Opel Forums
Go Back   Opel Forums > Opel Forums > Opel Events
Opel Events List Opel shows, Meetings, and Events Here. Don't forget to add the location.
Old 10-15-2007   #101 (permalink)
Opelitis since 1984
GoinManta's Avatar
Originally Posted by RallyBob View Post
Charles, I'm pretty darn sure the cam in Ben's Manta is stock. I recall looking at your dyno sheet and the horsepower rpm peak and torque rpm peak correspond to a stock cam's numbers. Peak power @ 5200 rpms, and peak torque @ 2800 rpms.
If the camshaft was larger than stock, then the peak hp and torque numbers will generally occur at a higher rpm level.
Thats what I remember as well.. now it could have a stock cam and bigger valves. If the machinist that did the motor knew how to modify AMC pistons to fit the Opel block, its not a big jump to think he could have figured out how to modify the hwad with Chevy Valves..
I am sure sooner than later it will need a head gasket and when it does then I can finally know for sure
Since Ben has already had to replace the starter, adn the clutch replacement isnt too far in the future. I had a new clutch, but figured I would let him destroy the one in the car first and then put a new one in once he got past the "learning curve".
Charles
GoinManta is offline   Reply With Quote Top home
'71 Opel Kadett 4 Door 36D
Blown motor = EV Conversion?
