Here are a couple sketches of the head modifications I made.
The 1st picture is of the valve guide cross section, this shows that I reduced the height of the intake and exhaust guides about .200 from stock. This was done to improve flow and to match the under cut stem on the Pro-flow Chevy valves.
The second picture is of the head showing the dimensions after angle milling. Milling this way instead of straight milling dropped the cam only about .035" from stock, but reduced the combustion chamber volume alot more.
Good idea Bob!
Stock is about 52.0 to 52.5 cc's.
