| Opel Events List Opel shows, Meetings, and Events Here. Don't forget to add the location. |
#76 (permalink) |
Overall
Keith |
#77 (permalink) |
True, but it's still generally the most accurate with the ratio that is closest to 1:1. Some cars with low HP/torque can't even turn the rollers on some dynos in top gear (Mustang dyno and Dynojet are good examples), since the rollers weigh about 2800 lbs. So the only option is to dyno in a lower gear. But to compare a before and after mod, you need to dyno the car in the same gear every time.
#78 (permalink) | |
1970-GT
![]() On a "X" Dyno here in Florida, if my GT shows 100 rear wheel HP, the numbers mean nothing to you testing on a "Y" dyno in the high elevation north, that shows 80 rear wheel HP. The Dyno is only useful to compare changes made on the same day! If I changed my timing & carb jets, and I gained 3% in HP/torque, that's the only thing that matters. I can't say my GT puts out 20 more HP than your GT! Unless we test on the same day and Dyno. Bob, what dyno did you test on? Lyle |
#79 (permalink) | |
A dyno is simply a tool. If I start at 100 hp, and with some tuning get to 110 hp, then I made a gain. And that's all that matters. You CAN compare amongst the group of cars that attended the dyno day of course, but that's about it. We had a similar situation at Carlisle a few years ago, when we tested 5 Opels on the same dyno, one after the other. I have tested Opels on a Mustang chassis dyno, a Dynojet chassis dyno, and a Dynapack chassis dyno (actually attaches to hubs, taking the wheels/tires out of the equation). I have dynoed engines strictly on a Land & Sea engine dyno, but know of two other Opel guys that have dynoed on Superflow engine dynoes using my parts. It gives me something to go by anyway. What is nice is I have also dynoed some of those same engines from the engine dyno on the chassis dyno (installed in a car of course!), so I got an idea about accuracy after doing a coast-down test. Example: One 2.0 engine made 113.9 hp at the rear wheels, and the coast down revealed 14% driveline losses (Getrag 240 and standard rear axle with synthetic oils). So that is assuming about 132 hp at the flywheel. The actual engine dyno results were 136 hp, but that was with no air filter at all (but a full exhaust was in place). So, they're pretty close considering the fact they were dynoed months apart. It all depends on the correction factors in place, and the operator. We always did 15 second pulls. They sound excruciatingly long, but the results were repeatable. Quicker 'flash' pulls might show higher numbers, but were not particularly accurate. Bob |
#80 (permalink) |
Dyno Testing
Dyno's are a great tool for tuning to achieve maximum results with your set up. Simple changes such as timing, valve lash and carburator tuning will show up in gains or loses on the dyno tests. To get the best results without changing components, several pull should be made in the same enviorment on the same day and with the same operator. I have seen timing and valve lash adjustments pick a motor up as well as carburators and jetting. When you have to operate within certain allowable engine modifications, spent a day at the dyno can be money well spent providing detailed notes are kept on the dyno sheets as to the changes that were made on that pull.
#81 (permalink) |
1970-GT
Thanks, good info!
Since the rollers weigh about 2800 lbs. a low HP car like are Opel's will struggle. It's like pulling a trailer up hill! I will be looking for a local Dyno shop this month. More questions: What make of Dyno should I look for? Should I use the Dyno the "Rice Rocket" Honda guys use? Should I test in 4th top gear only? Should the engine be warmed up, before the pull? Should rear tire air pressure be raised, because of strapping down? Air cleaner off? Thanks Lyle |
#82 (permalink) | |
Harold |
#83 (permalink) |
Dyno Testing
If you are going to test on a chassis dyno with a road car, you need to run the pulls under road conditions, air cleaner on, tire pressure at proper inflation and engine at operating temp. You are trying to make improvments over a broad RPM range as far a torque and HP and the brand Dyno really dosn't matter as long as you make several pull after you make a base line pull. Make notes of changes in jetting, timing and valve lash on the dyno sheet for each pull when they are made. Also on a road car exhaust size and lenght can effect HP & torque. I have only ran 1 road machine on a chassis dyno and it was not an Opel (70 Buick GSX) and we seen as much as 25 HP and 30 foor pound of torque with changes, but that is a much larger engine (455) but the principal is the same.
#84 (permalink) |
The advice we see given here looks very much inline with what I've learned in my studies. The article in Hot Rod Mag a couple years ago really emphasizes that the dyno operator really has to know his stuff, so experience and professionalism is what you want to pay for! I hope you get this, and will be able to see how helpful it can be.
#85 (permalink) |
dyno testing
If you are ever in the Charlotte, NC area and get the chance to tour a top running NASCAR shop, by all means do not pass up the chance.They are not going to let you watch assembly or dyno testing (you might be a spy
) but you will see the dyno "cell" (s) and if you take notice they are enclosed and the enviorment is controled as to temp. and air density. Both the Chassis dyno(s) and the engine dyno(s) are in enclosed controled rooms. Once upon a time the "good old boys" kinda flew by the seat of their pants and there was a lot of trial and error on the track, but since it has become big business and big money these guys "ain't playin" and they use every tool they can to make engines live and produce power. You can kinda take an educated estimation as to what will work and what won't, but the dyno will give you the chance to actually have documented results of any changes made.
#86 (permalink) | |||||
The brand doesn't matter as much as the shop's and operator's reputation. A well-kept, calibrated dyno and an operator who understands altitude and air correction factors is more important.
