jeff '73 GT,5spd,Recaro,EDIS4 2.2 EFI by MegaSquirt, Ali Flywheel w/S10 Clutch, Electric Fan, Roller Rockers, Venolia Pistons, 6 Cyl Intake w/ Custom Injection, 15" Wheels,Lecarra,F&R Sway Bars,Custom Exhaust,1" Sport Spring,Koni Reds,Big Brakes,3 Core Ali Radiator,Hse of Colors Kandy Pagan Gold. 123 WHP @ 6800 RPM ![]() '64 VW Karmann Ghia '08 BMW M3 Last edited by markandson; 01-16-2006 at 08:34 PM. |
#81 (permalink) |
Certified Opelholic
Real Name: joe blow
just looking at some of my notes
i used seat pressure of 118 @ 1.700 installed ht 275 open @ 1.200 coild bind @ 1.140 comp cams # 942 valve spring i guess i did not take good notes since this was a double spring setup split a stock rocker in half at 9200 rpm ha ha (man did that car shake) i also just found out i have to identical Cams cam techniques grind F-306/290-6 solid lifter lift is .459 at valve and .435 (EX) so if anyone needs a HI-Po CAM Davegt27 |
#82 (permalink) | |
#83 (permalink) | |
1970-GT
I should be able to check the valve/piston clearance now. I will use a (cutter) slightly larger valve with notches ground in it, or the tool Travis mentioned to put piston relief cuts in. Machinist's can't use dremels, plus I don't want back problems! I will keep the spring pressures low about 100-105 closed, 250 open. Started hand porting a little tonight at the shop, looking good, but I'm slow! Will take a couple pictures to show progress. David, sorry to hear about your car, glad your son is OK! Thanks again Lyle |
#84 (permalink) | |
1970-GT
With the lower spring pressures would a single spring be better? Less moving mass! Lyle |
#85 (permalink) |
From what I understand the inner spring is there to act as a damper, which I assume is to avoid harmonics that may be set up at certain rpms. The original spring as posted by RallyBob was a Crower which is NLA as far as I know, but it too was a double. I just followed along when I chose the Isky. This is where Bob needs to jump in.........bye. P.S. Bob, you were right, I forgot about the lash.
#86 (permalink) |
springs
markandson
exactly right on the multiple valve springs.most material/structure has a frequency that it gives up at.saw a ww2 aircraft that looked to have 6-8or more springs for each valve.i think it was a rolls royce merlyn.long time ago. the same formula for spring/damper selection for road springs should let you know what your springs quit working at look in steve smith-advanced racecar suspension development or costin and phipps---racing and sports car chassis design(costin of cosworth) or len terry and baker--racing car design and development. some where long ago i remember reading formula in an engine book--cant find now. something i have done is to ask cam grinder what springs to use for cam/valve train weight/rpm/ect.i have always gotten an answer. hope this helps David. |
#87 (permalink) |
spring surge
have looked in apile of books and online and havent found the math for valve springs.
waddel wilson calls it spring surge.(but no math) lookin at formula for road spring/damper caculations--would probably take some one good with math(not me)to use it for valve springs. did find this for chev small blocks (outer and inner spring) 110lb closed-1.7 installed hight 260lb open -1.25 hight(.45inch open) max lift .485 GM p/n 3927142 paint code reddish brown i think these fit the opel spring pocket for up to 8000rpm larger o.d. than above 135lb on seat 290lb at .5 open GM p/n 330585--spring retainer p/n 330586 |
#88 (permalink) |
I checked original installed height of the valve springs in my 2.2 head. Rough measurement only with a machinists scale. Intake = 1 9/16" Exhaust =
1 13/16" with the rotator removed. Checking the length of the valves that I bought from SI against the original valve lengths yields the fact that the new valves are about 1/16" longer to the bottom surface of the retainer. Since I need approx 1.765 installed height to get the 105# of closed force it appears that the exhaust side is very workable with a shim. It also appears that I have to cut the intake spring seat about 1/8" deeper than it presently is. Here is the question----How much deeper can you cut the intake seat of a 2.2 head before the wall thickness to the intake port gets too thin?
#89 (permalink) |
1970-GT
Got my new double cut oval carbide burr this morning! From McMaster-Carr.
