2017 Carlisle Parts Thread - Page 4
Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 91
Like Tree30Likes
Thread: 2017 Carlisle Parts Thread
  1. #61
    Tennessee
    4,152
    Keith Lundholm
    Quote Originally Posted by opellane View Post
    Did you find any longer type Alt. brackets? Have/ bringing any Backing Plates?
    The Seats Tracks don't sweat it.. the collar is important.. a nice one too
    Silly part ... on each side of the padded dash.. there are plastic Plugs to cover the access hole to remove dash
    2 plastic Plugs if you can find any...thanks
    Safe Travels
    No longer brackets, I got the dash plugs, will bring several
    I have a set of early rear end backing plates loaded, and some manta ones that have been powdercoated, do you have a late rear or early rear end or are you referring to front suspension backing plates?
    www.newvintageauto.com
  3. #62
    Nov 2007
    Cöllingswööd, NJ
    9,820
    Gördö
    6
    A leak-free steel oil pan and a chrome-worthy brake push rod is all I need. Thanks!
  4. #63
    Mike's Opel Shop Site Supporter My location opellane's Avatar
    Apr 2004
    Goshen,New York
    908
    Maybe the Manta front backing plates... those are the ones for the Big Brake calipers? bring the powder coated ones too
    MIKE
    1973 MGB, Red, Weber 38DG
  6. #64
    Tennessee
    4,152
    Keith Lundholm
    I am bringing rear backing plates, but in the front, I think I have some already powdercoated, Manta plates are a bit different. They need to be tweaked a little for the 75 calipers in most cases
  7. #65
    Opeler opelgtboy70's Avatar
    Mar 2003
    NJ
    1,001
    Karl Senula
    Have any Manta steering wheels? Or the emblem that goes in the middle?
    Mine doesnt have the blitz in the middle.
    Karl
  8. #66
    Member timemachine's Avatar
    Jan 2006
    Swarthmore, PA
    1,085
    Jim
    Quote Originally Posted by opelgtboy70 View Post
    Karl
    Horn rubbers are all the same but some inserts are metal, some plastic and different diameter. I can look around for you.
    '74 Manta ("Sig")
    '75 Sportwagon (project)
    '72 GT (whenever I get to it)
    Sold or wrecked:
    '72 Manta Rallye
    '73 Manta
    '74 Luxus
  9. #67
    Tennessee
    4,152
    Keith Lundholm
    I used to have a couple wheels, but no longer do, I do however have a later Opel wheel that the center may be close to the same.
    Here is a running list of things I can recall packing
    GT, The following:
    Ashtrays, both styles
    Headlight pivoting handles
    Headlight bucket pair
    Steinmetz front air dam for flares
    Rear defrost indicator light
    Gauges
    Instrument panel
    Resonator
    Muffler
    Over Axle pipe
    Two seats in black, pretty nice
    Several door panel pairs, one full set nice
    New carpet kit in black loop
    Brake shoes
    Brake pads
    Caliper rebuild kits
    Steering columns
    Ignition with key
    Ebrake handle assembly
    Nice set of black visors
    Grille sets
    Front marker housings
    New taillight bezels
    Heater boxes, early and late
    Rear backing plates early
    Engine to transmission supports powder coated
    Brake support bracket powder coated
    Brake rod powder coated
    Honda radiator
    GTS older aluminum radiator
    1970 steering wheel
    Drive shafts auto and manual
    Auto shifters
    Manual shifters
    4spd pedal assembly
    Pedal rubbers
    1973 gas tank
    5 valve covers
    Rear trim strip
    Rod set
    Piston and rod set .040 over new forged pistons low compression for boost
    Cams
    Oil pans
    Wheel cylinders
    Transmission mounts and crossmember
    Timing kit NOS
    Sway bar
    Lowering spring set
    Manta parts as follows:
    Clusters about 3-4 and facias
    Powder coated rear backing plates
    2 sets 75 calipers
    Sunroof visor new
    NOS rear seat cushion cover in silver/gray corduroy style-might serve as perfect pattern
    Front valance, believe a 70-73 style
    Transmission mount and crossmember
    Some trim
    75 gas tank, may also have a 74 style
    Kadett:
    Vinyl roof trim set for 92-95 series
    Rallye emblems
    Tranmission mount and crossmember
    Misc:
    FAST fuel injection system, with distributor and intake, computer. Maybe cheap enough for someone to want to play with it. Probably 1000s spent on it. Harness and other stuff with it
    Garrett Turbo, never used
    Gauges, misc autometer new
    Slotted wheels set with tires, centers and lug nuts
    Double crank pulleys
    Smog pulley
    2.2 valve cover
    Will have probably a used lens grab tub and a misc switch grab tote as well, just takes forever to bag all those. Also will grab some distributors, may or may not bring the 2.0, might have it sold to a customer.
