#202 (permalink) | |
![]() But yes, it's a way to estimate your airflow through the head itself. However it doesn't take into account the overall reduction of intake flow from the intake manifold and carburetor, and the increase in exhaust flow from the manifold/header bolted in place. Bob |
#203 (permalink) |
I think that, especially with the raised port heads, the parallel straight runners are the way to go. The center dividers are already wider than those on the low port heads, so I think the trick is fitting two GM Tuned Port throttle bodies as the center divider between the two (stock) 48 mm throttle plates matches the raised port head spacing. I planned on doing this for my Bonneville engine...short runners, big throttle plates (52 mm aftermarket), and a straight shot. There would still be an air plenum to avoid drawing warm air, and to take advantage of inertia tuning. You could also angle the manifold runners upward to match the intake port upward sweep, like I did on the sheet metal 2.2 intake I built. (pics below)
#204 (permalink) | |
at first sight I guess your 30E modified manifold flows very well! peak flow with the DBilas manifold fitted with ITB should be a tad lower than 134cfm (ca. 130cfm?), that's only 7-8cfm more than the peak flow from the 30E manifold... of course the flow path/direction is completely different, but probably for a street 2.4 this 30E manifold is more than enough? Hiro ps: BTW Bob I want you in my lab! generating such experimental data is not trivial, this I know from my daily occupation! |
#205 (permalink) | |
definitely the route to go for an extreme output race CIH! I'm dreaming about this setup with a drawer-type throttle ITB... Hiro |
#206 (permalink) | ||
And as you said, I have not flowed the Dbilas inlets with TB's in place...this diameter will affect the total outcome. Even more would be the reduction of flow with DCOE-type carburetors in place, since the 45 mm throttle plates are not flowing 100% thanks to the main venturi diameters (usually 36-40 mm for race use). The 3.0 EFI inlet was flowed with the 65 mm TB wired open, and when I achieved maxuimum airflow I tried to 'cheat' the air by untaping some passages I had covered up. It didn't make any difference to peak flow, so the restriction was not the 65 mm TB, but rather the intake runners themselves. Perhaps on a 'maximum effort' engine that must use this type of intake the Extrude-Honing process might make financial sense?
![]() Bob Last edited by RallyBob; 08-23-2007 at 02:13 PM.. |
#207 (permalink) | |
so here is the plot comparing Bob's 30E manifold with DBilas' DCOE type: |
#208 (permalink) | ||
Another clearcut demonstration Bob! And another take-home lesson for people thinking that a monster TB will be better flowing this short 30E manifold, Assessing the limiting factor is the key to any kind of development work.
Not too good these days, Companies will need to fire all the old guys like me to make room for youngsters, But young scientists in my field get far better wages & working conditions in the US or Australia so... |
#209 (permalink) | |
The ported 1.9 head improved a lot @ 0.3 low lift, Whereas the ported 2.2 & 2.4 are not better than std @ 0.3 low lift. This is a bad news for me, Because I wish to increase as much as possible the mid-range torque on my race 2.5/2.7 If I understood correctly one key is increasing the flow @ low valve lift, Any clue how to circumvent this drawback with the 2.2/2.4 heads? Do you think carving the "flow divider fin" in the intake roof would help? Hiro |
#210 (permalink) | |
I noticed on the vey first 2.2 head I flow tested, that if the bowls were blended, the airflow at lower lifts was worse than a standard 2.2 casting! It seems Opel had their valve angles correct for low rpm torque! In other words, if you have standard valves with the 2.2 head, you are better off leaving it 'as is' than doing any work to it! However, with the 2.4 head and standard valves, there is some small gain to be had with bowl-blending. I would not worry too much about the torque with the 2.7 litre engine Hiro, I think that by nature this will be it's strongest virtue! Of course you can create stronger torque by using higher compression pistons, and cams with tighter lobe separation angles, and by advancing the camshaft (earlier inlet opening). Or by playing with different length inlets and exhaust manifolds. Remember this engine is still basically a tractor engine! ![]() What is that saying? You can't make a race car from a pig, but you can make a very fast pig...
#211 (permalink) | |
Bob your street heads are much better than my so-called race heads! The 2.2 bowl-blending data with std valve is scarry, I remember you said numerous time that "wild porting will hurt flow instead of making it better"... For my 2.7 race CIH I will start with basical stuffs & settings, Head will be a ported 2.2 with 50mm intake valve, Cam something like Dave's F328-10 or a tad bigger, Let's see how it revs like this... without falling apart! Hehe Pumba likes stories with fast pig/pork/hog... Hiro |
#212 (permalink) |
this plot compares intake flows from the 1.9 competition & from the 2.2 street heads,
data are not strictly comparable because valve size is different, but what strikes me is the extent of the linear increase zone of each head: on the 1.9 head it's only linear uptill about 0.3" lift then it progressively bows, whereas on the 2.2 head it's almost linear until max flow (0.5" lift) then it suddently stalls. low port versus raised port effects? Bob I'm very curious about how your group2 "Swedenkopf" head flows, this head has both low & raised port features, but IIRC the runner volume is very big so this may harm the flow by itself? Hiro |
#213 (permalink) | |
I *think* that this head can be prepared to flow 155+ cfm (estimated), but it will probably only be suitable for super-high rpms and monster camshafts OR very big CC displacement engines. I say this because the port volumes are so huge, there will probably be no power below 6000 rpms otherwise. My friend Bjorn says this is true as well, the engines he has seen in Sweden with this head (2.0 litre) all have power from 6500-8500 only. Probably a very bad idea for rally or road use, but maybe good for circuit racing? Or perhaps a very big turbo... ![]() Bob |
#214 (permalink) | |
Hehe so that's more exciting work & data to study in the future! Wild idea: why not use this Swedenkopf with a "tall deck" 23D short block, Maybe we can build a monster CIH4 with more than 3000cc displacement & good rod ratio, This engine should rock! Hiro |
#215 (permalink) | |
I wish to build a roller-cammed 2346 cc engine with extra-long rods, and use a Garrett GT4094 turbocharger with this head. I want 700+ hp and 10,000+ rpms from this combination. I have a 1974 Manta that would like to try this engine out.
#216 (permalink) | |
never actually seen one myself. whoa this turbo CIH will super-rock! our old cast iron dinosaurs still have fun days to come! Hiro |
#217 (permalink) | |
http://www.opelgt.com/forums/opel-en...omparison.html Bob |