Wow, that baby can remove some metal!! One wrong move and you can do some major damage $$!!. I have smaller diameter burrs I am using when I get close to the valve seats, Yep I'm chicken!!! Area's that have been tough are around the exhaust valve seat insert, the chamber upper edge and the valve guides. I used the bronze valve guide as a gage to thin the cast area around it. Trying to maintain a .04-.05 wall, milling them to height has helped a lot. They have a sharp milled edge now, I will be putting a radius around them as Bob show's, not sure how to do that yet. Bob's pictures are a great guide to show how it should turn out! Doing it is another thing, this is not easy! I'm such a perfectionist this will take me awhile! Will take pictures of the port and chamber area tomorrow. Lyle |
#90 (permalink) |
Jeff while the machinist was doing the deepening of the valve seat area for my 2.4 stroker he broke thru into the coolan chamber. It was massive core shift in the casting process. I would guess we were dropping the floor about 1/8 an inch. The next head machined OK.
TMK |
#91 (permalink) |
1970-GT
Here is what I have so far. The valve guide casting and the bronze guides are ground concentric and milled to height to match valve undercuts. Will try to stream line them, but want to maintain valve stem support!
Take a look at the picture, any imput before I continue on? Lyle |
#92 (permalink) | |
1970-GT
Been busy, will try to port a little tomorrow at the shop. I decided not to grind the cast guide away around the bronze insert, for wall strength. My thought is, if I ever have to replace the bronze guide this will keep the cast guide from cracking!? I know it will not flow as good as Bob's technique. Will take a picture of it. Any thoughts? Lyle |
#93 (permalink) | |
If you want middle-of-the-road, then these work fine: http://www.sivalves.com/ocdomestic_valvesps_chevsb.html If you want better quality then call Manley and order some cut-down valves (they start with a 1.94" blank). Takes about 7-10 days and adds $8 per valve to the cost. You have a ton of options for a starting point BTW, I usually just use the Raceflow 11/32" stems, stock length. |
#94 (permalink) |
Certified Opelholic
Real Name: joe blow
i would scan this in but it takes time for approval
from the Manley 2003 catalog stainless pro flow int P.N. 10722-8 --- 1.940 stem diam .3415 installed ht: stock OA length 4.911 tip length .250 underhead angle/radius: Pro flow-- 10deg x 3/8" seat width .080 top of head 5 deg dish wgt/grams 107 EXH P.N. 10721-8 --- 1.500 stem diam .3451 installed ht: stock O/A length 4.911 tip length .250 underhead angle/radius: 12deg x 3/8" margin .060 seat width .100 top of head 7deg dish wgt/grams 89 2003 jobber price 10722-8 is $80.0 10722-1 is $10 10721-8 is (or was) $80 and again 10721-1 $10 HTHs i can look up other number if you like Davegt27 |
#95 (permalink) |
Chevy Valves
I found some Chevy valves that the seller states are 4.92 length.
Is the standard size length for opel big valve heads 4.88 Can this difference of .04 be machined off?
#96 (permalink) | |
1970-GT
Lyle |
#97 (permalink) |
1970-GT
Working on the head again.
Have a couple valve spring questions. If I use 1-1/4 Chevy springs, will I have to use cup type spacer to locate the base of the spring in the exhaust spring pocket?? Or should I just use a 1.440 spring (Pontiac 400) instead? I would then just have to machine the intake spring pocket to 1.45 and proper depth, and be done!? Lyle |
#98 (permalink) |
Lyle,
I don't know the reason for using the 1.250 springs over any other, other than reducing the mass of the spring for higher rpm applications. You would need to make the spring cups you are referring to for the exhaust springs if you use the 1.250 springs. I, at this point, have only taken apart a 2.2 head, not a 1.9, so I am sure others out there will have better answers.
#99 (permalink) | |
My only exception to this statement was the roller cam setup which used a single spring with damper, and I had custom cups machined for the exhaust side that were quite thick, with off-the-shelf cups for the intake side. http://www.opelgt.com/forums/showpos...5&postcount=83 Bob |
#100 (permalink) |
Bob, I had a question regarding porting the heads. Another person on the list told me he was doing the porting BEFORE having any of the machine work done, which didn't make much sense to me. He is going with the 1.72" valves as in this thread. In your thread here you showed a funky little "lip" in behind the valve that you had to carefully blend in, and mentioned this is often why you go with a 1.84" or 1.85" valve. Is it possible or feasible to properly port a head before having the larger seats cut? I don't see how. It appears you have to work from the edge of the seat back, and I also noticed how you take away part of the guide (which in this case would be put in AFTER the porting). Ever hear of anyone doing it this way? He claimed that by doing the porting first, the "lip" area is already gone when you cut the seats.
Todd