Bob Last edited by RallyBob; 10-04-2007 at 05:42 PM. Reason: gramma... |
#87 (permalink) |
1970-GT
Thanks again for the info!
I will have to add all this stuff to my Dyno test sheets. I will start searching for local dyno shops next week. Like you guys said, a good skilled Dyno operator is probably more important. My drag racing neighbor is going with me, he has had experience with chassis dyno's. Lyle |
#88 (permalink) |
You got it, just like in your profession Lyle...what good are your machines in your shop without a good operator? A bad machine operator/programmer with the lastest 5-axis CNC machinery can do a lot of damage, but a good machinist on 50 year old manual mills and lathes can make virtual jewelry.
#89 (permalink) |
Tony, Glad you got some footage(orange GT) of Swifty, my 71 orange gt automatic that dynoed right up there with Bear's and Matt's very nicely restored GT's. Matt, as I was living I asked Denise if ya'll wouldn't rather have an orange automatic but that was my fantasy----:-) !!!! Keith, a big thanks to you and your father and your lovely wife(for putting up with us) for a great day in Tennessee! I really enjoyed meeting some of you guys like Gene and Dieter that I see post a lot. Up till last saturday, it was mainly keith and Harold that I talk to ( God, i got to get out more often ;-) !!!!
71 GT/auto in the Boro, 73 Manta Rallye w/AC in the Boro |
#92 (permalink) |
Greenopelgt
T-shirt RECEIVED
TO: All that attended Dyno Days
I just received in the mail a signed Dyno Days T-shirt with your individual comments. I sincerely appreciate and will value this act of thoughtfulness from my many friends in the Opel community who took time out of their special time together to think about someone else.
Tom Adkins 1969 Opel GT 1.1 Liter Cincinnati, Ohio |
#93 (permalink) | |
You're welcome!!
#96 (permalink) | |
Opelitis since 1984
Real Name: Charles Goin
Too bad you couldnt be there Tom so we could compare what you got on your Carlilse Dyno vs what you would have gotten there.. The same day Tom has Ms Opel on the Dyno, I had Bens Manta Dynoed at Carlilse. For Comparison.. 87 HP at rear wheels.. 2.0L Pistons (Actually told they were AMC pistons) Stock Head & Valves (Thats what I was told.. but am starting to think maybe the head had work too if there wasnt somethign off on the numbers) Weber 32/36 DGAV (140/160 Pri & Sec) 75 exhaust manifold (2" exhaust) 74 intake manifold (Bob Legere Hot/Street Port Job) Pertronix 4 Speed Manual 3.67 Rear End
#97 (permalink) | |
Primary idle jet 70 Cold air induction Mild hyd. cam from Cam Dynamics (for mid range torque) 19# flywheel. I think Keith is working on a way to post the graphs. Bear's engine was built for driveability and to be enjoyed without having to flog it to get the most out of it. I have yet to really play with the distributor. I'm going to work with Bear about installing a modified intake and '75 sprint type exhaust manifold to see if that helps. I will be the first to tell you that my weakness is tuning. HTH, Harold Last edited by hrcollinsjr; 10-10-2007 at 09:52 AM. Reason: For clarity |
#98 (permalink) | ||
Opelitis since 1984
Same on Bens Manta using stock Manta air cleaner w/ solex adaptor... cut open the snorkel end and ran to a bell at the radiator support.
Speaking of manifolds.. the one thing I have done without changing anything else was install the Ported BL intake. It alone made a HUGE difference.. Seeing that he only peaked at 64 HP and taking into account the low HP all the other cars showed, I have to say the dyno was reading a bit low. Especially when you consider the fact on the Dyno at Carlilse I pulled a 87 HP the same day Toms stock 1.1L pulled about 54 HP if I remember correctly. I am almost willing to bet if I brought the Manta there I would have pulled under 70 as well. Would have loved to have been there with the Manta so we could have a real dyno comparison. I think you will all just have to come to Carlilse and Dyno there to find out or hold another Dyno day ![]() Charles
CURRENT '06 Pontiac GTO '71 Opel Kadett 4 Door 36D (w/ Opel Parts & Service 2.0L) '74 Opel Manta (Bens Manta) '74 Opel Manta (w/ LK5 transplant) Past '73 Opel Manta (Blue Max) '75 Opel Manta (Yellow) '85 Bitter SC '73 Opel Commodore B GS '73 Opel GT (w/ Vinyl Roof) At least 16 or So Parts Opels Last edited by GoinManta; 10-12-2007 at 09:31 PM. |
#99 (permalink) |
Differences in cars
We all ran in the same range I would say. We noted that Gene's Wagon was a low compression engine and fuel injected, where it seemed like all other tests were of high compression engines. Our dyno will read the same as a dynojet, but some dynos at these shows are notoriously higher, to make the customer happy. Yes, as stated, it would have been nice to run everyones car on the same dyno the same day to see what they compared to across the board. My 1.1 Automatic Kadett was at 28hp on inertia run. I guessed at 30. Tom stated his was 47 at Carlisle. I feel I would experience a drop due to the automatic transmission, but its hard to say with different dynos. I could make ours say that I was pulling 450HP as well
, but for accuracy, we will keep it at the proper settings. Now I would like to sometime this winter experiment with the hydro brake to actually see loaded HP numbers, as this will show closer what the true rear wheel HP would be. Most shows do the inertia run, as the load method can cause a breakdown.Keith |
#100 (permalink) | |
If the camshaft was larger than stock, then the peak hp and torque numbers will generally occur at a higher rpm level. Bob |
