Turbo Cih build - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 54 of 54
Like Tree27Likes
Thread: Turbo Cih build
  1. #41
    Oct 2002
    Mahopac, NY
    3,950
    Don't know about the width of the 2.5 rods but a search of Crower turned up a bunch of different possibilities. I am sure you can get the correct pin end bushing, I don't know what your 2.2 crank needs at the big end.
    www.markandson.net
    www.gpny.com
    '64 VW Ghia '09 S35 BMW Z4
  3. #42
    Spofford, NH
    12,377
    Bob Legere
    Quote Originally Posted by clausholleman View Post
    C/R 58cc=10.0, 64cc=9.3, 76cc=8.2
    Piston/Pin Weight: 615 g
    Rod Length: 5.7", Ring Style: A
    Comp Height 5.7" Rod - 1.561
    Pin Diameter - 0.9272
    Hmmm, I dont know of any rods that work with those pistons and a 2.2 crankshaft. Normally 2.2 pistons have 1.619" compression height. Those pistons have 1.561", difference is .058". So rods need to be 5.097", or 129.46 mm long.
    I wonder why you got cast hypereutectic pistons instead of forged pistons for turbo use?
    markandson likes this.
  4. #43
    Oct 2002
    Mahopac, NY
    3,950
    Bad assumption on my part but the way he was posting it looked like he already figured out that a 5.700 rod was what he needed and he was only trying to decide on which one to use.
    www.markandson.net
    www.gpny.com
  6. #44
    Spofford, NH
    12,377
    Bob Legere
    Well, the way those pistons are sold for their original intended use, they are sized for 5.7" rods with a 3.48" stroke small block Chevy. Doesn't correspond to an Opel the same way, due to a different stroke and different deck height.
  7. #45
    Jul 2005
    Milner, GA.
    11,164
    Dan
    12
    I use this method.
    1/2 stroke + rod lenght + compression height = block height.
    clausholleman likes this.
  8. #46
    Aug 2015
    Gennep
    69
    Claus Holleman
    as i read it, there are a lot of people who use these pistons for turbo ore non turbo.
    the part of the rods, i will look @ the lists to figger out witch to use, i thinkl its gonna be a h-beam.
    i have a lot of crankshaft's here, like the 1.9 , so i will messure things out.
    when i take my 1.9 crank, ore a 2.0, i can take 137.16mm /5.4inch rods then
    and in the 5.4"size there are manny solutions like the Crower rods
    luckly i saved all my crank's.
    cheers
    Claus
  9. #47
    Aug 2015
    Gennep
    69
    Claus Holleman
    PS
    Rod/ratio is 1.97
    stroke to bore ratio is 0.723
  10. #48
    Aug 2015
    Gennep
    69
    Claus Holleman
    2.0 crank with 8 counterweigts
  11. #49
    Aug 2015
    Gennep
    69
    Claus Holleman
    aaaannnnddddd YES 14days of waiting, but here they are:
    Trevil likes this.
  12. #50
    Aug 2015
    Gennep
    69
    Claus Holleman
  13. #51
    Aug 2015
    Gennep
    69
    Claus Holleman
  14. #52
    Aug 2015
    Gennep
    69
    Claus Holleman
    designing te intake plate/adaptor
  15. #53
    Aug 2015
    Gennep
    69
    Claus Holleman
    just a few porting pics ;)
    just a few pics of some of my heads porting, roughly , will be finised in a few days and i will post pics when the ports are done.
    not one of my own heads, but for a customer.
    a lot of work but its fun to do
  16. #54
    Aug 2015
    Gennep
    69
    Claus Holleman
    hmm, not bad
    1. Opel GT build with Turbo Mazda Rotary
      By Kustoms in forum Engine Swap Forum
      Last Post: 05-31-2016, 03:15 AM
    2. CIH turbo...
      By kadet-c in forum Opel Engine Performance Modifications
      Last Post: 05-24-2013, 05:18 PM
    3. Cih turbo
      By norbertone.gt371 in forum General Discussions
      Last Post: 04-28-2013, 01:20 PM
    4. A new 2,0l CIH is build
      By TMB in forum Opel Engine Performance Modifications
      Last Post: 11-15-2010, 04:59 PM
    5. My cih build
      By opelidiot in forum Opel Engine Performance Modifications
      Last Post: 09-25-2008, 07:51 PM
