Opel Forums
Go Back   Opel Forums > Opel Forums > Opel Events
Opel Events List Opel shows, Meetings, and Events Here. Don't forget to add the location.
Old 07-17-2007   #51 (permalink)
jlthunder's Avatar
How is this for an idea, if Rick is up to it? Rick, order a new donut, support bushings and a rear pinion seal. The ones in there are over 30 yrs old so even if this isn't the culprit, his rear axle gets a nice refreshing. We just need someone with the "star" tool for the 4 bolts which hold the torque tube to the rear axle. I would suggest replacing these bolts with metric stainless steel hex heads.
If this doesn't fix it, then the only other things I can think of is the center bearing(rare) or U-joint on the driveshaft(possible). I only had one of those go bad on me and that was on a '74 Manta Luxus.
jlthunder is offline   Reply With Quote Top home
1973 GT, Parted out, R.I.P.
Old 07-17-2007   #52 (permalink)
Kick a little asphalt
MantAscona's Avatar
MantAscona is on a distinguished road
For what it's worth, the hillclimb car will be going to the blaster tomorrow, so that will leave my lift empty. You're welcome to come and use the lift if it will make your life easier. Let me know what you want to do.
Duane
MantAscona is offline   Reply With Quote Top home
Old 07-17-2007   #53 (permalink)
MantAscona's Avatar
Oh, BTW, I have the tools to remove the tripple square bolts.
Duane
Old 07-17-2007   #54 (permalink)
Opel-ing since '74
opelgtguy's Avatar
opelgtguy
Duane
Careful there ........ I will take you up on that offer
Thanks to all of you guys - I appreciate it.
Rick
opelgtguy is offline   Reply With Quote Top home
Old 07-17-2007   #55 (permalink)
Opel-ing since '74
opelgtguy's Avatar
opelgtguy
I just got off of the phone with Dennis at OGTS ....... the parts should be in the mail this afternoon.
Stay tuned !
Rick
Old 07-17-2007   #56 (permalink)
timemachine's Avatar
Remember guys, I described what the problem sounded like from above after a couple of 10-foot rolls in Rick's driveway. I never said it was the definitely the donut or anything else. Hopefully that's it (and it deserves replacing after 34 years), but don't look at me if something else shows up.
While we're down there let's fix that droopy exhaust once and for all. And Rick, I have a spare rear axle seal for that right side.
Duane, blasting the hill climb car? I thought that's what the hill was supposed to do. What color are you thinking?
Jim
timemachine is offline   Reply With Quote Top home
'74 Manta
'72 GT
Sold or wrecked:
'72 Manta Rallye
'73 Manta
'74 Luxus
Old 07-17-2007   #57 (permalink)
jlthunder's Avatar
Don't worry, we won't hold you to it. Troubleshooting with your ear or over the internet is shakey at best. We just plan to "freshen" up his car.
Rear end problems? Droopy exhaust? Sounds like middle age to me
Old 07-18-2007   #58 (permalink)
MantAscona's Avatar
I want to start with a clean shell so I can see all of the metal work that needs to be done. It will make it a lot easier to do the work also. I haven't decided on color yet. There are a few things rattling around in my brain, but I haven't settled on one yet.
Duane
Old 07-18-2007   #59 (permalink)
MantAscona's Avatar
I took a spin in Ricks GT last night. I surely sounds like a torque tube issue. The clutch is also pretty far out of adjustment. As mentioned, the exhaust is in need of attention too. My biggest concern is the whining noise that the rear diff is making. Combined with a known gear lube leak, I'm guessing the pinion bearing is running dry.
Duane
Old 07-18-2007   #60 (permalink)
I only drove it in Rick's driveway so I didn't notice the whining. There was some oil built up in the middle of the floor as well as in the right wheel so if the pumpkin gasket is good then the pinion seal is bad, yes? Haven't done one in 20 years, as I recall there is an end nut and a collapsible spacer back there ahead of the bearing. Duane would know better than me. Can you get that stuff from OGTS?
It was actually the first time I had sat in a GT and pushed a pedal. I was surprised my head fit under the roof without a problem.
Jim
'74 Manta
'72 GT
Sold or wrecked:
'72 Manta Rallye
'73 Manta
'74 Luxus
Old 07-18-2007   #61 (permalink)
There are a few things rattling around in my brain,....
Ahem...very few things rattling around up there...
Old 07-18-2007   #62 (permalink)
Originally Posted by timemachine View Post
IHaven't done one in 20 years, as I recall there is an end nut and a collapsible spacer back there ahead of the bearing.
Replacing the pinion seal only requires removal of the torque tube and torque tube housing. You can remove and replace the seal without disassembling the pinion assembly.
Old 07-18-2007   #63 (permalink)
jlthunder's Avatar
If you have a seal removal tool, it is a 10 minute job once the torque tube has been removed. If we don't do it a Duane's, let me know and I will get the tool.
Old 07-19-2007   #64 (permalink)
71 GT Owner
lkyrog's Avatar
lkyrog
Dang Rick, I thought I was the only one to develop problems on the way home.
I started to have problems (grinding) getting in to 3rd gear (going up and down)...figure the synchronizer is gone.
At least I remembered how to double clutch and got home
I'm now looking for a good 4 speed transmission to install this winter (can't afford a getrag 5speed)
I don't have the facilities (and knowledge) to rebuild what I got.
Oh well I needed something to keep me out of trouble anyways.
Update: I found someone kind enough to let me have one of there 4 speed trannies (BQS4) so I will have something to tackle this fall....yea!
Thanks againe Gene!
lkyrog is offline   Reply With Quote Top home
Life is shorter than you think...Live!
Old 07-19-2007   #65 (permalink)
Opel-ing since '74
opelgtguy's Avatar
opelgtguy
Hi Roger:
Yep ..... me too. I just read your thread last night about your problems.
IT'S ALL JIM'S FAULT !!!
Rick
Old 07-19-2007   #66 (permalink)
Originally Posted by opelgtguy View Post
Hi Roger:
Rick
So, I am the Opel "cooler" eh? Geez, after all the help I offer...
I have to tell you fellas, whatever your problem is, my car is running like a bull and the Opel life has been very good to me lately.
Must ba a Manta thing.
Jim
'74 Manta
'72 GT
Sold or wrecked:
'72 Manta Rallye
'73 Manta
'74 Luxus
Old 07-19-2007   #67 (permalink)
71 GT Owner
lkyrog's Avatar
lkyrog
yeah, I guess it is Jim's fault
By the way nice Pictures.....of Jim's hood
Old 07-20-2007   #68 (permalink)
Opel-ing since '74
opelgtguy's Avatar
opelgtguy
Thumbs up A nice package has been delivered .......
I just got a call from home ........ my care package from California has arrived ! (Thank you Dennis !!!!)
So - who's busy this weekend ?
Rick
Old 07-20-2007   #69 (permalink)
I am pretty available - unless you don't want me cursing your car.
If Duane's offer stands that would make life a lot easier. Plus, he has the tool we need (and the best tool set generally). Drop an email or give me a ring.
Jim
'74 Manta
'72 GT
Sold or wrecked:
'72 Manta Rallye
'73 Manta
'74 Luxus
