#151 (permalink) | |
#152 (permalink) |
Well, this might be a totally stupid question, like I've never done that before....but what is enough flow? I mean, I know it depends on displacement and compression ratio for what is needed, but I have to assume at some point the curve starts to go the other way once flow passes a certain point and velocity drops. Is this measurable?
Jc |
#153 (permalink) | |
So putting a fully ported big-valve 2.4 head on a 1.9 block with a Solex and a stock hydraulic camshaft won't gain you much. But as far as the potential for a drop in velocity, it is more a matter of port size than port flow. If you can gain flow but not lose velocity, then by all means go for it! Porting is easy, but porting effectively is not always so simple. I like bigger valves because the curtain area is so high (more exposed valve seat area at low lift). In conjunction with modest porting, the big valve head can actually make a fantastic street head where you have no loss of power or torque...only gains throughout the powerband. Now for racing, you will want even more flow, and at some point you'll need more port volume...as you said dependent on compression ratio and displacement. It's also dependent on the required powerband. A larger runner can store more of a charge between cylinder firings and improve VE on a smaller displacement engine too, however the trade-off might be a narrower power band requiring special close ratio transmission gear ratios and accurate induction/exhaust tuning for best results. I've had one Opel racing engine pull 112% VE for a 400 rpm powerband thanks to inertia tuning, most street engines would be lucky to break 85% at any point! Bob |
#154 (permalink) | |
The Cannon intakes have a more pronounced angle as well, they are at the same level as the inlet port for a short distance, then they angle upwards, then they level off again (so they don't angle the sidedrafts too much and upset the floats). When I modify the Cannon intakes, I weld some more material at the center area of the runners, to allow me to port the intakes for a 'straight shot' at the valves. Bob |
#155 (permalink) | |
I do have a rough-cast Opel Parts and Service SSD intake. It was apparently an intake they designed and had cast for Mantapart...and then Mantapart didn't buy them even after contracting them. So they sold them directly to their own Opel customers instead. Just before Tom Thevenin decided to retire, he sent me a list of misc parts he was looking to unload, and one of these items was an as-cast SSD intake they made. It was never even machined, just a raw casting. So I bought it, and drilled/tapped it to fit, but never tested it. I suppose at some time I'll have on throw it on my flowbench, but unfortunately the 1.5 litre 'test head' I used for these other flow tests is currently on loan to a friend of mine. I'd rather use that head to bolt the intake to because any variation will skew results. Bob |
#156 (permalink) | |
very interesting for my next upgrade, thanks! I was planning to go for home-made throttle bodies, alternatives being should I use modified DCOE with their manifolds, or motorcycle bodies with home-made ones. I guess the second option will allow for a better "direct shoot at the valve", moreover the head is a 2.2 so maybe I can play a little bit with the angle to benefit from the raised port design. Hiro |
#157 (permalink) | |
http://static.summitracing.com/globa...m-227700_w.jpg Two of these will work nicely on the raised-port Opel heads! Standard version for 305/350 Tuned-Port GM engine has twin 48 mm throttle plates, with the center divider nearly the same width as the 2.2 inlet ports. Straight shot to the valves! These you can get off Ebay for fairly cheap (you need two units). Now, for Bonneville I will buy two of these Summit units, as they are 52 mm each...perfect for 10,000 rpms! They also have twin 58 mm available, but that might only work with a 2.7 litre/roller cam engine! Bob |
#158 (permalink) |
racing cylinder head porting
Hi Bob
I have a local machine shop do the porting on my racing cylinder head. what additional to the street porting should i do for racing. The car is SCCA FP, high compression pistons with stock sice valves. 35 mm exhaust and 42 mm intake manley custom valves Pete |
Pete Anastopoulos www.anastosmotors.com info@anastosmotors.com * * * * * * * * * * * * * * |
#159 (permalink) | |
#160 (permalink) | |
Bob |
#161 (permalink) | |
that's a very nice idea Bob! not so expensive & much bigger than my motorcycle stuffs, again using US parts is the way to go for our old CIH... cheers, Hiro |
#162 (permalink) | |
what are the FP race specs? Hiro |
#163 (permalink) | |
I want to mimic this but you know my poor fabrication skill... my design will be much simplier just to fit the single motorcycle bodies, hum... more news this winter I guess! cheers, Hiro |
#164 (permalink) |
It is a classification for circuit racing here, call Production. 'F' is where the Opel fits in, based on the standard model's capabilities (like old FIA Group 2, Group 4, etc). Rules are here.
Basically, the head can be upgraded with any valve springs, and retainers, and porting work. Valve head diameters must be standard size, but the stem diameter and material may change (so 6 mm titanium is okay!). This of course limits total power capability. Page 52 and 53 of the rules show the Opel-specific limitations, which include a minimum weight, track width, wheel width, valve sizes, induction restriction, and brake sizes. It is basically a class to provide racing for older cars, but newer cars are being added all the time. Unlike our 'GT' classes, complete tube-frame cars are not allowed in Production class. Bob |
#165 (permalink) | |
Bob |
#166 (permalink) | |
a difficult & sometime expensive challenge for engine builders! Hiro |
#167 (permalink) | |
my R6 TB are fitted with hose adaptors anyway, I will probably start tinkering with an old 22E manifold as raw material. Hiro |
