#101 (permalink) | |
4246 Post Club
'Frame' of Reference
http://www.opelgt.com/photos/showgal...0/ppuser/13893 The 'copper' colour on some of the inner panels is a spray on copper-plate rust eliminator product that was used to 'rust-proof' the new inner panels and between the spot welded lap joints. When you see how truly awesome a cherry GT standard body is it is all worth it! HTH |
#102 (permalink) | ||
'72 Opel GT (Sara)
. Thanks for the link - gives me an idea of what the process ahead will be like.Matt |
'72 Opel GT (Fireglow Orange)
Third Owner, Purchased in 1986 Current Status: Fully Restored Major Mods: Weber Carb, High Compression Pistons, Electronic Ignition, XM Radio / CD, ADDCO Front / Rear Anti-Sway-Bars Other Cars: '06 Pontiac Solstice (Envious Green) '99 Oldsmobile Intrigue GLS (Black Onyx) |
#104 (permalink) |
'72 Opel GT (Sara)
Visited the Opel GT...
My wife and I took a road trip this weekend and went to visit the Opel GT at the Mid-Southern Restorations shop in Cookeville, TN. Two words to sum up our visit: "Blown away!". The restored parts are even more impressive in person - pictures don't do them justice.
We had a great day of it and really came away being thoroughly impressed and more confident than ever that this car restoration is going to be worth every penny. I'll post more commentary and pictures in the PROJECT thread this evening after work as well as some hi-res photos into my Member Album. More to follow... Matt |
#105 (permalink) | |
Keith's head is swelling at this point but I'll have to say "Ditto" to what Matt said. Don't go look at the stuff Keith has powder coated or you'll get to thinking how nice it would look on your car. I'm already trying to figure out ways to get some of my stuff powdercoated. It sure looked NICE! Harold |
#109 (permalink) |
'72 Opel GT (Sara)
Thanks!
In case anyone missed it from the PROJECT thread, here is a bump on this request: Matt |
#110 (permalink) |
5,000 Post Club
Keith, you're doing some fantastic work there!!! If I could make a suggestion based on a few obversations of GTs with major front end damage. When you're done with the exterior sheetmetal repairs, install the headlight mechanisms, buckets and covers to match the surrounding areas to them, after they are adjusted correctly. I've seen a few where no amount of adjusting the buckets would bring them into alignment with the surrounding sheetmetal.
#111 (permalink) |
Headlight buckets
You are correct!!! The passenger side I was not too concerned with, but the driver's side was the case. I basically took the headlight bucket and held it into place to make sure my oval shaped hole lined up to where the gap was even on all sides. I didn't cut but a 1/4 of the circle out, but you never know when you have made the cuts too long or short when reinstalling. I also did change the backing mount to the driver's side and I may go ahead and hook everything up just to see if we are okay there as well.
Keith |
#112 (permalink) |
4246 Post Club
Another "Opel" Job ....
Getting the headlight buckets lined up and with equal gap all around is the mark of a well done body restoration.
It is so noticable on may "restored" GTs that the headlight buckets just are not positioned accurately. Took three people, three days to get mine near perfect .... just a hint - get everything as close as possible BEFORE painting the car and carefully build up and blend any miss-matches with Urethane body filler to achieve near perfection! The whole process is another of Opel's "Character Building" Exercises !!
#113 (permalink) |
You made "structure reinforcements for rocker removal"
what is a/the rocker? [ http://www.opelgt.com/forums/general...ownload-3.html ]
Groetjes, Greetings, Grüße:
Only built from 1970 until 1975 ![]() Daily driver: '72 Ascona 2.0 Luxus Automatic |
#114 (permalink) |
5,000 Post Club
Not wanting to steal anyone's explanation, but the rocker is the channel below the doors and goes from the back of the front wheel well to the front of the rear wheel well. It's what the jackpoints and the leading arms for the rear suspension are mountd to. HTH.
#115 (permalink) |
Correct on definition
Namba is correct, they are basically the outer/inner metal below the doors that create the lower door jam. This is a structural area of the car that helps support the body, I don't know how much will actually be cut out of here on each side, but I will be prepared just in case. The cross joist will act as a temporary rocker so once it is cut out, it (the body) doesn't shift into the wrong location.
Keith |
#116 (permalink) |
4246 Post Club
That's English ...
Yeah - the panels along under the door are known as "rocker" panels ... for some reason - guess bodymen and mechanics use the same word to mean different things - the English language usage is a bit like that .... sometimes.
The whole boxed length is sometimes refered to as "rocker boxes" and this complete boxed panel construction is the main strength beam between the front and rear 'quarter' panels behind the front wheel arch and ahead of the rear wheel arch. Thus reinforcing the body before cutting into them for repair so the body does not sag and distort the door opening holes. Last edited by GTJIM; 04-04-2007 at 09:42 PM.. |
#117 (permalink) |
Thanks for explaining, I had a hunch, but wasn't sure, and yes "rocker" is wat confusing, in Holland we call them "koker balken" translated "case or tube beams"
#118 (permalink) |
'72 Opel GT (Sara)
Post #73 - "Rocker Panel"
What? No curvey bead on the inner panel!?! Looks great Keith - thanks for the update. I can't wait to see things start going back on the car - getting closer every day! Matt |
#119 (permalink) |
Have to agree with Matt: "Looks great Keith", wish I was that far with my car, just haven't been feeling up to it lately