    Not sure I want to haul much more, but have some powder coated front suspensions and rear end extra I may bring, nothing in the rear end but housing.
  10. #68
    Opeler 69whitegt's Avatar
    Jan 2006
    Cincinnati, Ohio
    667
    David
    Keith, you are bringing the carb and intake we talked about correct?
    ____________________________
    . 1972 GT " Ms. Cali "
    . 1.9 High Comp.
    . Sprint Manifold
    . 32/36 Weber
    . Isky OR-66 camshaft
  11. #69
    6,793
    Charles Goin
    5
    Forgot to mention still looking for 3.18 rear >.<
  12. #70
    Tennessee
    4,152
    Keith Lundholm
    Yes on the SSD
    I have a Kadett Rear diff, I assumed it was a Rallye 3:67, but it might be out of a Wagon from 1970. I'm going to pull the cover and try to do a gear count
    GoinManta likes this.
  13. #71
    Aug 2006
    Goderich, Ontario Canada
    2,706
    P.J.
    Keith, I will see Norbert at Eurotreffen in Holland in two weeks. He asked me to pick up from you left rear NOS all in red lense (no amber turn signals) with chrome trim for a 68 Kadett Wagon.
    I believe you know about that, this is just a reminder.
  14. #72
    Tennessee
    4,152
    Keith Lundholm
    Yes, packed in with note.
  15. #73
    Jan 2016
    Albuquerque, NM
    535
    Joseph Bauer
    Keith, did you see my request? Thanks in advance
    I can't go to this awesome event. Would you mind setting aside whole set of cherry condition gauges for me? I can send you money via pay pal or cut you a check. You can deal with shipping my order after your trip. I appreciate it.
    Oh manual trans speedo please. I'm assuming a whole set will include speedo, tach, clock and both small combo gauges. Let me know if that's an incorrect assumption.
    ~Joe
    "Autoholism is an incurable addiction medicated daily with car porn." ~Me
    "the sickest of the sick — a car guy who is collecting parts for the restoration of a car he doesn’t even own yet." ~Anonymous
  16. #74
    Tennessee
    4,152
    Keith Lundholm
    Quote Originally Posted by Autoholic View Post
    I did, I have plenty sets, so no worries
  17. #75
    Nov 2007
    Cöllingswööd, NJ
    9,820
    Gördö
    6
    I think Gabe(CWO?) has been eagerly searching for a flip up ashtray. I sent him a pm.
  18. #76
    Tennessee
    4,152
    Keith Lundholm
    I have both, gordo...do you need just the oil pan or pickup tube and all that jazz
  19. #77
    6,793
    Charles Goin
    5
    He needs just the pan. His pan has a bad spot.
    I need "all that jazz" at least 2 sets.
    CURRENT
    '74 Opel Manta - "Barbara"
    '72 Opel GT - "Ginger"
    '05 Pontiac GTO
    In the past owned:
    '04 & 06 Pontiac GTO
    2 Bitters (#491/#439)
    '73 Commodore GS
    & many other Opels
  20. #78
    Tennessee
    4,152
    Keith Lundholm
    I found two more oil pans is why I asked, no point giving him the jazz if I can build another set
    Mike, I found a column cover, and seat tracks
    PJ, I will ask you the same, do you need just a steel pan, or a pan and all the jazz
  21. #79
    6,793
    Charles Goin
    5
    FWIW.
    Hey I have a pan or two that need just the "Jazzy bits" in case you have extra
    CURRENT
    '05 Pontiac GTO
    In the past owned:
    '73 Commodore GS
    & many other Opels
  22. #80
    6,793
    Charles Goin
    5
    If you do that's great, and if you want I have a very low mileage 3.44 that's in great condition. For any of your future projects.
    CURRENT
    '05 Pontiac GTO
    In the past owned:
    '73 Commodore GS
    & many other Opels
    1. 2016 Carlisle Parts Thread
      By markandson in forum Opel Events Forums
      Last Post: 05-17-2016, 03:36 AM
    2. Carlisle Parts Thread 2011
      By jlthunder in forum Opel Events Forums
      Last Post: 05-19-2011, 11:38 PM
    3. Carlisle Parts Thread
      Last Post: 05-21-2010, 06:02 PM
    4. '07 Carlisle parts thread
      By Rionart in forum Opel Events Forums
      Last Post: 05-17-2007, 08:06 PM
    5. The Carlisle parts thread....
      By matl59 in forum Opel Events Forums
      Last Post: 05-19-2006, 07:44 AM
